@bnt What method are you using to combine the files? I'm not getting any audio dropouts, and I use either Avisynth or ffmpeg to combine. Try one of those.
Thanks @bnt. I get flicker when using anything but 1/50 shutter with fluorescents in Germany but the quality seems good. Will check for audio dropouts.
Hi,I have a europe g70 and I think it's great for photos and videos. I have a few problems with it. Is less stable in 4k than full hd? I also noticed that audio is mising 0.10 sec aprox..when it creates another file when recording in 4k ( When i put the files together ..video continues exactly but audio is missing that part..so external audio needed when recording in 4k. Each file is 3,96gb every 6 min ..so have to remember, if we can, just stop and start again if possible ( for ex when recording some live music ). Japanese version has 30 min limit in avchd if we suitch to pal? thanks
@DrDave I'm a fan of 30fps, so I almost always use 4K30fps. Never had a problem. It works the same as 24fps.
@santo_w awesome production value! lol. Nice stuff: good narration, Image and sound.
Anyone have any issues with 30fps on the G7? Thinking of switching to 30fps for filming in Europe.
I've just got my G7 from eBay for just $511. It's Japanese international version so it has 30min limit on 4k but no limit on AVCHD. It's not problem as I'm using it as b-cam for details, so each take is just few minutes long. If there was hack it'll be superior cam as bitrates could be a bit higher. I think 150Mbit for 4k should be enough but 100Mbit is sufficient if downconverting to HD.
Lately I have been using the G7 from PV Deals more and more for HD as well as 4K projects. This one was recorded in 4K but output as 720p24. No issues at all.
On this project, each talking segments was way shorter than 30 minutes, but on others, I have been able to record 4K video for up to 90 minutes on a 64GB card. Very nice indeed.I did. No problem at all.
For those with a unlimited recording 4K G7 from here, is it ok to update the firmware to 2.1 without removing the unlimited recording? I'm on 2.0 that shipped with mine.
Thanks!
Hi everybody,
One reason I did not immediately jump to get the G7 was because the 4K video is limited to 29 minutes. This is similar to my LX100 (limited to 15 min). Earlier this month, I was shooting multicam and borrowed a GH4 for the 4K wide-angle cam and it was simply wonderful. I really want a long shooting 4K B-cam. The one from the PV Deal deal (G7 NTSC) fits the bill. I ordered one from Vitaliy and several days later it arrived via DHL. It works as advertised: unlimited record duration for the 4K video.
Just to test this, I set the G7 in front of the TV and recorded away into a 64GB Sandisk card. Figure 1 shows that it created 15 files each 4GB in size (the last one being a bit smaller). When I dropped them into the NLE timeline (Figure 2), the total recorded time is 1:29:59:23. Almost 90 minutes of 4K video. I have had it for 1 week now and so far like it it very much.
Vitaliy, do you have the same trick for my LX100? Thanks!
I've noticed that the version 9.7 SE of the Photofunstudio software which comes with comes with the G7 is much quicker and more effective at trimming clips (edit video/delete partially) for both 4K and HD. This helps a lot with storage.
Hey G7 owners.
I don't know if you are into LUT's but there is a guy asking g7 owners for help by testing some setups to create a LUT to match GH4 and DVX200 cameras. With the most natural skin tone possible.
If you want to help, just contact him on: https://www.facebook.com/visceralpsyche
I got an unlimited NTSC G7 from PV deals. Very good purchase, fast delivery and responsive seller. It came with two original panasonic batteries.
Coming from a G6 and a GM5, i'm very happy with the cam so far. It kind of enhances both previous cameras strengths: The good ergonomics of G6, grip, articulated screen and customization (but more possibilities and overall better build quality) and the good sensor of the GM5, color and noise (but better engine). The natural setting seems quite accurate color wise (just an impression, i didn't test it very seriously...).
With a nice EVF, good 4K codec (not mentioning the unlimited recording of this particular model :-), i would say it's kind of a perfect budget camera.
If i had to criticize something, i don't understand why Panasonic doesn't let the user record focus positions and control speed of motor (since it's all electronic) to pull focus accurately and smoothly in controlled shooting situations. They added this "snap movie" feature (limited to 8s!!) just to let us know that it was perfectly possible! To be able to have marks on the touch screen (like on a follow focus) would be very nice, and would address the main flaw of contrast detection focus in video (ugly hunting...)
Here is a small internet video I've been working on shot almost entirely with the Panasonic G7 and the 14-140 zoom. Yi action camera was used over the shredder. The G7 is not a multi thousand dollar workhorse that being said I think overall it delivers. It was shot in UHD and delivered in HD.
I just bought a ViiGim cage on ebay. Looks ok, $70, not arrived yet
Can anyone recommend a good (on budget) cage for my g7? Could any of these half cages be a solution? Thanks
this is the difference on NX1 between in camera luma level or after in Premiere CC
@rean the article you posted has this text: "All settings record the exact same information. One does not give more dynamic range or protection than another."
It is not correct in mathematical sense. 16-235 luma has less information than 0-255. It has 14% difference. Many users cannot see 14% Y-channel quality loss, but it may be important for color grading for non-ideal lighting. It is 8-bit domain, not floating point, that lossless. Any level manipulation in 8 bit gives a small rounding error. Level manipulation for not ideal image can give a posterization, where this 14% difference may be important.
But, of course, if we have noised video, this difference is really small, because all these small differences will be covered with noise.
