@mpgxsvcd "As I expected you have lots of other settings(AVC-HD overall bit rate, encoder settings...etc) configured. Just set the Video Bit rate FSH/SH and 24p to 32000000. Don't change anything else and it won't fail. Your settings are what is breaking the video."
Odd.
The only settings I changed were the 4 end-user AVCHD Compression settings, using suggested values (FSH/SH & 24H = 42mb and FH/H & 24L = 35mb). Perhaps I sent the wrong INI file.
FWIW - Your suggested value of 32mb for FSH/SH and 24H is lower than Hint Suggestion of 42mb.
I retested changing only FSH/SH & 24H with 32mb and that worked fine. Specifically, I could not get FSH crash.
> Never do it. Bitrate for higher mode must be always larger (at least 4Mb).
Now you tell me ; ). That's a day's outdoor test footage wasted. Can the settings be made independent eventually?
I want to be able to shoot unmodified 24H and 42mbps without reflashing, so I can shoot the same footage with both settings. So if I set 24H to 42mbps and 24L to 22mpbs, will 24L look exactly like unmodified 24H?
@Angry_C "there´s much unsharpness in your screenshots, that decrease the detail level. Use f-stop 11 with the pancake and it would crash in FSH (1080i) mode I think. Or record grass on the ground with exact focus. "
I tested this an confirmed crash behavior in FSH.
Parameters: FSH (with suggested hack settings), SanDisk Class 10 (30MB/s), manual focus, F11, filming grass. I started recording with the grass completely out of focus (blobs of green). Then brought the grass into sharp focus and panned camera. Crash occurred very soon after sharp focus requiring removal of the battery. If picture remained blurry, FSH crash did not occur.
I did not experience this crash behavior with 24H, 24p80% or SH recording (suggested hack settings), SanDisk Class 10 (30MB/s), manual focus, F11, filming grass.
A suggestion, keep the high-bitrate settings unmodified, and only change the low ones. Then you can shoot the same footage with the original and modified settings to compare without having to reflash (also useful if you need to get a shot on location and the modified setting screws up).
I know you are right for most studios. However, I still disagree. Lot's of scenes in Storm Chasers is shot with Sony or Panasonic hand held camcorders. If your content is compelling enough then they will accept it.
If you showed up to Discovery channels door step with a season’s worth of footage shot with a GH2 from inside tornadoes you would probably have your own show as well.
After looking at the requirements it looks like if you shot it in 1080i/60 with the GH2 you would be fine. I don't see any restrictions for bit rate, 4:2:2, or codec listed on that page.
@Mimirsan I see a huge difference in the lower mid section of grass between the 1st and 3rd pics in regards to pixelation. Then again I'm making a comparison between progressive and interlaced. Do you have any before-and-after screen captures (with and without the 32mbps hack)?
I applied the patch and so far no issues on testing 24p native and in wrapper. Also 720 @ 60p. I did a 3.3 gig file over 10+ minutes at the 42,000,000 mbits/sec and that seemed to work. Haven't needed to test the 35,000,000 rate as the 42,000,000 has worked.
Question, I'm thinking of testing a 20-40 minute record time with high bit rate. Any issues/concerns for overheating? Will the camera shut itself down if heat gets too much ? Is this a reckless thing to try at this stage?
@mpgxsvcd 420 and bitrate stops it from being broadcast. it can be used as a b cam if small amount of footage is used, but no major channel will commission anything intended to be shot on 420, and low bitrate.
if you want a better idea of the tech specs, check here. they are always subjective to the commissioning editor, who has the last word, but it's a good start http://dhd.discovery.com/guidelines/guidelines.html
