Original manufacturer do not have any H005 (it is just marketing trick from seller).
It looks that firmware changed not long ago to include peaking.
So, in reality it is H056.
The Camax H005 seems to be something I've never seen before - white highlights over top of a darkened colour image
I suggest to see SmallHD opinion and comparison. They use similar approach.
Just a fun note - that 5.6" 1024x600 LCD from RED cost $1,700 when it was new.
Note that it appears the H056 does not have peaking, but the H005 does.
The Lilliput 5D-II-O-P has the type of peaking I prefer - coloured highlights over top of a monochrome or colour image.
The Camax H005 seems to be something I've never seen before - white highlights over top of a darkened colour image. You'll therefore need to rely on the camera's LCD for exposure judgement, or turn the peaking off, but the GH2 doesn't have the most reliable HDMi output for judging exposure anyway, and my main concern is just getting focus.
I ordered the Camax H005 (and will review it when it arrives) over the Lilliput because of its higher resolution (1280x800 vs. 1024x600) which I am giving preference to over the peaking style I prefer, and the fact that for a savings of over $100, I can live without the HDMI pass-through. Now, that lack of pass-through might come back and haunt me some day, but I can always get an HDMI splitter, I suppose.
The choice for me was all about resolution... I've pulled focus in the field quite a bit with the 5.6" 1024x600 RED LCD, and it's not quite good enough in a lot of cases, even with peaking. When collimating a lens mount by focusing on a Siemens star, I rely on a 17" 1280x768 Panasonic BT-LH1700W, so I'm hoping that 1280x800 jammed into a 5.6" will make for an eminently useable piece of kit.
How does this screen compare to new Lilliput? http://personal-view.com/talks/discussion/2054/lilliput-monitor-with-histogram-focus-assist-zebras-#Item_88
I really need somthing to judge focus. How is the peaking? Is it strong enough?
"Focus on the high degree of the objects that gou bian, let photography yeah can easily finish in the complicated scene precise focus"
Ehm.. yeah?
I just ordered one from mega-supply on eBay via Mr. Kiselev's link in the first post. Their "Make Offer" is set up automatically. I had three chances to get an offer accepted - $200 and $205 were rejected, but $210 was accepted. So if anyone else is interested, I'd suggest trying $207 and $209, and if those are rejected, at least you know it will accept $210.
Darn, I bought the early version without focus peaking and 5D 480p mode. Now it's very functional. The new model number being H005.
Yep, quite interesting, I updated first post with ebay link and photos.
@strangways - no one bought it - I just have too much camera gear. make me an offer I'll let you take it off my hands. Cheers!
@bannedindv What did you think of it? Why did you decide to sell it? I'm considering ordering one myself, but hoping for some comments from someone who has used one.
I need a focusing solution for the GH2. Reading these threads and not really sure which would be a good option for $200-300. The 7'' or 5'', as I'll be using a hand held device at times. Does this one work on all modes 1080, 720, HBR? If it is a good solution for focusing which battery does it use? I really need a monitor where I can really nail down the focus.
Given that so many other inexpensive 5.6" monitors are 800x480, and many inexpensive 7" are the same or 1024x600, that's a quite an impressive spec!
Yes, false colour of blue, black & white and colour can be toggled. No green or red :( Some more specs pulled from the site:
Screen size 5.6" Resolution 1280(H)×800(V)Support 1080i Dot pitch 0.05(H)×0.15(V)mm Display ratio 16:9 / 4:3 /full screen Brightness 400cd/m² Contrast 500:1 Response time 10 ms Viewing angle Left 85° / right 85° / up 85° / down 85° Input voltage DC 7V-24V Power consumption ≤11W Monitor size L 148 × H 119× D 26 mm Weight 1 kg
It looks good. Does it have any video-related feature? ie. false color, etc.
Interesting find
