See first post and post above.
Presumably taken down, among other things, because they haven't finished editing the copypasta from the E1 specs (from the PDF):
4096x2160 @24fps
3840x2160 @24fps/25fps/30fps
2880x2160 @24fps/25fps/30fps
1920x1920 @24fps/25fps/30fps
1920x1440 @24fps/25fps/30fps
1920x1080 @24fps/25fps/30fps
1920x1080 @50fps/60fps
1280x720 @50fps/60fps/240fps
840x480 @25fps/30fps
Video Encoder H.264 high profile
4K UHD bit rate 60Mbps
And yeah, for $34k, it had better be a whole lot nicer than the E1.
I like the price most.
All the specs here in pdf. The page is not on line anymore.
                  Mckinise
+1
And also, does it have modes for HDMI out before compression, and also before image adjustment (RAW like). Does it have high bit depth for HDMI out and 4:2:2? So, you can use a recorder like the Black Magic Video Assistant 4K.
Another question is if the recordings have high bit depth of 12-16 bit, hdr, 4:2:2, and rec2020 color gamut support?
These are important for good quality you can adjust if you shoot wrong.
Wowzers! If they make it sub $1K, and it works well, then this will take the budget high speed crown for sure!
Curious about HDMI output and dynamic range too!
Very good news!
1- What Resolutions and frame rates are available on this camera?
2- What is the maximum and minimum bit rate for each mode?
3- How many stops of dynamic range?
4- What is the HDMI output resolution?
