Funkytown, HBR mode uses the same encoder settings as 1080i.
Jeffryalan, if you look at the PTool changelog you'll see that there are no GH2 changes in version 3.66d, so it doesn't matter which version you use. PTool 3.66d is not listed in the FAQ because it has only been released as a beta version. Forget the "simple instructions" and any references to the GH1. Just read the PTool FAQ and do what it says. It clearly indicates which camera firmware images can be modified. http://www.personal-view.com/faqs/ptool/ptool-faq There is no comprehensive hacks chart. Just look in the hacks section for the different topics. http://www.personal-view.com/talks/categories/hacks You'll find quite a number of GH2 hacks, some with ongoing development, and some beautifully refined and stable. Mixing and matching encoder settings can get quite tricky, as different settings are shared by different sets of modes, so it is not recommended that you attempt to do so.
Just back to PV after a long absence and looking for a place to begin again (though not a beginner).
•PT v3.66d? As this is the new PTool, should I use this for my GH2 hacks or stick with 3.65? Vitaly has set in 'BOLD' step #7 which is to read the faq's, yet v3.66 is not even listed (as of this post).
•Why is GH1 is still the name of the link for the firmware manipulation tool? (confusing)
•Why is the link to the firmware update download still unnecessarily convoluted?
•The "Simple "Instructions" still list GH1__V13.zip rather than a generic camera setting file which adds to uncertainty as to it's applicability to current camera models, wasn't that written months ago?
•The Hack Vault is three months stale even though there seems to be a plethora of ongoing hack settings, and all recent efforts seem to be towards the GX1 hack. Is there a comprehensive up to date hack chart that I am missing?
•Are there established procedures for mixing and matching settings that are widely accepted? Any other basic concerns for non newbie users that aren't on the faq page and should be?
p.s. thanks Vitaly for your instantaneous response, deleting my original post and sending me to the correct topic heading where I am sure all the experienced pro's in charge of administering and editing PV will be eager to explain the current entropic state of the Hacks topic and faq's and quickly answer all my queries!
cheers- J
I've been told to post here, so here it goes.
I've produced a new GF3 firmware with a hacked bitrate. I saved the file as GF3__V13.bin (it's GF3__V12.bin at the moment) into the root of the SD. When I power on and press the play button the update progress does not start.
Battery is full. Any ideas?
I cannot find the settings for 1080p25.
If you select AVCHD Compression, you only can find "Video Bitrate 24H", it meens 1080p24, not 1080p25. Therefore the HD GOP Length, you can only find "1080i50 and 1080p24 GOP Size". But where is the settings for 1080p25?
The default for 1080p25 is 24Mbit/s (firmware 1.1). The default for Video Bitrate 24H is 22Mbit/s, and for FSH/SH 16Mbit. What is my mistake in my head?
Thank you for helping.
A question about log and transfer into Final Cut for hacked footage. I've been looking for answers on this forum, but it's hard to find anything completely clear.
I'm using FCP 7.0.3 and shooting with @cbrandin's 44M/32M AQ4. Is the best way to work with the footage in FCP to transcode to ProRes 422 using Clipwrap?
I've seen some people say that FCP recognizes their hacked .mts footage, but this doesn't happen for me. Before I hacked the camera, I could log and transfer in FCP with no problem.
I prefer to keep using Final Cut. What do others in the same position do?
Can someone help me clarify...
This is my understanding, is it correct?
Driftwood Cluster v6/Drewnet Thread... - These patches are a balance of reliable spanning ability, bitrate vs quality (smaller filesizes, a bit less quality)
Driftwood Canis Majoris - The quest for the ultimate highest quality reliable recording (95mb cards only, no spanning)
Timebuster - Best for high quality time lapse
Flowmotion - Another attempt for balance of reliable spanning ability, bitrate vs quality (smaller filesizes, a bit less quality)
Am I missing any major patches or releases? or am I behind the times on the status of any of these? I think a lot of people have the same questions and if someone who is familiar with this can update the faq or post here, i think it will be really useful!
krotal, I don't understand your question. You say that the footage looks fine with 5DtoRGB, which means the hack is doing what you want. There shouldn't be any reason that you can't grade that footage. If the problem appears after using After Effects, then it is an After Effects problem, and nothing to do with hacking.
palmiuga, try menu, setup, reset. If that doesn't fix it, I'd guess you have a defective camera.
Sorry if this is not the place... However I've googled and searched all over in hopes of discovering the supported resolution modes under the iA setting and have come up empty. Q: Is there a method of enabling HBR (1080 30p) recording in the iA mode? All I'm getting is some gawd awful 1080i and I gotta believe there is a way to enable 1080p... BTW:720p works as expected.
Hi guys, I need your advices on a problem : I'm currently using the stock firmware on a project, but I'm disappointed by crazy banding (after "heavy" grading) on dark out of focus parts. I noticed that the banding issue only appears after AE H264 compression, no problem with the original 5DtoRGB footage, so the problem may come from my compression settings... ( H264, High Profile, VBR 1pass, 5.1, 24mb/s) If not, is there a patch that allows better grading capabilities ? In-cam playback is an important feature I would like to have.
Thanks
@SilverPepper There are different opinions regarding your question. I'm assuming, like alcomposer, that you're asking about "film modes". I would also add that Standard and Vibrant (and Cinema) are legitimate choices as well. I stay away from Nostaligc except in circumstances when I want the specialized look it provides.
Also, @cbrandin has a particularly insightful breakdown of some things related to filmmodes related to the gh2 from this thread: http://personal-view.com/talks/discussion/737/gh2-hack-myths-and-realities#Item_45
Here's the relevant passage, which I'm quoting:
"Setting noise reduction in the camera is bad. Not necessarily true. If you are shooting at high ISO’s more noise will be produced. The codec has to work hard reproducing this noise, and you’ll end up just crushing the blacks or doing noise reduction in post anyway. Applying some noise reduction in camera under these circumstances can be very helpful because the NR is applied before video is encoded and you are not consuming codec bandwidth reproducing noise.
The camera should always be set with Contrast at -2. Not true, the camera’s contrast should be set so the histogram shows the entire range being used. If you always set Contrast to -2 low contrast scenes will have poor gradations because you have set the dynamic range artificially low thus limiting the number of bits being used for the image.
In camera saturation should always be set to -2. Not true, for the same reason given above.
In camera sharpness should always be set to -2. Absolutely correct! Sharpening produces fake detail which the codec will have to work hard to encode. Sharpening is always done better in post."
I think Chris is right about all of this (the point about noise reduction in particular is way overlooked in my view). In the end, though, it's going to be your personal tastes that dictate what you use. Happy shooting!!!
Thanks @alcomposer for the quick reply!
There are many long, (and detailed) threads on P-V regarding movie settings. Suffice to say that 2 have become popular:
Nostalgic - high dynamic range (more detail in shadows, but also a bit yellow and will need some grading)
Smooth - does the job and looks good.
Mostly I try to use -2,-2,-2,-2 for everything on both settings (that is for saturation etc settings)- however you may find that different subjects work better with different levels.
What i have found is that -2 for de-noise is very important- as the noise grain will be finer with it at -2 and look less like cotton wool.
However it is totally up to you!
I have a question!
First, thank you so much for the hack and patches -- great work!
I just installed the mpgxsvcd "all stable" patch with the hack and am wondering what movie settings I should use.
Thank you!
What ss should we use in VMM 80% (uses 24p settings but records in 30fps)? should it be multiple of 24 (so ss 25-50-100 etc) or of 30 (ss 30-60-125 etc.)?
@gong HBR only became available in firmware 1.1 with it's access to 25p. But when you apply the hack to the camera it will be applyed to all shooting modes. If you need to confirm if any footage that you have shot has "hacked compression" take a look at the file analysis in Streamparser which can be downloaded here..
http://personal-view.com/talks/discussion/370/official-streamparser-topic/p1
is anyone here using 720p straight out of the camera in premiere? I'm having a real problem with it: its as if premiere thinks the footage is 25fps - the video is playing back at half speed, the sound at normal speed. VLC is saying the footage is 50fps but mediainfo (from super) is reporting 25fps.
Always something new to find about my GH2. I am flying my GH2 on a Hexakopter, and have set up a video downlink which uses the AV output (not HDMI) of the GH2, so you can see the POV of the camera while flying. I was very frustrated that I could see still images when playing back, but wasn't getting a video signal while recording. Finally, I found the trick: sometimes, you have to press and hold the Delete button on the back of the GH2 to switch on the AV out (the signal comes out of the USB-type connector.)
I added this to the FAQ. Anyone else come across this trick?
Hacking your camera won't change which video modes are available in the camera's menus. If you're not seeing progressive modes, then something is wrong, and you should do menu, setup, reset. Set the top dial to creative movie mode, and then select 24P Cinema or HBR mode. They are both progressive. There is little reason to shoot in 1080i on the GH2, though you have that option. FAQs answer all: http://www.personal-view.com/faqs/
