@peternap that looks awesome... which lens did you use?
@SisterCities I used my normal walking around lens. A 55mm Nikkor 2.8 micro Nikon mount adapted.
This patch was worth waiting for. The low light test was next so I drove to town and started shooting a Burger King from about 200 yards at ISO 800. It is amazing! Some noise but fine grained and good sharp images in the lighted areas. That's in 720-60.
Tomorrow I'll start panning and give it the "I screwed up, can I save the clip" test...Kinda like twit of the year.
Which one of driftwoods hacks are best for video high detail and works well with HBR 25p PAL?
Here's very high HBR 25p and 720p plus everything else... Please now try Cluster v2c FINAL as P frames on 24p have been slightly tweaked at GOP memory level.
                  @driftwood Thanks! :D
@driftwood May 31...Left 4 Dead Fan Film Behind the Scenes (Northern Five / Airsoft GI)
Why do people produce such a bullshit ? What for ? What reality ? What need...??????
@Driftwood, is Cluster v2c for for Pal users or for NTSC ?? Thank you for your great work and your time.
@driftwood 6:04AM ...Here's very high HBR 25p and 720p plus everything else....
Just come back from town testing V2b (not final):
Results: SDXC 95MB/s 64GB. - 14-45mm Pana - Iso 160 outside-640 inside -3200 Underground.
PAL land.24p = no playback in camera, camera stops, restart by removing battery. Mjpeg = card speed/reed error after some seconds, shut down, restart by removing.... HBR = Works fine.
Result quality playback: top quality in 24p,
                                     visible worse quality in HBR comparing 24p
                                     no flowmotion in the seconds with Mjpeg, HD result simply not usable.
Only had positiv, impressiv results with all driftwood patches before !???
@driftwood, thank you, looking forward to it.
@Benibube Having just checked my mjpeg settings I realise (as I had working high settings for months) that these are not the correct ones. The adjusted mjpeg settings that you will see in v2d attached below (in a moment) will have my 2K dimensioned 2048 x1152 HD very high quality settings. Apologies for this oversight.
@xavieramelio for NTSC and PAL - its pretty much there for 6 GOP - looks good allround. However,expect a hi powered 720p for a future Cluster v3.
                  @driftwood....good timing ...I was about to load 2c...:)
@driftwood 5:13PM...thank you Nick !
CLUSTER v2e
Ok this is just about right and NOW with in camera playback too. Please experiment and let me know how you get on with this lill' babe. This will not 'dropout', fallback (call it what u wish) unlike other settings Ive seen of late.
Superb allround setting for people who want that bit more!
At ease.
                  @Driftwood Are there performance differences between 2d and 2e other than the in-camera playback? I was unclear on whether the comment about fallback mode applied to Cluster 2 versions or only to 2e. I ask because I was about to start testing 2d but I see no reason to do so if it is already obsolete (so I would just head back to a coffee shop and re-load).
@driftwood only v2e has 2k and v2a doesn't right?
@driftwood This is getting confusing. Is 2a the same as the first v2 you posted?
Okay - at the coffee shop now. While I am here, here is a Cluster 2D frame shot handheld in NTSC EX SH with a 58mm Rokkor at f/4.0 (vibrant -2, -2, -2, -2 with IR off and shade WB).
