'Apocalypse Now' Experimental Series 1 Thread - BOOM, Intravenus - cbrandin/driftwood AN Soft/Cinema
  • 1089 Replies sorted by
  • What is Intra Venus??? Apocalypse???
  • Apocalypse Now 444 IV: Game-changer? I expect so.
  • Q. What is the Matrix?
    Those must be red pills and blue pills battling it out in the thumbnail!
  • can't wait. Anything that can simulate 444 on h264 will be most welcomed
  • Valkyrie 'Apocalypse Now' 3 GOP Settings
    NEW!!!
    "TYPE-ZERO1" released previously was not good in other than 24p. And, previous TYPE-ZERO2 "Candidates1-5" are sometimes not good in IQ or stability. Therefore, I further improved C1 and made Candidate1.3. setting. Probably in this C1.3, the finest noise in candidates of TYPE-ZERO2 will be reproduced.
    bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.3 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Seta.ini - Released 25/09/2012
    Latest Valkyrie is this. Please try this TYPE-ZERO2 Candidate1.3 first! :-)
    http://personal-view.com/talks/discussion/comment/88237#Comment_88237
    While improving, I am going to develop this in my thread so that it may not become the obstacle of Nick. :-)
    bkmcwd Valkyrie 444 TYPE-ZERO1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' - Setc.ini - Released 06/09/2012
    *I am sorry to make it get confused, because I was mistaken in the matrix. :-(
    Since "TYPE-ZERO" released previously was not with an original matrix of Chris strictly, I remade another setting as "TYPE-ZERO1" with the pure original matrix of Chris anew.
    Warning! : in this "TYPE-ZERO1" setting, all the modes of AVCHD other than 24p are experimental.
    Please keep in mind that artifacts often appears in HBR, 1080i and 720p in spite of being very stable.
    !!! The improved version is "TYPE-ZERO2" at upper link place. !!!
    • Superb-looking simulated 444 matrix from cbrandin
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 75M for HBR/FSH & 720/50p modes (Experimental)
    • Upto 55M for 720/60p modes (Experimental)
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24L only
    • Fully working iA and iDynamic modes if you require them
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
    bkmcwd Valkyrie 444 TYPE-ZERO 'Apocalypse Now' with cbrandin/driftwood 'Original 444 Matrix' - Setc.ini - Released 30/08/2012
    bkmcwd Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix' - Setd.ini - Released 01/09/2012
    • Superb-looking simulated 444 matrix from cbrandin & driftwood
    • Upto 110M for Top Quality 1080p24 at Q16
    • Upto 75M for Top quality HBR/FSH & 720/50p modes
    • Upto 55M for Top quality 720/60p modes
    • Extremely reliable top performance in AVCHD 24H, HBR, FSH, FH, SH, H and MJPEG modes
    • Fully working iA and iDynamic modes if you require them at top settings
    • 6 GOP in 720/50p and 9GOP in 720/60p also bringing short GOP style detail & movement-rendition
    I am sorry! The 2nd is not the right setting although I have uploaded two "Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix'" accidentally. Please download the right zip files.
    1st : Valkyrie 444 TYPE-ZERO
    2nd : Wrong zip
    3rd : Valkyrie 444 Soft Matrix
    4th : Valkyrie 444 TYPE-ZERO1
    bkmcwd Valkyrie 444 TYPE-ZERO 'Apocalypse Now' with cbrandin 'Original 444 Matrix'.zip
    2K
    bkmcwd Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix'.zip
    1K
    1K
    bkmcwd Valkyrie 444 TYPE-ZERO1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix'.zip
    1K
  • reserved for up and coming footage and stuff...
    Driftwood Tips of the Week
    • If by chance you can't seem to playback your Cluster files in-camera, switch off, switch back on, press the play button and everything should be back.
    • 'My Apocalypse Now recordings won't playback in-camera?' For some hi-bitrate recordings what do you expect?! The decoder inside the GH2 is rather limited; inadequate memory, buffers, etc... and playing back these settings where recordings are hitting the settings' peaks will cause playback issues if it runs out of steam. Sometimes its a case of doing what is mentioned in the top tip. But better to bring along a decent specced laptop on set and copy over the sdcard's private folder over to the hard disk and watch the mts files playback thru a decent piece of software like 'Movist' on the Mac or WMP with 'k-lite codec' pack installed on the PC. The most important thing to remember is that there should be nothing wrong with your recordings.
    • Don't forget to record a small recording after a long recording on a 64Gb 95mb/s extreme pro card as sometimes its file name handling gets confused. Doing so will enable you to continue using the card for further recordings.
  • The Matrix
    Q. What makes a matrix? Coming...
    Q. How we constructed the Apocalypse Now Matrices for the GH2
    Answers up soon!
    1220 x 755 - 23K
    1862 x 537 - 61K
  • Cluster v7 'Apocalypse Now - DREWnet' 12/15 GOP Settings
    Cluster v7 'Apocalypse Now' 12/15 GOP (DREWnet) with cbrandin '444 Soft Matrix' setf.ini - Released 28/08/2012
    Includes;-
    • Superb looking simulated 444 soft matrix from cbrandin for sharp lenses
    • Upto 80+M for Top Quality 1080p24 at Q15
    • Upto 40/56M for quality HBR/FSH & 720p modes at Q15
    • Extremely reliable top performance in AVCHD 24H, HBR, FSH, SH, and MJPEG modes
    • iA and iDynamic modes should work at top settings
    • Conservative yet powerful 12/15 classic Long GOP structure for most good SD cards
    • smooth de-macroblocking - ie Flowing water looks superb and Night stuff looks great
    • In-camera playback
    • Spanniing should work
    • Tested by upto 20 'AN' beta testers
    Cluster v7 'Apocalypse Now' 12/15 GOP (DREWnet) with cbrandin/driftwood '444 Sharp2 Matrix' setc.ini - Released 28/08/2012
    As above setting except employing a sharpened 444 matrix as adjusted by Driftwood targetted for soft/manual lenses.
    Apocalypse_Now_-_Cluster_v7_DREWnet_12_15_GOP_'444_Sharp'_matrix_setc.zip
    2K
    Apocalypse_Now_-_Cluster_v7_DREWnet_12_15_GOP_'444_Soft'_matrix_setf.zip
    2K
    Apocalypse_Now_-_Cluster_v7_DREWnet_12_15_GOP_'444_Sharp2'_matrix_setc.zip
    2K
  • Cluster v7 'Apocalypse Now - Nebula' 6 GOP Settings
    Cluster v7 'Apocalypse Now' - 6 GOP Nebula with cbrandin/driftwood '444 Sharp2' matrix- Seti.ini - Released 28/08/2012
    A balanced matrix aimed at both manual and sharp Pany lenses (ie a combination of 'cbrandin 444 Soft' Matrix meets Driftwood's Sharper-tuned matrix).
    • Superb-looking simulated 444 sharper matrix from cbrandin & driftwood
    • Upto 90M for Top Quality 1080p24 at Q16
    • Upto 50/60M for Top quality HBR/FSH & 720p modes
    • Beautiful 6 GOP bringing short GOP style detail & movement-rendition with the benefits of lower bandwidth-consuming Long GOP (ie it sits in the middle!)
    • smooth de-macroblocking - ie Flowing water looks magnificent., Night stuff looks great.
    • Tested by upto 20 'AN' beta testers.
    Spanning - As ever, sometimes it will/sometimes it won't.
    Driftwood Cluster v7 'Apocalypse Now' - 6 GOP Nebula '444 Soft' matrix - Setd.ini - Released 28/08/2012
    Setting details are as above except this is the original soft 'cbrandin 444 Soft' Matrix version targetted at Pany lenses.
    Driftwood Cluster v7 'Apocalypse Now' - 6 GOP Nebula '444 seti.zip
    2K
    Driftwood Cluster v7 'Apocalypse Now' - 6 GOP Nebula '444 Soft' - setd.zip
    2K
    Driftwood_Cluster_v7_'Apocalypse_Now'_-_6_GOP_Nebula_'444_Sharp2'-seti.zip
    2K
  • Apocalypse Now - Intra Settings
    1. Apocalypse Now 'Intravenus' v1 Settings
    • Intra GOP1 24p & HBR/FSH + 6 GOP 720p Modes - Released 29//09/2012
    Another experimental setting. Intra on GH2 for those who require 24/25/30 keyframes per second. The GH2 is just about strong enough for decent Intra quality mid to closeup style shots using matrices based on Chris Brandin's matrices - the 24p is the 444 soft matrix as seen in Custer v7s. The HBR/1080i matrix is an adapted variation of my own, the 720p mode is a slighty stronger weighted version of Cluster v7s 6 GOP 720 using cb's matrix 444 soft. Some of the work ideas gone into Intravenus will appear in Cluster v8 flavours coming soon whereby using a mid to longer GOP users will achieve better Q.
    With 1080i/HBR REC modes, Intra's consummation of max memory limits Intra prediction of the lower field together with its insistence of using part 16x16 macroblocks for horizontal lines under hi frequencies in the lower field (most of it is P mode encoded) - its very difficult to get under control and once again I confer that matrix design is a black art. The matrix has to be compensated for this to stop mosquito / contour artefacts. The first version of Intravenus looks at this compensation but drives the bitrate upto around 117M in certain scenes. Subsequently, analysis of the hi frequency range has led to better looking Intra 25p/30p than in past Intra settings - but it's still not exceptional - indeed I am yet to see ANY setting that blows me away for HBR modes. The GH3 with its 8x8 macrobocks alongside 4x4s will improve the problem considerably.
    2. Apocalypse Now 'Boom!' - Intra GOP1 24p Flat 4 matrix experiment. Works very well for Mid Shots/Close Ups. Out now for trial 24p REC Mode - this setting has NOT been setup for HBR/FSH or 720p despite what patch adjustments you find inside.
    FYI This is a completely different matrix than Chris Brandins. Instead, lets see how far we can push the GH2 and its matrix sharpening. Lets reverse the 'Soft machine' and take a look at how a Flat 4 (All 4s in the matrix) records on a GH2. This has been tested at close-up skintones and mid to tight shots and is very very sharp on a typical soft lens like a Nokton 25mm f0.95. I would probably not recommend this for wider shots or for pany lenses. More notes when I get home from vacation.
    Boom!-Flat 4s-Experimental Setting-seta.zip
    1K
    Intravenus v1 - all-I except 720p - seti.zip
    1K
