Thx for explaining this @driftwood.
i was thinking that it where the standard settings from the gh2!
**** TODAY'S HOT TIP FOR BEGINNER's ****
Question: I want to try a different matrix on such and such a setting?
Answer: Easy, follow these simple steps:-
REMEMBER: PATCHES ARE SELECTABLE SECTIONS IN PTOOLS FOR YOU TO EDIT, SETTINGS ARE WHAT WE INPUT, EDIT & SAVE & AS A COLLECTIVE NAME (like for example 'Orion').
Done
@L1N3ARX that's the look i am looking for very will done
@L1N3ARX That looks amazing. The cinematic quality of those shot and the composition makes me feel like the potential of this camera is beyond what I've thought of it as. All with a 20mm. Makes me wish I had a 20mm now! haha
Testing out Orion 4vC around the city.
@GH2_fan check out the first post for more info on the settings. Orion's info via Driftwood: 154M INTRA 108024p; CBR style HBR & 1080i INTRA 100M+ Max; CBR Style GOP12(PAL)/GOP15(NTSC) 720p 50/60 - 80+ Max
Dark matter is a proper name for this matrix, hbr is high bit rate, and Cbr is constant bit rate. There is a lot to take in to understand the patches, you really should read through the first few posts on this topic, and maybe check out what @lpowell wrote on the flowmotion settings topic.
@JPB1138 version 3. Everything is 24P at 1/50th and the daytime shots are 160 iso. I think all of those shots were on smooth 0,0,0,0 too.
Well can someone tell me more about "Driftwood Quantum X (v4d Orion) 'Dark Matter' Matrix Pack + HBR FIX - CBR 'Settings'", is it completely Intra-frame? and what Bitrate does it record at?
Also, what is the title of this patch telling me exactly? "'Dark Matter' Matrix Pack"? "HBR FIX"? "CBR 'Settings'"?
@jclmedia. Try Ralph_B Sanity 3.1. 720p60, 1080i60 and HBR are very stable and good quality. I have been using it along with Driftwood's Orion v4b CBR for 24p and I am very happy with both.
@royadkins which matrix version of Dark MatteR?
Few clips edited together of testing Orion Dark Matter, night shot ends at about 1:25
@jclmedia What card are you using? I use an 8gb Sandisk Extreme 30mbs card and have no troubles with 720p on any settings with Orion. Lower end cards may not work.
@brodieg Beautiful sky. :)
@driftwood What would you suggest is a good matrix mix between the stock Panasonic sharpness and the Orion 4b.. one of the dark matter matrices?
I often go from the Leica/Lumix 25mm 1.4 to Zeiss and Tokina manuals.. and without switching patches, which would be best for a good mix? thanks. All others who have tried dark matter may chime in as well.
@GH2_fan If you mean "highest quality regardless of bitrate", the different Orion versions seem to be the current favorites, though which of the 4 is a matter of opinion. :)
Hi everyone, I know this may seem like the noobish question ever, but what would you say is the 'best' version of Quantum patch to use??? :D
it there any chance to get a "mini" version of latest orion dark matrix v1 ... this CBR "eats" my SD 32GB ... I need something about 50mbit that works OK on HBR 25p PAL ... If I had two GH2 the one would be all the time latest orion dark matrix :-) EDIT:Ah, found it "Cluster" will test this :-)
@driftwood "red chrominance" the patch for graphics people for chrome key????
@Driftwood Will do. And here's hoping the testing doesn't get too "testing". ;)
@thepalalias You're 'thee' audio man on this site. Let me know when youre finished and Ill include it on the next Orion if you want. Making progress on limiting red chrominance but its difficult... taking a lot of tests.
@Driftwood Thanks, but they are also about to get a lot better.
Been spending the last couple days improving them and @SpaceWig and @Frame are both helping with testing now. :)
@driftwood i recorded a very long session in orion v4b today,..amazing patch sir,..thank you so much,...do u have any future plans to improve this patch further? i am very much satisfied with this patch,..just curious to know abt u r research
@thepalalias Must remember: I need to integrate your excellent audio settings in our future settings. :-)
SMBU v2b is great. It's the one I've been using while testing for the "Setting AGC" and "Setting Level Meters" GH2 blogs I've posted in my Tutorials section.
http://perlichtman.com/pasdenapulse/wordpress/category/tutorials/
