A simple music video, using the eoshd 44mb vanilla patch, and a cheap cctv 35 1,7 lens. Lightning was done with the led light zv96, quite happy with the result.
Driftwood GOP1 AQ2 'AQUAMOTION' Experimental patch
All done in 720 50fps, with some twixtor in post.
Edited in sony vegas, and only added the levels plug-in for the differences between light and dark.
//edit, some parts with color corrector 2, and some parts with magic bullet filters.
1080i converted to 50p, then slowed down to 25p, and one part with twixtor (you can see it by the warp effects)
First 19 seconds is original and still interlaced, from there on its 25p
Sanity 3.1
Lens all the time on 150mm with some parts with tele2.
all shot in 720p 50 fps (only the last clip is 1080i converted to 1080p 50fps)
720 upscaled to 1080
just a clip with v3.1 and color presets to try what editing does with it later in post.
http://www.one80project.com.au/page/Top-Ten-finalists/Fracture-228
Heh guys, a fim comp here in Australia we made into the top ten. Shot with the GH2 with dirftwood settings (150mbps, i think?) cheers PS make sure you vote for us too ;)
Some work I did... shot with Quantum v5 If I don't remember incorrectly. I did the footage and grading/coloring - no editing. Please comment here (if you want to) instead of on Vimeo as it's not my page:
vimeo.com/35000111
Shot with sanity v3.1 The patch works great, only in interlaced H mode with tele2 it faild. No problem i never use it, just want to test it. sadly no Internet ad the moment, So i uploaded this screen-shot with my phone. Shot with 1/500e and lens op 150mm tele2 (auto iso) and dynamic collor. Graded in sony vegas pro, with levels, white ballance and collorlab.
when my Internet is up again, i post a link to the video..
@GMC wonderful work! I see myself spending some time at the airport this summer after watching this. The shots in Macau (?) look incredibly cinematic as well. Is that the Panagor, too? (DOF looks too shallow for the 20mm, or is it?)
@feha
Thank you for the positive feedback.  On my drift car, I taped on my iPhone 4 which I also glued onto a hard iPhone case an old 0.42x wide angle lens from my old DV camera days.  There is too much vibration coming through the car body shell, so a better method would be to make a mount that connects to the chassis of the car to reduce vibration  in future recordings.
All the footage at ground level are mostly a MIR-1 37mm f/2.8 'Grand Prix Brussels 1958' and hand held tracking cars along the track is a Helios 44-3.  These are in M42 mount and mounted to the GH2 via an adapter purchased from eBay.  As for the Helios 44-3 58mm f/2, I had to remove the focus ring as it was rubbing against the adapter preventing change of focus.  I am in the process of have it CNC cut down.  The Helios 44-3 has 8 aperture blades, whereas the other Helios usually have 6 blades.  The MIR-1 has ten blades, making circular bokeh rings at any aperture.  I like USSR glass, and use this set for more general footage acquisition, as opposed to my Lomo's.
I also have as part of this set, the Jupiter-9 85mm, Jupiter 37A 135mm. I personally like the bokeh rendition of all these lenses and they do not breath when pulling focus.  The other lens I use is a Carl Zeiss Flektogon 20mm f4.  My favourite of the set for general use is the MIR-1, and this older edition that I managed to find in near mint condition is not multicoated, so I can get it to sometimes flare nicely.
great video, what lenses did you use ? also camera on yellow car "Go Pro" ?
Quantum v7. Thank you @driftwood.
@blackspot glad that you liked it i used the following lenses and magic bullet looks for color correction/grading :
PANSONIC PANCAKE 20MM 1.7 Panasonic 14-42mm f3.5/5.6 Canon FD 50mm f1.4 Canon FD 135mm f2.8
Mission Impossible spoof. Quantum V6
@Swiss_Boy I Love that video of yours! It looks just beautyful! What lens and setting (and color correction) did you use?
