Driftwood ClusterX series 2:│moon│ЅріzZ│nebula│drewnet│Slipstream │Redshift
  • 1053 Replies sorted by
  • Graded w/ Colorista II and shot with Smooth -2 all.
  • Here's a documentary I shot for a non-profit organization. Gh2 w/moon t5 for the "A" camera and Canon t4i for the "B" camera.
  • DREWnet T9 setting -2 -2 -2 -2
    1024 x 768 - 78K
  • I would like to share my last video with GH2 and Drifwood´s Moon T5 setting:
    Thanks to @Driftwood for his excellent work with that setting. Lately I moved to ML RAW, but this video has changed my thoughs about RAW vs GH2...... I should check Moon T7, looks amazing.
  • Having same issues.. But off and on. Also random in-cam playback. (Even using the usual turn off, turn on, shoot short clip etc. tricks) Reluctantly switching back to Moon T5 as I had no complaints with it before T7.
    No complaints now either. If you wanna play...you've gotta pay. Can't image using the stock firmware HBR setting for...well....anything actually.
  • I've been shooting extensively with MoonT7 on paid gigs and plan to share some work soon. I like it, a lot. Only thing is I'm not spanning with my Sandisk 95/sec cards. Not a huge thing, just the first time that has happened to me. Seems a touch greener/yellower than T5, but I suppose I could be hallucinating since GH2 tints slightly that way, anyhow.
  • @producer
    I'm total AE newbie but I don't have any problems with opening my short test MTS files (24L mode, Slipstream #3) under AE CS6 Win. Hope this helps.
  • No, I don't use PP. Only Sony Vegas and Adobe AE for LUTs.
    Once when I use any of the HD video converters (just for a try), the files are accepted, but this is not the right way since the bitrate and quality decrease drastically.
  • Do you get the same in Adobe PP?
  • Has anyone experienced "Not Responding" message in After Effect right after opening SlepStream #3 video files?
    I think I saw similar topic, but couldn't find it again. There was described with a weird "waterwaving" line at the lower part of the videos.
    I tried processing the MTS files via Win ReWrap, then the same results - immediate crach of AE.
    Any help, please?
  • Just a fast handheld test with Slipstream #3:
  • @rorykane
    What frame rate and setting are you shooting at?
  • @rorykane
    Nice man, I really like the vintage finish to the blacks and color.
  • GH3 + GH2 / Slipstream #3
  • @pop24 just wondering which Cluster X version you used when shooting that "Trailer by Paul" video at the end of page 37? Looks excellent.
  • @driftwood
    Thanks. Slipstream didn't seem part of the new topic or mentioned therein so I was thinking you were maybe retiring it, or future development. I'd have loved to have shot this in a flavor of Moon (3 is my favorite but I'm going to shoot something in T7 soon to give it a whirl) or try out Intravenus II but Slipstream performed well for me. Many thanks.
  • Looks good @BurnetRhoades Its pleasing to know that Slipstream has its uses. More Slipstreams will appear on the other thread soon.
  • Last month, before getting a pair of cards fast enough to shoot with Moon Trial 3 (or any All-I patch), I shot a short for an actor friend that's appeared in practically everything my brother and I have made that required professional actors.
    I'd been happy shooting a series of spec commercials in Flow Motion but wasn't sure I wanted to do something narrative in that patch while needing to stay in that ballpark for bandwidth. I gave Slipstream a go. I shot everything on either my Nikkor f/2 24mm or Olympus F.Zuiko f/1.8 50mm and am grading with @shian ColorGHear.
    I was very pleased with the detail and almost Moon Trial like cleanness in the imagery from Slipstream. It was a very trying shoot as I had no AC, no lights or even someone who could half-way competently hold a reflector. The whole thing is 99% available light with only a few scenes making use of a small LED I couldn't use for the entire shoot because it sucks the batteries like mad.
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
  • @driftwood Thanks for the fast response.
  • ETC mode is problematic to this. Personally, I'm not a fan of it and never use it. Its got its uses but for me ...best to frame tighter with what lens you've got.
  • Shutter speed 50, ISO 200, old nikon 24mm 2.8 @ f5.6 i believe. WB on "cloudy". I was switching between normal and ETC mode to get different FOV, this was shot in ETC I believe.
  • @donniewagner Shutter speed / ISO ./ lens?
  • Having issue using Moon T5 (it may not be the patch at all though). I've read on a couple other threads about the noise and banding issue. I have a very intermittent issue with noise and banding. it show up occasionally, typically in darker areas of the image. But it is not consistent. I try to set exposure for the highlights so my histograms tends to be very shadow heavy. I have plenty of slightly underexposed footage that looks great, no problems. Long story short I've got two questions- 1) is this a) "the" normal banding issue people talk about or b) an f'd camera that needs replaced? 2) if the answer is a) , then where is the best source of info for workarounds to avoid triggering the banding while shooting.
    footage- https://www.dropbox.com/sh/4cwlme1d1mb39c7/SYjQpPGX09 lower right hand corner has massive banding and noise issue
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
