Sanity 4.1 and 5 are totally reliable for spanning in 24L if you use Sandisk Extreme HD Video 30MB/s cards. I can't speak for other cards. mo7ies has obviously had good success with SanDisk 64GB SDXC Memory Card Extreme Pro Class 10 UHS-I.
But in the broader picture, cards are a variable we can't control. One person reports success with a given card, another reports problems with the same card. Is there variablility in the manufacturing of these cards? Possibly. Did the person inadvertently buy a counterfeit card? Possibly. We don't know and may never know. All we can do is plow on and find something that works for us.
@mo7ies Yes, SanDisk 45MB/s Extreme edition (the good one with 46MB/s measured speed, not Extreme Pro) is not reliable for spanning. Out of 4 times, two times it did not span in 24L mode when using Sanity 4.1.
@Ralph_B I suppose that Sanity 5 is not more reliable than Sanity 4.1 in 24L mode?
Do 64GB 95MB/s cards have some problems in a sense that you have to make one short clip before switching the camera off? If yes, it might be a problem for me, since I will forget to do that in more than 50% of the cases.
I have this USB 3.0 Reader: http://goo.gl/Umsyf
Yes, these particular 64Gb cards are wonderful. I use them almost every day here, zero issues so far. Flawless spanning with Sanity v5 (except for the 1080p30 mode). 1080p24H, no problem - spans forever! Also, affords very fast transfer times, and works great with USB 3.0 readers - which some cards don't play well with, notably Lexar and some Transcends.
@RandyCatanach "I was surprised how well the GH2 with Sanity 5 was able to handle the low light conditions with such clean noise!"
That was one of my goals!
Yeah that was intentional. I probably shoulda mentioned that! I've noticed it does show up as a stronger blue on some monitors and lighter on others. Not sure how it looked on your monitor but I definitely like how it looks on mine lol. I like to use skate vids of friends to just try out different little things like that. I felt it added to the feeling of the carnival at night. Maybe I won't go so intense next time....haha
Anyway, I decided to post it here though because I was surprised how well the GH2 with Sanity 5 was able to handle the low light conditions with such clean noise!
Shot this in HBR mode with Sanity 5. Very satisfied with the results! Canon FD 28mm 2.8 and 50mm 1.4; Vivitar 35mm 2.8; Peleng 8mm
From what I researched... just because the card says Class 10, it won't sustain the recording bandwidth required to span some hacks. Specifically, Transcend and Lexar do not seem to be very good for our particular purpose, which is spanning on GH2. Further, most SanDisk cards won't safely span either, even when they say 45MB/s. The only card I found so far that absolutely safely spans in 24H (and in 720p60) in Sanity v5 is this: http://goo.gl/gbQf4
I used to own this Zeiss 100mm Makro lens (Nikon version), which is considered one of the best: http://goo.gl/uSThT The lens was OK. However, I disliked ugly coma it produced on night lights, so I sold it. Maybe CP.2 video lenses by Zeiss are better, I don't know.
