PTool v3.66d public beta released
https://www.personal-view.com/faqs/gh2-hack/ptool-software
You'll need to download firmware from http://panasonic.jp/support/global/cs/dsc/download/fts/index2.html
StreamParser by Chris Brandin as help tool to analyse AVCHD streams - https://www.personal-view.com/faqs/gh2-hack/ptool-software
Other good idea is also use trial version of Elecard StremEye - http://www.elecard.com/en/download/products.html
Remember that Testers section patches are for testers. Use simple bitrate patches.
How can I make encoder hold better in low detailed scenes? Use Auto Quantizer patches.
How to update firmware:
How to provide reports in this topic?
8-999. Reserved.
Known Issues
GX1 has problems playing back MP4 files with increased bitrate.
More testing required to spot the cause.
I tested only PAL mode.
Case 1. Default bitrate for FSH/SH and 1080p MP4 worked fine. In-Camera-Playback (ICP) passed. Video Bitrate FSH/SH=16000000, Video Bitrate 1080p MP4=20000000
Case 2. Raising FSH/SH failed ICP for MP4 file. Video Bitrate FSH/SH=32000000, Video Bitrate 1080p MP4=20000000
Case 3. Raising MP4 bitrate failed ICP for MP4. Video Bitrate FSH/SH=16000000, Video Bitrate 1080p MP4=35000000
Case 4. No FSH/SH bitrate selected. Rasing MP4 passed ICP, but the overall bitrate remained only 20Mbps instead of 35Mbps. Video Bitrate 1080p MP4=35000000
That'll give some idea to those who want to test more to find more clues for VK.
This case is meaningless, as FSH patch is requires by any other bitrate patches. See tips in PTool.
It is also very very interesting.
I have a suggestion. Just release it as a final patch
Sorry? What is "final patch" ?
Did you noticed words "public beta" ?
I meant official version :)
Still do not understand you.
PTool is publically available.
Of course, it is beta, as we need to figure out this MP4 stuff.
*** NEW *** Driftwood 'GalaXian'. 12/15 GOP
Here's the GX1 cluster variation provisionally entitled 'GalaXian' setting. Everything is souped up to Cluster v6 GH2 levels but set at 56M all round max, Q target is 18. You probably won't reach those dizzy heights. This features the Cluster v6 scaling matrix set on AVCHD modes. I don't think MP4 mode at level 66 baseline uses the scaling matrices as checked in ptools and Streameye Pro confirms this with matrices = n/a (not applicable) in the headers.
There is NO in-camera playback of MP4 modes at present but they look dramatically better than the stock recordings, AVCHD is unaffected and playsback.
Also features superior audio from @thepalalias at 'pasadenapulse.net'.
Test it out and see how you get on. Who knows, one day, we may get the in-camera playback resolved?! For now I continue testing...
UPDATE: In this release PAL works, NTSC may freeze and is being sorted in the next revision.
                  Hi..i´m new at this forum..i have a G3 and did the firmwareupdate with mr JOFO ´S settings ,the camera did update but the version number still says 1.2..(i did download and install the latest panasonic firmware on the camera 1.2 about 4 weeks ago) how do i know that my new firmware that i named 1.3 is on my camera?..everything looks like it done before...
http://www.personal-view.com/faqs
Plus we have few topics with beginners in the topic title.
Where can I find PTool v3.65d?, I'm still using v3.64d '200212'. What's new in v.3.66d beta?
@mjfeliciano here are the changes, also on the first post :)
and the downloads are here: https://www.personal-view.com/faqs/gh2-hack/ptool-software
Yes, of course.
Download latest firmware from panasonic. Download PTool v3.66d, load firmware, open Patches for end users -> Interface and check All Interface Languages. Save firmware and name it e.g. GX1___14.bin copy to SD card and update firmware normal way (power up camera, press Play button and confirm update). After update you will be able to change language to whatever you need...
