This was shot on a sandisk 8gb 95mb which doesn't span. just a little test shoot out doors to see what quantum v6 is like, I really like it however even with the iso at 160 in this video there does seem to be some noise, it isn't bad at all and could most likely be covered up with neat video but I was just wondering if this is normal?
@mozes Thanks for the report. Yes, class 6 cards are dicey, but they should work OK if you use them with 24L and FH/H modes.
just tested sanity v3.1
The trancent 16gb class6 gives porblems but works fine with sanity v2
The sandisk extreme pro 45mb works just great with v3.1
i have done all posible options, and no hickups or anything else.
just one thing.
after some video shots, i did make a picture in raw format.
after that, the camera says, file number exeed, and i had to remove the batterie.
in menu change the setting in video out from pal to ntsc.
powering down the gh2, and powering up, and set it back to pal.
After that everything works great again.
Even when i take a raw foto picture it dosent give any errors anymore...
720p Screen-shot (from sony vegas when collor correcting... )
                  I know what you mean and I actually do have neat video although I did not use it in this piece. I somehow wanted to see how it would look without the ISO being too high for most scenes although for scenes like the traditional dancing, I kept it at 3,200 so it can be seen more clearly and it was very good. Still, when it came to scenes with the ice, it was my intention to only show the ice well and not care about anything else.
The next time I used that hack was this Moday for behind the scenes shooting for the music video "Beautiful Comeback". It was the 1080 24p H mode and in this case my PNY class 10 had not one issue.
Please don't mind the changing of the lighting in the first scene. That window was being a pain!I took a heck of a lot of footage on that day. The music video was shot entirely on the 5D Mark II by another shooter. I'm not sure when he'll finish editing the music video but when it's done, I'm going to mix some of my GH2's behind the scenes footage with some of the music video's footage for a behind the scenes video and it'll go on that kids YouTube channel. What I might also do is put it on my Vimeo account with a high bit rate so that people can see the quality if they download it. I'm still planning on how it'll look but at least I have some time to think since the music video needs to be out first. I do have good ideas so far.
That video I'm showing is just a couple of clips that we decided should be online right away.
@paulo_teixeira I watched your New Year footage - good job! Just an observation - many of the scenes are too dark. Don't be afraid to use higher ISOs. I do a lot of night shooting myself. It's far more important to see what's going on, than to worry about a little noise. Besides, there's always Neat Video...
@driftwood "The next version will have 50i & 50p primed"
Cool - I am looking very forward to test the next version!
Thank you driftwood, 24H, 1080i, 720P works with my shitty sandisk 16gb. 24L doesn't span. Many other patches give write speed errors.
*** NEW *** Quantum v7 (this is v6 updated - don't bother wiith v6) Tuned buffers 70% of bitrate all round. Plus, 1080pL setting is slightly down on bitrate/buffer ratio - test for spanning please. 720p now on AQ2 for balance. Everything else virtualy the same. This patch looks great in real world preliminary tests. Use the L setting for 80% mode. Tested on Voigtander 0.95 manual lens. I kinda' like the look of this updated v6 patch with GOP3 1080i60 and GOP15 720p60. The next version will have 50i & 50p primed.
