Official Low GOP topic, series 4
  • 586 Replies sorted by
  • It seems that lpowell is trying to steal some thunder from my Cake with his Flow Motion. ;)
    At first glance it looks like Flow Motion has a quality advantage if you don't care about spanning. If you care about spanning, Cake should win for quality and efficiency.
    But I need people to test it and let me know if it works!
  • @balazer:
    What are the essential parameters that make this patch set so much VBR?
    What other parameters did you have to watch for it not to break?
    I'm trying to make a patch set (for totally different footage characteristics) for which I believe this VBR approach is the way to go and I'm trying to learn how to tackle it.
  • @duartix, to achieve constant quality in my Cake patch settings, I set the bit rate and the frame limits high, and set a quantization parameter to control the quality level. I copied Driftwood's Quantum Beta 8, which apparently has some other setting in it necessary to make a static quantization parameter work.
  • @JDN The one on dvx is more recent. I want to set the standard to your test, so that it works for you 100% of the time.
  • Quantum X - the all i frame patch is coming...
  • @Driftwood Cheers Nick.
    Reading @balazer last comment, what do you reckon is the magic parameter setting that makes a static quantization work? I'd kill for something as simple as this:
    875 x 709 - 103K
  • @driftwood Have you gotten the i frames higher on 50/60? (~280?) If so, count me in
  • Will Quantum X work with panny lenses... a conformations would be great all i need is 24H
  • Well I started the feature on Aquamotion v2 and for consistency will continue to shoot that patch... but next film--- which is a shorter film (1 weekend shoot). I think I am going try out Quantum X...
    *In Driftwood I trust!
  • @artiswar which patch did u test in those screen caps? 9b?
  • @shian - That is 9b.
  • @artiswar, glad your liking the lomos ;)
  • I had a chance to test my constant quality VBR "Cake" settings against some other settings on some different scenes at different ISOs. In my humble opinion, Cake easily beats SpanMyBitchUp (66 Mbps intra) and Quantum 50 (Intra), and equals Aquamotion (88 Mbps intra), while averaging less than half the bit rate. Flow Motion L50 beats Cake for a static highly detailed scene at ISO 200, but Cake wins at ISO 400 and higher or when there is motion. At ISO 400 and up or when there is motion, Flow Motion L50 doesn't manage to keep the frames as close in quality to each other as Cake does.
    Personally, I'm not interested in any settings that don't span, so I didn't test Flow Motion H100. I suppose if you don't care about spanning and you don't mind such high bit rates, you're probably better off with 146-Mbps intra.
    I'm really excited about the quality I'm seeing from Cake. I wish some people would try it out!
    1151 x 771 - 350K
  • Its a nice patch @balazer.
  • Haven't tried "Cake", but seems like a great patch...well done balazer.
    @driftwood, could you be dropping a bomb soon sir? Your reticence has got me excited. Love this bloody place...
  • @balazer: You forgot to set "All Languages". Encoder setting 1 720p is checked but has default value. I'll give it a try tomorrow.
  • Quantum X - damn that even sounds good...
  • @Balazer, just tryid your patch. Sadly enough in 720 SH and H mode in tele there is a speed limit on the sandisk extreem hd video 32gb 30mb/s. when go higher then iso160
    This is the first patch that dose save the recorded file, in other patches a get a 0mb clip
    In 24p and 50i mode it runs great. even with tele-converter
    *File size : 43.8 MiB
    Duration : 17s 833ms
    Overall bit rate mode : Variable
    Overall bit rate : 20.6 Mbps
    Maximum Overall bit rate : 184 Mbps
    *File size : 211 MiB
    Duration : 46s 972ms
    Overall bit rate : 37.7 Mbps
    - I love the image it gives
    In 720p 50 fps with tele2 and the error speed limit give me this file
    File size : 125 MiB
    Duration : 13s 721ms
    Overall bit rate : 76.2 Mbps
    Maximum Overall bit rate : 100 Mbps
    1e screenshot from vlc player (raw mts file 720p, 50fps, iso, 160 color neutral, white ballans-daylight)
    2e screenshot from vlc player (raw mts file 720p, 50fps, iso, 320 color neutral, white ballans-daylight) done with tele2 ad max = 300mm
    4e screenshot from vlc player (raw mts file 1080, 50fps, 24p iso, 160 color neutra, white ballans-daylightl)
    Screenshot 3 is a bad jpg compression i uploaded the 4e in a png screengrap from vlc-player
    I did not have permision to delete the 3e image.
    1280 x 720 - 48K
    1280 x 720 - 52K
    1920 x 1080 - 55K
    1920 x 1080 - 2M
  • @Balazer
    Tried your patch:
    • No writing issue (Samsung 16GB class 10)
    • No ex-tele issue
    • Quality => very good
    The only mode I use is 1080i50 (de-interlaced in post-production), I'm a slow-motion addict :-)
    No idea about 1080p/720p.
    Thanks a lot for "Cake",
  • @mozes: When uploading JPG please make sure you have saved them at maximum quality. All your samples are suffering from heavy compression, there's blocking, ringing, the whole enchilada. I'd almost go as far as suggesting to post PNG only.
    There is no conclusion to draw from these samples until you update with proper captures.
    @Vitaliy_Kiselev : Is there a reason why we can't delete attached files? Every time I try to delete one of my attachments, I get a confirmation overlay and when I press "Okay" I always get this: {"Code":401,"Exception":"You don't have permission to do that."}
  • you are right, i wanted to upload the good png screens, but then the post gets such a chaos, thats why only updated that 1 image.
    I will upload a 720p 50fps, a 10801 and 1080 24p clip, strate out off the gh2.
    I really like this patch, just that it doesn't record in 720 tele is for me a slight hold back, because i use it 25% off the time.
    quick question, can i use driftwoods Quantum v9 720 settings in this patch? mmm well i go try it ;-)
  • Cake test 24p @ISO3200 & Panasonic 14-42mm.
    Very reactive bitrate. :)
    Amazing quality and detail. Great grainy shadows. No blocks. Absolutely no noticeable difference between I/P frames in my eyes.
    The boring stuff:
    Stream: TS Max Speed = 187.656.100 bps
    Mode = 1080/24p
    Average PCR Timing Interval = 0,094 seconds
    Clip Duration = 0:00:44,42
    PCR Duration = 0:00:44,43
    Average Total Bitrate = 59.368.189
    Average Video Bitrate = 57.509.756
    Average Audio Bitrate = 235.155
    Average Other Bitrate = 1.623.277
    Max GOP Size = 1.124.352 Bytes (8.994.816 bits)
    Video Frame Size (Min/Ave/Max)= 169.728 / 305.899 / 408.960
    No speed issues on Samsung Class 10 Pro 16GB.
  • 720 50fps uploaded the orginal mts CAKE file to youtube.
    the 50i and 24p file are uploading to
    its 1.47gb it will take some time when i will poat the links
  • @ Silent users of my patches :-)
    This is the patch focused on image quality which referred to advice of Chris Brandin and Nick Driftwood, and was made.
    Special thanks to @cbrandin and @driftwood!
    NOTE: *24L mode is for 24p80%(30p). *Except 1080/24p, it is completely the same as my usual, and they are the contents of Chris's 66M. Of course, you can combine with a favorite patch except 24p and 50i. *In camera playback is available. *Spanning in 24H and 24L with SanDisk 95MB/s 64GB SDXC Card.
    bkmcwd New
    1297 x 634 - 187K
    1620 x 862 - 209K
    1296 x 632 - 188K
    1298 x 736 - 171K
  • @bkmcwd Nice work. I reccommend this excellent patch combining great picture size, good estimated psnr (signal to noise ratio), and good quantisation. Plus, great rate control - PCR duration matches Clip duration - which slightly helps!!! This is 'thee' de facto best GOP3 patch around.
