Olympus most expensive and last m43 camera comes in January
  • 110 Replies sorted by
  • @Bernie
    Yes, photo only.
    They'll use same software as they do for extended resolution. So, it is almost free addition.
  • I don't think that Olympus are saying it can be used in video mode. Purely for still photography.is my guess.
  • Well so what are they doing taking two exposures at 1/120 and combining them without clipping to make a fake 1/60 of a second image? So instead of having too little motion blur in your video you'll now have weird stitched together double motion blur?
  • Live ND
    Which can obtain using slow shutter effect “Live ND” which can simulate slow shutter effect like using ND filter was installed. It is a new technology that can obtain slow shutter effect by combining multiple exposed images. In addition, you can check the slow shutter effect with the viewfinder before shooting by live view, and you can improve the shooting efficiency. The effect can be selected from 5 stages of ND 2 (equivalent to 1 shutter speed), ND 4 (2 steps), ND 8 (3 steps), ND 16 (4 steps), ND 32 (5 steps).
    Fake thing.
  • Video and audio only
    • Video recording system: MOV (MPEG-4AVC / H.264 )
    • Modes
      • [MOV] 4096 × 2160 (C4K) / 24p / IPB ( about 237Mbps)
      • 3840 × 2160 (4K (FHD) / 60p, 50p / IPB (FHD ) / 30p, 25p, 24p / IPB (about 102Mbps)
      • 1920×1080 (FHD) / 30p, 25p, 24p / ALL- IPP (SF, F, N) 60 p: 59.94 fps, 50 p: 50.00 fps, 30 p: 29.97 fps ( SF, F, N)
      • 1280 x 720 (HD) / 60 p, 50 p, 30 p, 25 p, 24 p / ALL- , 25 p: 25.00 fps, 24 p: 23.98 fps 24.00 fps at C 4 K, HDALL-I (AI: ALL-Intra / about 102 Mbps), FHDIPB (SF: SuperFine / about 52 Mbps, F: Fine / about 30 Mbps, N: Normal / about 18 Mbps) , HDIPB (SF: SuperFine / about 26Mbps, F: Fine / about 14Mbps, N: Normal / about 10Mbps)
    • Recording time limit: about 29 minutes
    • High Speed Shooting: 120 fps (1920 × 1080 / MOV)
    • Shooting Movie Shake Reduction: M-IS 1 (Multimotion IS with Image Sensor Shift and Electronic Shake Reduction), M-IS 2 ),
    • HDMI Monitoring Through: Monitor mode (mode for outputting video and information to external monitor)
    • Recording mode ( mode for outputting video only for recording on external device)
    • Movie exclusive Picture mode: Flat, OM – Log 400
    • View Assist
    • Audio
      • Wave format compliant (stereo linear PCM / 16bit, sampling frequency 48kHz
      • High-quality recording stereo linear PCM / 24bit, sampling Frequency 96 kHz
      • Built-in stereo microphone (connecting external stereo microphone possible)
      • Recording level adjustment
      • Microphone input limiter
      • IC recorder link: Slate tone generation function. Movie shooting and recording synchronization function. Compatible models: Linear PCM Recorder LS-100
  • More leaks via 43rumors
    High-speed performance and excellent image quality
    Speed and image quality of the new E-M1X are fueled by a 20.4 MP Live MOS sensor with a new coating in order to deliver improved sensitivity as well as two TruPicVIII high-speed image processors improving fundamental performance factors such as start-up time and recovery time from sleep mode. The dual processor design not only contributes to a faster camera, but also allows the support of two high-speed UHS-II SD card slots and enables the latest shooting functions such as Handheld High Res Shot, Live ND, and Intelligent Subject Detection AF.
    Advanced Image Stabilization
    Olympus have introduced a redeveloped gyro sensor -- the camera allows for the world's best compensation performance. In combination with a M.Zuiko IS PRO lens, this technology enables the 5-axis sync IS to compensate for approx. 7.5 shutter speed steps, eliminating the need for a tripod and enabling free-hand shooting in various conditions.
    Super-fast AF
    With locked AF, the E-M1X features high-speed sequential shooting at a maximum of 60 fps to capture split-second moments that the human eye cannot see. With AF/AE tracking, a maximum of 18 fps may be reached. The camera's Pro Capture Mode records up to 35 frames retroactively from when the shutter button is released during shooting.
    High-Res Shot functionality
    In addition to high-resolution maximum 80 MP images that can be captured in Tripod High Res Shot, a Handheld High Res Shot functionality is now available on the OM-D E-M1X: designed for photographers who don't want to be limited by using a tripod, this function generates a single high-resolution shot equal to that captured with a 50 MP sensor -- without any signs of blur caused by handshake.
    Live ND functionality
    A new Live ND functionality incorporates slow shutter speed effects as though using an ND filter. The scene can be reviewed in the viewfinder and the effect edited before users take the photo. Effects can be set in five levels: ND2 (equivalent to one shutter speed step), ND4 (2 steps), ND8 (3 steps), ND16 (4 steps), and ND32 (5 steps).
    Movie capabilities
    In addition to professional-quality photos, the new E-M1X is a master at movie-making. It features all the extras videographers need to capture moments as they happen. With the ultra-high Cinema 4K (C4K, 4096 x 2160) movie format, videographers not only have the highest recording resolution to date, but also more flexibility when it comes to post production. 120 fps high-speed movies are also now supported in Full HD resulting in the capability to shoot cinematic movies with slow-motion perception.
    The powerful 5-axis IS and electronic stabilization enable refined handheld 4K and C4K video recording with three selectable levels of movement compensation depending on the photographer's posture and movement.
    Log shooting
    To counteract changing lighting conditions typical during documentary and nature shooting, the E-M1X supports log shooting. OM-Log400 delivers movies without loss of details in shadows or highlight blowouts, and greater freedom over video creativity through colour grading.
    Anti-flicker shooting feature
    With an anti-flicker shooting feature, the camera detects the flicker frequency of artificial light sources and activates the shutter at peak brightness to minimize uneven exposures and coloring between sequential frames (via PR). Flicker scan suppresses striped patterns that can occur when using Silent Mode (electronic shutter) and when shooting movies, so that users can fine tune the shutter speed.
    Connectivity
    A new Wi-Fi capture allows tethered shooting without a cable and makes it possible to transfer images wirelessly to a computer with the “Olympus Capture” camera control software.
    GPS
    The OM-D E-M1X contains a built-in GPS sensor, temperature sensor, manometer and compass, collectively known as ‘field sensors’. In addition to location information such as longitude and latitude, these sensors detect and record the temperature, elevation, and direction of the camera for adding detailed shooting information to images.
    • World’s best Image stabilisation: In combination with a M.Zuiko IS PRO lens, this technology enables the 5-axis sync IS to compensate for approx. 7.5 shutter speed steps
    • 50 MP Handheld High Res shot functionality. Building on the HiRes innovation on the E-M1 MK II where a tripod was required, the E-M1X can now take a 50mp HiRes shot hand held. Using a tripod it can now produce 80mp images.
    • Totally Re-developed AF system with various AF target modes and settings and intelligent subject tracking
    • Live ND feature for slow shutter effects without external filter
    • Dust, splash, & freezeproof. Weatherproofing maintained even when connecting microphone, earphone or remote control cable
    • Integrated field sensors to add detailed metadata to pictures and video
    • Two UHS-II SD card slots for high speed responsiveness
    • Two batteries in innovative cartridge system and USB charging capabilities
    • Key “OM-D Movie” video capabilities: 4K and C4K, OM-Log400, Different levels of IS, 120 fps high-speed shooting in Full HD
    • Anti-flicker shooting capabilities
    • The sensor dust reduction system now features an improved Super Sonic Wave Filter (SSWF) with special coating which vibrates 30,000 times per second further reducing the possibility of dust or dirt ruining photos and equipment by factor 10
    • Capture up to 2,580 images before having to recharge. Featuring USB Power Delivery (USB-PD) from up to 100 W power sources, both batteries in the camera body can be fully charged in approximately two hours.
    • With locked AF, the E-M1X features high-speed sequential shooting at a maximum of 60 fps to capture split-second moments that the human eye cannot see. With AF/AE tracking, a maximum of 18 fps may be reached
    • A new Wi-Fi capture allows tethered shooting without a cable and makes it possible to transfer images wirelessly to a computer with the “Olympus Capture” camera control software.
  • @Vaterfreuden
    I just tell that few people inside feel and expect. It is extreme pessimism inside and among dealers.
  • You do Not know how the 1X sells. You do Not know how the other cameras this year will sell and the lenses.
    Do you recognize that you are Talking a Little bit weird?!
  • Olympus Corporation today released the following statement about the upcoming Olympus 100th Anniversary on October 12, 2019.
    We are sincerely grateful to all of our customers and stakeholders who have supported the Company’s development and progress since our founding 100 years ago. Going forward, Olympus will continue to contribute to society by making people’s lives healthier, safer and more fulfilling around the world.
    Takachiho Seisakusho, the precursor of Olympus, was founded in 1919 to produce microscopes for the Japanese market. Takeshi Yamashita, the founder of the Company, had a strong desire to create something truly original, believing that mere imitations of imported products would not suffice. In the following year, Yamashita’s dream of producing a domestic microscope was realized with the introduction of the Asahi — the first microscope manufactured by Takachiho. Thereafter, the same optical technologies developed for our microscopes and the Company’s focus on specialist needs, continued to be applied and infused into additional innovations, including the Company’s first camera — the Semi-Olympus I — and the world’s first practical gastrocamera, a precursor to the endoscope. This approach has carried Olympus through to the present day.
    Throughout our rich history, Olympus has been known for pioneering many “world’s first” products and providing innovative, advanced products and services in the medical, scientific solutions and imaging fields. As Olympus marks its 100th Anniversary, employees around the world will celebrate and reflect on the Company’s history, while also looking to the future as we move forward and continue to realize Our Purpose of “Making people’s lives healthier, safer and more fulfilling” as a forward-looking innovator.
    Our 100th Anniversary logo commemorates our historic milestone and embodies the Company’s determination to reach new heights. During this Olympus 100th Anniversary year, all Olympus employees will take part in a variety of activities, uniting us across the globe and contributing to the communities in which we live and work.
    I really hope they will still have camera division by this time, but chances are not big.
  • Interestingly the new 150 to 400 mm f4 lens is not going to be available until Q4, 2019.
    Since it seems to be a lens created for the "X" to a large degree (heavy and expensive) it's strange that the release is not concurrent to the camera.
  • @Bernie
    Target market is 10-25 people who had been only input in making this product.
    As soon as companies returned to all this ambassadors and such you can see fast degradation of progress and extremely strange management decisions. And this is consequence of such strange input. It worked more or less good in time of simple film based cameras, but now it is disaster.
  • Built in espresso maker? Its certainly big enough to have one. Who is the target market for this at the proposed price?
  • @Fahrenheit
    Finally we know why the price is such.
    I heard that you can also call Trump directly using it.
  • New FT5 rumor: It can control your neighbour's barbecue by wifi and launch guided missiles at Syria from US destroyers.
  • "Video specs are on par with the GH5s, autofocus equal to the Sony A9, best EVF in the industry!"
    One of our Asian Sources (Thanks!) sent us these three product images of the E-M1X. And for the first time we also got an info about the pricing. In Japan the E-M1X will cost 365,000 YEN. Rough conversion in dollar is $3350 or 2900 Euros. Keep in mind that usually the prices in USA are lower which makes it sound the final price might be $2999.
    My sources tell that all who saw camera had been badly surprised and that management had been told to lower price countless times, but all this price craze clouded their vision.
    Get my words, before September this will sell for $1999 for kit with lot of accessories and even gift card thrown in.
    It won't reach in the discount amount the Panasonic FF cameras, of course as this ones will be absolute champions.
    572 x 511 - 38K
    570 x 533 - 34K
  • Olympus teaser. Date:1/24/19
  • On the E-M1X launch day around Jan 20 Olympus will also announce the development of new MFT lenses. The only “production ready” lens will be the 150-400mm f/4.0 MFT lens
    43rumors
    Again, most of announcements will be just declaration, as management want to play safe and not invest to production for now.
  • Olympus is down. Their stock is under preforming and they need to trim the fat. Aside from that it's all about the GH2 baby. GH2 has the size and the raw that you want.
  • @Vitaliy_Kiselev If Olympus buys GoPro they can both use the GP2 LSI. ;-)
  • @EspenB
    And what are chances of alien invasion right after this camera will be complete flop?
  • So what are the chances for Olympus making an new LSI for possible future cameras after the "X".
  • Olympus did not even make any new LSI
    • 2x TruePic VIII processors making it just 2x the processing speed of the E-m1II
    Same cheap old one made using cheap process.
