Something strange. I used Driftwood's GalaXian patch and recorded the MP4 video, which is failed ICP. Then, I downgraded the firmware with my lower bitrate setting (AVCHD high bitrate only). I can playback the same MP4 file (higher bitrate) in camera. It seems that something is linked to the playback mode by Ptool. BTW, the GalaXian patch is really impressive! Well done.:-D
Download latest firmware from panasonic. Download PTool v3.66d, load firmware, open Patches for end users -> Interface and check All Interface Languages. Save firmware and name it e.g. GX1___14.bin copy to SD card and update firmware normal way (power up camera, press Play button and confirm update). After update you will be able to change language to whatever you need...
Yes, of course.
@mjfeliciano here are the changes, also on the first post :)
and the downloads are here: https://www.personal-view.com/faqs/gh2-hack/ptool-software
Where can I find PTool v3.65d?, I'm still using v3.64d '200212'. What's new in v.3.66d beta?
http://www.personal-view.com/faqs
Plus we have few topics with beginners in the topic title.
Hi..i´m new at this forum..i have a G3 and did the firmwareupdate with mr JOFO ´S settings ,the camera did update but the version number still says 1.2..(i did download and install the latest panasonic firmware on the camera 1.2 about 4 weeks ago) how do i know that my new firmware that i named 1.3 is on my camera?..everything looks like it done before...
*** NEW *** Driftwood 'GalaXian'. 12/15 GOP
Here's the GX1 cluster variation provisionally entitled 'GalaXian' setting. Everything is souped up to Cluster v6 GH2 levels but set at 56M all round max, Q target is 18. You probably won't reach those dizzy heights. This features the Cluster v6 scaling matrix set on AVCHD modes. I don't think MP4 mode at level 66 baseline uses the scaling matrices as checked in ptools and Streameye Pro confirms this with matrices = n/a (not applicable) in the headers.
There is NO in-camera playback of MP4 modes at present but they look dramatically better than the stock recordings, AVCHD is unaffected and playsback.
Also features superior audio from @thepalalias at 'pasadenapulse.net'.
Test it out and see how you get on. Who knows, one day, we may get the in-camera playback resolved?! For now I continue testing...
UPDATE: In this release PAL works, NTSC may freeze and is being sorted in the next revision.
                  I meant official version :)
Still do not understand you.
PTool is publically available.
Of course, it is beta, as we need to figure out this MP4 stuff.
I have a suggestion. Just release it as a final patch
Sorry? What is "final patch" ?
Did you noticed words "public beta" ?
