Everything works fine. What do you think? any advice? Settings:
SD_Card=10 Camera=GH2 v1.0E [Settings] Version increment=1 30min limit removal=Checked PAL<->NTSC Menu=Checked Video Bitrate 24H=60000000 Video Bitrate 24L=42000000 1080i50 and 1080p24 GOP Size=12 Video Bitrate 24H ADD=60000000 Overall Bitrate=60000000 Overall Bitrate 2=60000000 Video buffer 24p=0x3600000 1080p24 High Top Setting=42418 1080p24 High Bottom Setting=29692 1080p24 Low Top Setting=31178 1080p24 Low Bottom Setting=21824
@swen24, sorry I'm no stream expert, and I'm no longer testing.
To finish what I started though, you _can_ use the original bitrate and a higher rate in the same firmware. The trick is to use the original 'bottom' bitrate. This works for me:
24H = 42mbp 24L = 22mpbs (original 24H):
Video Bitrate 24H=42000000 Video Bitrate 24L=22000000 1080p24 Low Bottom Setting=10912
The 24L stream shows the typical 1s low bitrate, but otherwise works fine. Have fun.
I now have a GH2vk. Did first try and set conservative figures du to the capability of my post produktion equipment. 24H was set to 28 mbits 24L to 22 mbits. FSH and FH to 28 mbits and 22mbits. 24H works OK with an average bitrate of 28,3. 24L got very low bitrate. I went into patches for testers and just marked 24 Low Bottom setting without any other change. The average bitrate went up to 15,4 mbits, still low in comparisson. Same images, grass and water shot from tripod. FSH and FS got average bitrates of 28,8 and 22,8 respectivly. So something still need to be changed for 24L.
Small P-frames will occur in static scenes where few details change between the previous I-frame and subsequent P and B-frames. In these cases, since backward prediction is not really needed, P-frames can be encoded as efficiently as B-frames.
does it make sense to have such small p frames? maybe its possible to have only i and b frames by playing with encoder setting (1), if this is allowed in avchd restrictions? i mean for long gop, not for short gop of 3, like i saw in another thread
Screen info while in recording mode shows "EX" when enabled. For examples, LVF/LCD screen shows "EX SH" or "EX FSH" for movies and "EX M" or "EX L" for pictures.
The "EX" is not shown in playback mode.
Other oddness...
When ExTele is enabled, image in viewfinder is zoomed (of course). But when recording FSH/SH, the image quality displayed in LVF/LCD is strange. Specifically, image is blurry, not focused. When movie recording begins, then focus achieved on LVF/LCD. Makes manual focus difficult.
Also, even though picture can be taken with ExTele enabled, the picture recorded is not "zoomed."
@Vitaliy_Kiselev *correction*, the original 24LBottom value also works if I tick the patch. What bottom bitrate does the simple patch actually set for 30mpbs?
original 1080p24 Low Bottom = 10912 = multiple of 32 (x 341) = OK if patch is ticked. 10944 (32 x 342, 100.3%) = OK 11040 (32 x 345, 101.2%) = OK 11200 (32 x 350, 102.6%) = OK.
I shot two 24L clips (same content) at 32mbps - the 1st takes _4_ seconds to stabilize (usually only 1). The second is visually perfect from the start. So this seems to depend on the exact encoding needs of the early frames.
Have not been able to crash Ex-Tele on same high-detail shot with 32 or 42mbps & lots of movement. Seems stable.
@_gl I dont think they have camera requirements. Earlier today a high speed chase ended by the station with no live trucks so I ran out there shot b-roll and they used it for broadcast.
I'll repeat this here as this is important. Always keep lower bitrate settings within 95-70% of high bitrate settings. Otherwise you'llsee dramatic bitrate drop in this low modes.
@GOODEMPIRE, for each mode you want to change, you must tick the higher-bitrate patch, and it must always be a higher bit-rate than the lower bitrate version (this is a limitation of the firmware). If it still doesn't work, save your settings to a slot (hold SHIFT and click the A button at the bottom), open the seta.ini (in the Ptools directory) file in a text editor, and paste the [Settings] section here.
@stonebat what are you worried about, all that complicated stuff are thinking about you DONT NEED to stress about. Yes its safe for "noobs" but don't call yourself a noob, call yourself lazy. Its literally going to take 4minutes to do this if you just want to see bitrate increases and enjoy the patch... here is your noob version of instructions but imo vitality's are as direct as it needs to be.. you over complicate this. read now how simple it is and understand that you are only checking 4 VERY SAFE and stable patches. you cant brick it, i promise. what you are worrying about is like saying i don't get how combustion works so no way am i putting gas in my car until i do. Who cares, if you can dive then put the gas in and vroom! seriously.
Noob Version / fool proof. 1.is your battery fully charged? ok mount camera on your pc. (use the provided cable) 2, Run Ptools and load the firmware GH2 1.0E that you downloaded (looks like GH2__V10 after unziping) 3. Now you have options... just check the first box for version increment and then under Patches for end users ... click on avchd compression and from that drop down check all of 4 options there while your at it. when you highlight each option it literally pops up and tells you type in this number instead of current number. it tells... you.. what to type in. type in that number for each of these 4 options. 4.SAVE firmware. use same file name as original except change the last digit to anything else. 5.Drag or copy and paste or w.e you want, you're new firmware that you made over to camera's card patiently waiting for you grow some balls, now unplug and restart that camera once its on the card. 6. Once camera is back on, wait a second and push play/preview button. it asks you, would you like to update? hit yes!! DO NOT touch anything or mess with camera during update, that's the only danger... so press update and watch don't touch and guess what? Hardly a minute later you're set
Total time you've spent thinking about it and not offering your camera steroids? a shameful long time. poor GH2. people need to stop worrying, education is a good cure for fear and you sir know whats up... with no excuse. ENJOY!!
These were our 10 o'clock news topicals. The first 2 are shot with GH2 42mbps and the other 2 are shot with an EX1. The GH2 looks fantastic for broadcast. Password is cbs13.
I am using the recommended values for 24H and 24L but as you can see below I'm getting really low bit rates. 720p works great and I used it all day today while playing golf at Lake Tahoe. Would greatly appreciate some help as to why 1080p/24 is returning such low bit rates. The video I have shot in that mode has horrible blocking.
Finally tried the plasma plate test that I did at 24p, but this time at 60i (FSH) It did indeed make my camera go poop! I am gonna try 32mb settings like others have suggested.
UPDATE: FSH and 32mb settings are working just fine! No crashy crashy.
