RJ Lens Turbo m43 adapters
  • 782 Replies sorted by
  • @Boncrek For what its worth, I have the 2nd version, the one that came with the tripod foot, and I see it a little bit. Its not bad, but Ill see it if I look for it.
  • I did read it and only some persons mentioned it while others say they didn't see it at all. So I decided to ask.
    Well, cool absence of logic.
  • @Vitaliy_Kiselev I did read it and only some persons mentioned it while others say they didn't see it at all. So I decided to ask.
  • @Boncrek
    Small tip, you can click on page name and read topic from the start.
  • This is a question for owners of the Version 1 of the Lens Turbo (the one without the tripod foot): Does your copy of the lens turbo suffer from the blue dot problem when looking into bright light sources while stopped down?
  • Thank you very much @anti12 thats very good news
  • @konjow I measured mine and I'm pretty sure it is at least 21mm on the thinnest part of the curve.
  • I know it may seems to be wired request but can same happy owner (Nikon version) tell me what is a dimension marked red on the picture. I need to know if its more then 20mm.
    664 x 632 - 63K
  • I've gotten the Nikon (F/G) to M43 one, because the newschool Tokina 11-16mm f/2.8 and Sigma ART 18-35mm f/1.8 give you a very nice ability to shoot wide and in somewhat lowlight conditions. Especially with the rather small crop sensor of the GH4/BMPCC, I find it really convenient to be able to use these lenses and use a focal reducer in combination with 'em. Pretty sure 'new' refers only to the addition of the adapter's collar / tripod mount. It's a rather nice addition though, certainly if you're working with some heavier/bigger glass.
    Just got back from a trip to China (I took the FZ1000 with me to keep travelling light) and have some days off now to fully test the RJ Lens Turbo out (if weather permits to go out and shoot some).
  • Hello,
    I'm wondering which adapter to choose between the Nikon F/G and the Canon FD.
    I just want to use it on the Nikon or Canon 50mm f/1,4
    I prefer the quality of my Canon 50mm but I'd like to know if the inscription "new" after the Nikon F/G to micro4/3 indicate a better optical performance or if it's only for the external build quality.
  • Is there any reason stacking a dumb adapter on this would lower IQ?
    Because adapters are not ideal things :-) But for video tasks if additional adapter is not faulty you are usually ok.
    I would like to put a OM to EF adapter on the EF focal reducer. Maybe a Nikon G to EF as well.
  • Ah! It took a while to get here. But in the end it was worth the wait. Own fault for wanting the free shipping (no import charges, yay!). Free shipping is not so quick. Easy peasy put together. Lens turns on smoothly; in turn the adapter attaches smoothly to the GH4 as well (maybe some added markings on the tripod collar and lens turbo would've been nice for easier alignment of the two in order to get the tripod base exactly level). So far, so good. Happy camper here. Thanks Vitaliy & RJ!
    Now just gotta find some time for some vigorous testing. Unfortunately a couple of long days work ahead of me first.
    540 x 370 - 88K
    640 x 213 - 92K
  • Have there been any side-by-side comparisons between the different focal reducers? I'm especially interested in any image quality differences between this, and Metabones.
    You can just browse back, it is long topic.
    Also, do we know if they are working on anything stronger than 0.72x? Maybe something better suited for the GH4?
  • How do I know if it's the older adapter the one I have ?
    All Canon and Nikon ones that do not come with such ring are old ones.
  • About the mount ring, I was wondering if it was possible to get one without the adapter since the first time I bought the one for nikon mount I didn't think I would need one.
    It can't be used on older adapters.
  • @Vitaly,
    First suggestion: write apperture mesures/marks on the adapter so we can have more controls on the apperture wheel, especially if the lens used lacks one. See this for exemple: http://www.bhphotovideo.com/c/product/1002612-REG/metabones_mb_nfg_m43_bm1_nikon_g_mount_lens.html
    Other suggestions might follows, but I thing that gonna be all for now.
  • Is the RJ Manufacturer/builder open to some suggestions like light modifications on their adapters speedbooster ?
    What is your suggestion?
    Also, do thew still offer the tripod mound ring ?
    Meaning? Two adapters (EF and Nikon G) have such thing.
  • @Vitaly, Is the RJ Manufacturer/builder open to some suggestions like light modifications on their adapters speedbooster ?
    Thanks to answer
  • Rj turbo canon to mft arrived today .. all ok thanks Vitaliy
  • I've heard from someone that it's a stereoscopic fisheye, and I had no idea what the hell they meant by that as I had assumed that all fisheyes had been using one perspective. I think that might be one reason behind the 6.5, or it could be 8mm as several have argued :) Refer to http://en.wikipedia.org/wiki/Fisheye_lens#Mapping_function for those who've no idea what I meant.
  • Have any of you considered the 6.5mm 3.5 fisheye
    Something tells me that it is Vivitar rebrand of Samyang 8mm :-) So, not 6.5mm at all.
  • From the research I recall, I couldn't find any mention or examples of it. One of the reasons I'm so interested too. I can't really imagine what they'd look like though, sounds like it'd give crazy results.
