How hard would enabling sound recording in the 24fps 1080p 80% speed mode would be? Because, at least in the NTSC version of the camera, it is actually just silent 1080p at the standard 29.97fps - so I use that as my standard shooting mode and I'm always frustrated by lack of sound to sync my second source audio to. Would totally be awesome if this GH2 hack comes to fruition.
What you want can be done, but it has to be done in software - you can do it in post. The firmware could theoretically do it too, but it requires a lot of frame memory and some processing power.
Ahah i'm sorry vitalyi but i don't know how they work, i just thought that it was possible to let the sensor record frames while the shutter is still open obtaining powerful effects like light trails. But it is impossible ok, got it eheh
@Elenion, I'm not sure what you mean. The shutter can't be more than fully open, which is whatever the framerate you're shooting at (ie. 1/24 for 24fps).
I know that i can record with much longer speeds but the gh2 record just a frame every 1/8th or whatever i choose, it doesn't take frames continuously at 24p while the shutter is open like it happens with film cameras
You can shoot with much longer shutter speeds, but you can only select them if you switch to MF (manual focus) for some reason. However true 1/24 would be useful so the shutter is fully open.
If i choose a shutter speed of 1/8th of a second for example also if i choose 24p recording i've a video where every frame is taken every 1/8th. I thought it could be possible to record what the sensor sees while the shutter is open, like in analogic film cameras. But if you say that it is impossible, then :(
I don't know if it's possible but i think that it might be a real plus: the ability to record all the 24fps with the shutter open for more than 1/25. Maybe it is just a codec issue and you can fix it, it would be awesome
Vitaliy, man, honestly just do your best, as I'm sure you are. Anything extra we can get out of this already amazing machine will be much appreciated. Good luck!
Firmware Request Would there be a way to set ISO for videos outside of Creative Motion Picture Mode? For example, when the camera is in M/S/A/P and I press the video button, the camera instantly changes the ISO setting to AUTO.
Perhaps another way to enable this is to allow the exposure lock (AEL) to function for movies taken when the camera is in M/S/A/P mode. Again, when the camera is in M/S/A/P + AEL and I press the video button, the AEL is disengaged an the camera uses AUTO ISO.
The Creative Motion Picture Mode does not have this issue, but I'd rather not have to twiddle the dial back and forth between M/S/A/P and Creative Motion Picture Mode.
Firmware Request Would there be a way to allow EX. TELE CONV. function outside of Manual Movie mode?
* Increased bitrate for 1080 24P (120 Mb/s ?), but if possible, increased bitrate for all Video modes (e.g. 720, 1080i ....). * 1080 60P (We can dream, can't we?... LOL) * HDMI The ability to correctly stream 24P over 60i for capture. * Anything that can help improve signal-to-noise spec. (Although, this will of course be limited to hardware) * More Zerbra settings e.g IRE 60, 65,70,75,80,85,90,95,100 * 720P improved with B frames. * Ability to stream video at a higher bitrate to USB.
I've been lurking this forum for a while and am about to purchase a GH2 but they are too damn expensive here, plus I do not like the 30 minute limit on the PAL version. Is there currently no way to change the language of a Chinese or Japanese version to English until the hack arrives?
Vitaliy, I have a question about the issue with 3rd party batteries not showing their power level. Is it GH2's 'feature' that can be overriden with the upcoming hack or is it battery manufacturers' issue and nothing can be done about it? I hope it can be hacked somehow because original batteries are crazy overpriced and the cheap ones usually die in the middle of a take, which is not cool at all;) Thanks!
I would like the ability to actually USE remote aswell as mic to the 2,5mm jack using soldered adapter, as iandrew pointed out.
- "after studying gh1 schematic I can say that this is fully software feature: switching from internal to external mic is software procedure (command and wires going from main board). It will be great for example to have possibility to "manualy" switching to external mic."
- cited from "GH2 Remote+Mic Adapter out there?" thread, which i started.
I wish for working AE lock during video recording. It works currently "one-way" only (it's possible to turn it on before recording and switch off when recording), so it sounds like very possible improvement.
But full manual gain control would be much better, of course.
