Longer Life Batteries:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390550880940&ssPageName=ADME:X:RTQ:US:1123
Those planning on purchasing the BMPCC might want to checkout this eBay listing, I have confirmed with the vendor that the batteries they are offering are rated at 1800mAh which is a big improvement on most other EN-EL20 batteries which appear to be only rated at 1080mAh.
I would also recommend you send them a message requesting confirmation of the power rating to cover yourself just in case.
I have no connection with the vendor other than having just ordered two sets of batteries from them.
I have to apologize guys, I just combed Brawley's blog again and can only find reference to the 14-42 x lens being SOL due to lacking manual focus capability (zoom rocker only, no manual focus ring or rocker). It's possible I confused this with disqualification due to power zoom feature. I could've sworn I read that somewhere official in my quest for info weeks ago, I'll post a source if it turns up (I hope it doesn't!).
ETA: From bmcuser forum NOIRIST 04-12-2013 02:23 PM "One of the Black Magic reps said that power zoom for MFT lenses is NOT supported."
@Brian202020 this is something I could well imagine, but for me this would not be any issue. As long as I can use the switches on the lens itself it would be perfectly OK to me.....
I remember hearing the power zooms weren't supported either. I beleive it was in an NAB video somewhere. He might have meant that the LANC port not controlling the zoom function tho.
@Tron where did you get the information from that the electronic zoom feature will not be supported? The only thing really needed is power supply from the BMPCC body, the 14-42X namely also perfectly works on an old GF1 camera. I do not know the M4/3 mount standard but as on most lenses the focus is also electronically controlled and thus requires power, I would not know why the power for the zoom function would be disabled..... can you please explain the issue into more detail? Thanks in advance......
The line in the eBay listing that put me off that lens was "There is some internal haze in the lens."
Apologies: I hope the one in the shop is in better condition than the one on eBay
Thanks @balazer! Good analysis, and saved me a few bucks. I'm not sure what you mean by "reflex" in terms of lenses, but I guess that's what Google is for.
Edit: http://en.wikipedia.org/wiki/Catadioptric -- wow, this is interesting stuff. Reminds me a little of reflector telescopes, with which I have a passing familiarity. That's one of the reasons I love P.V. -- always something new to learn!
Edit2: wrong reflex -- see below.
The Som-Berthiot Pan Cinor 17-85mm f/3.8 is a 16 mm lens, reflex possibly. It won't cover Super 16, and if it's reflex it means it would be hazy on a non-reflex camera except when stopped down.
As a rule, old cine lens are not Super 16 lenses. As a rule, zoom lenses don't cover a larger format than they're designed for, at least not for the full range of focal lengths and aperture settings.
I was looking today in a camera store (analog only!) and they had an interesting lens, which I think might work nicely with C-mount to m43 adaptor on the BMPCC.
It's the French Berthiot Pan 17-85mm zoom.
What's the consensus -- will this work with the BMPCC?
@johnbrawley Have you shot anything with the 20mm and the 14mm on the pocket cam and if so how do they compare to the 12-35mm?
Does DNG footage even exist yet for this....? ALL I have scene anywhere from anyone is ProRes and even in the videos of the cameras menus it seems the Raw is not accessible.
Would be nice to see the DR and how the footage holds up etc...
While I think he pocket cam footage looks good. I feel like the 12-35mm In a practical sense is perfect, wide, reasonable fast and brilliant stabilization. It's just I feel like that lens makes everything look like HDV video. the fact the PC footage looks good is in my opinion in spite of the lens not because of.
As a last resort I still might try to work around the problems of the Leica 14-50mm cause whenever I see footage with it, it shines. Is there a better stablized zoom? so far I haven't seen footage that convinces me.
