@jramos That is a very weird error. Do you have the original MTS so I can try loading it in a couple programs to make sure it's not a software glitch?
Anyway, my favorite Driftwood Intra settings for daytime shooting are IntraVenus V2, Moon 5 and Sedna (though IntraVenus V1 will give you the highest bitrate on low detail subjects). Canis Majoris Night works well for night subjects at high ISO.
I'm using Apocalypse_Now_-_Cluster_v7 sharp2 and i get broken images. What could be causing the problem?
I'm shooting stock footage and I love the Apocalypse_Now_-_Cluster_v7 sharp2 when it works. Can anyone recommend the best hack for shooting stock footage?
I'm shooting the Cherry Blossom in DC and I need a the best hack that works!
I have used Flow motion v2.0.2 and Sanity 5.1 but I still like Apocalypse_Now_-_Cluster_v7.
Thanks for the help!
                  Here is an experiment with Intravenus IV 2 - 720p. This patch is the perfect gateway to explore more usage of the 60fps capabilities of the GH2. Spanning is flawless. Thank you very much for the great patch.
Here is a music video.... really just a concert with some story added in... I shot ALL on the LOWRIDER patch :)-
Here's a clip using the latest Apocalypse now. It was really dim in the church so I had to crank up to ISO to 1000 -1250 using 20mm pancake 1.7 wide open. I can't believe how good it turned out using whatever light there was. Colors are rich and noise is not ugly blocky. I feel confident taking this camera/lens anywhere where lighting is lousy. I tried several other patches, and I like this one the best so far with this lens. Thanks Driftwood!
I want to analize edited files that are not recognized by stream pharser. Is there another program, or coud stream pharser do it in the future?
You have not added grain to the clip? Do color correction? In some frames visible fibers, like bristles or hairs on the film.
If you're talking about the vid I posted then yea, there is actually some film-grain I added.
@HillTop1 You have not added grain to the clip? Do color correction? In some frames visible fibers, like bristles or hairs on the film.
the quality don't looking as how it is on FCP7, it's degraded a lil.
Oh yea, never use "quicktime conversion". Always export "current settings" and then transcode with another app like mpegStreamClip or Compressor...
@rajamalik, I think he has all that info in the post above mine :)
@bwhitz looks good, may i know what profile u used?? std or smooth?? nokton lens or nikon???
@bwhitz, great video men! Great work. You mentioned you use FCP7 for editing, I am having a problem with it maybe you could help. After color correct and everything is done and I export my project using quick time conversion, the quality don't looking as how it is on FCP7, it's degraded a lil. Are you having sure a problem? If not any suggestions on how I can fix it? Thanks.
@matt_gh2 @bumsklumpen @x_worpig_x
Thanks for watching! Glad you liked it!
And yea, as far as setting go...
Profile: Standard (-2,-2, 0,-2).
Lenses: Sigma 30mm 1.4 (on the Glidecam HD-100 Shots), Tamron 17-50mm 2.8 (for the Jib shots), and Canon L-series 50mm 1.2 and 24mm 1.4 (on the slider and close-ups).
For the color correction, I used the standard FCP7 3-way corrector. Exposed and lit the sets for about a stop over what I wanted the final image to look like, then dropped the mids quite a bit in post. I've always like the look the dropping the mids gives the footage... much more cinematic/film looking gradation.
@bwhitz Great cover man! The video was exellent!
@bwhitz really nice video, congrats!
@bwhitz Awesome video! I just found Intravenus 2 a month ago and fell in love. Mind sharing what lenses and settings (standard, smooth etc -2s etc)? This Intravenus 2 is crazy...footage comes out of camera perfectly. Great video really - visuals great, story great, and performance great. Thanks for posting.
Here's a music video for a friend's cover I just did. Shot with Intravenus II 'cinema smooth'. I think it's the best patch I've ever used. I was shooting at ISO 1600 in 60fps 720p mode for some scenes and there was BARLEY any perceivable noise. So awesome!
Nice work @nachelsoul
Thanks @WhiteRabbit. The name of the song is "end of the line" by Daft Punk (remixed album). A superior theme and soundtrack. I have seem that the soft version makes the Panny lenses look alike older glass, less "plastic" sharpness. I found it very usefull 'cause the 20mm and 14mm are great glass, classics I would say, and I like to mix them with legacy glass. Thanks to Driftwood to make it possible.
@nachelsoul, looks good. I was testing AN sharp 444 prior, as I am a legacy glass addict. Hard for me tell any substantial difference between the patches, as I have not tried any form of relatively controlled test to compare. They are all so great to me. Cool edit and music. What is the name of that song?
AN 444 soft is incredible with Panny glasses. Thanks Driftwood to make this happen.
Also work well with Canon FD´s as you can see in the video.@Meierhans Sounds like good choices. I like Sedna but felt grain at times was a bit too pronounced. I would def try IV1 as many rave on it, and this all comes down to how it hits your eye and personal taste.
Thank you for your very detailed reply @matt_gh2. Really helpful! I havent had the time to test trough all these settings, but its kinda seems that after using Sedna AQ1 for quite a while I will now settle down to Moon 5 for business stuff and give IV2 a try for anything that goes into the direction of art.
I second your praises to the masters of GH2. ;-)
@Meierhans I tried Moon trial 4 and it was too sharp for me. I understand trial 5 and 3 aren't as sharp. But I have looked at many of the samples of Moon trial 3 and 5. IMO, best use of Moon trial 5 was the rap video done by @DeShonDixon. I think that highlights one way Moon trial 5 can really shine. @kellar42 did a nice test shot of trial 3 that had some images that looked like great professional landscape establishing shots you might see in a hollywood film. To compare them and IV1...Moon (trial 3 and 5) has a unique imaging characteristic to it, and in the right hands can produce gold. IMO the best use of IV1 has been from @shian who's put up a few videos that really show how IV1 can be special when in the right hands.
For me, IV2 (on Smooth -2,-2, 0,-2....Standard is too harsh for my taste with IV2) is like handing a kid a 35mm camera. Everything he shoots will just have the texture/look of film. Now all he needs to do is learn filmmaking and all that involves. It's almost as if the "film-look" issue is now solved for me. What shocked me was I brought IV2 footage into editor and started doing some things I often do to get film-look (luma curve adjustments etc.) and it made the footage worse...and I realized the footage was great/correct straight out of camera. Some of that I attribute to my DP - I think she just nailed the shooting that afternoon...but the base image texture/type/nature of IV2 on Smooth just happens to hit my eye as "35mm film".
It's all what you're going after. If you want an energetic/dynamic and modern look that can be really special I think you can get that with Moon 3, Moon 5, and IV1. If you want more classical 35mm film look, I think it can be acheieved with IV2. (I also like footage I've seen with Quantum v9b, which I also consider a modern look).
Gotta love this damn GH2 - it's a gift. Bigtime thanks always go to cinematic geniuses known as @Vitaliy_Kiselev @Driftwood and @cbrandin
