Redownload and check now.
No, Vitaliy just created a new Ptool so we can't alter the settings at all. ( ' _ ' )
@Vitaliy_Kiselev Thank you :o)
hai vitality u mean i can update my camera to v1.1 and work with the hacks????
@Vitaliy_Kiselev thanks.
@Vitaliy_Kiselev, just found a small bug in all PTools versions: they cannot open the firmware file if it's set to read-only (I just did this after I accidentally saved over the stock firmware).
"Error opening file, or wrong format!"
but I'm not seeing any 25p specific patches. Are 25p settings shared with 24p?
Look closely and read hints. 25p is shared with 1080i settings. This is how firmware is designed, it can't be done other way.
Thanks @mozes, I'm about to try balazer's Cake 1.1 (which sounds exciting).
So, you can use settings designed for the v1.0 firmware on the v1.1 firmware? I suppose they will not be optimized for the 25p/30p framerates though?
@_gl i think so.
just did a quik test and..
Video "Driftwood GOP1 AQ2 'AQUAMOTION' Experimental patch"
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : 27
Duration : 41s 80ms
Bit rate mode : Variable
Bit rate : 60.7 Mbps
Maximum bit rate : 102 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Bits/(Pixel*Frame) : 1.170
Stream size : 297 MiB (96%)
Media info: http://mediainfo.sourceforge.net
Sweet - just trying it with 1.1, but I'm not seeing any 25p specific patches. Are 25p settings shared with 24p? ie. will old 24p patches work for 25p too?
Just loaded "Driftwood GOP1 AQ2 'AQUAMOTION' Experimental patch" in ptool v3.64d.
And saved as firmware GH2__V12.bin
The gh2 is updating to firmware v1.1 without problems...
And that auto iso bug is Gone, nice job and well done! thank you.
WOW! awesome, can't wait to try it!
Many Many Thanks Vitaliy!!!!
Awesome, thanks Vitalily (and everyone testing the alpha/beta + developing settings etc).
A new life starts for GH2 and all the master testers.Panny is watching closely...Thanks VK.
Toing, wham, and boing, did not expect it before this weekend, thx...............
Ay Caramba!
Thankyou VK! much appreciated.
The calm before the storm.
