I did playing some more with the @Balazer Cake patch.
i replaced the 720p settings with the driftwoods Quantum v9 720 settings.
Meaning, i change the Video Bitrate FSH/SH to 80000000
enabeld the Auto Quantizer for 720 modes=3 - Most to details
Set the 720p50 GOP Size=3
And the 50fps Frame Limit=1687144
Anything else is not changed.
Tele convertor now works in 720p mode without the error report.
@Balazer My question is, is this oké, or must i change something more?
I will play some more with this patch, if it doesn't rain this weekend, i can take some serious shots..
@rikyxxx, "Cake" is for 24p and Variable Movie Mode. I haven't touched the 1080i and 720p settings. Thanks for testing.
Yes
@Sage - Is correct I hope? Haha.
@artiswar 'The jittery and somewhat amorphous "consistency" of higher GOP' -This
Further testing on "Cake" patch & 1080i50: I'm sorry to report you that it doesn't span with ex-tele tuned on, although it spans perfectly with ex-tele turned off.
Riccardo
@csync - It's very subtle but noticeable. At least to me. GOP1 produces a very solid picture. And I mean to use solid in it's most basic meaning. The jittery and somewhat amorphous "consistency" of higher GOP is virtually eliminated. Or at least that's what I see. GOP3 is just slightly smearier.
Any brief summary of visual differences in GOP3 vs GOP1? (other than the obvious technical differences)
I need to shoot an interview in 1080 50i so should i use quantum100 or quantum50 for best stability? Are they both stable in 50i mode?
@driftwood Thanks Nick! :-) Since this is the patch also with same having made together with you, I am glad if I get you to say so. Thanks again.
@Butt Thanks mate. ;-)
@bkmcwd awesome GOP 3 Patch: thank you
@driftwood, When do you plan on releasing Quantum X ? I'm definitely excited to try Quantum for the first time, been using seaquake until now. Thanks for all your hard work.
@bkmcwd Nice work. I reccommend this excellent patch combining great picture size, good estimated psnr (signal to noise ratio), and good quantisation. Plus, great rate control - PCR duration matches Clip duration - which slightly helps!!! This is 'thee' de facto best GOP3 patch around.
@ Silent users of my patches :-)
This is the patch focused on image quality which referred to advice of Chris Brandin and Nick Driftwood, and was made.
Special thanks to @cbrandin and @driftwood!
NOTE: *24L mode is for 24p80%(30p). *Except 1080/24p, it is completely the same as my usual, and they are the contents of Chris's 66M. Of course, you can combine with a favorite patch except 24p and 50i. *In camera playback is available. *Spanning in 24H and 24L with SanDisk 95MB/s 64GB SDXC Card.
UPDATE(2012.Feb.3rd): http://www.personal-view.com/talks/discussion/comment/39577#Comment_39577
                  720 50fps uploaded the orginal mts CAKE file to youtube.
the 50i and 24p file are uploading to https://www.wetransfer.com/
its 1.47gb it will take some time when i will poat the links
Cake test 24p @ISO3200 & Panasonic 14-42mm.
Very reactive bitrate. :)
Amazing quality and detail. Great grainy shadows. No blocks. Absolutely no noticeable difference between I/P frames in my eyes.
The boring stuff:
Stream: TS Max Speed = 187.656.100 bps
Mode = 1080/24p
Average PCR Timing Interval = 0,094 seconds
Clip Duration = 0:00:44,42
PCR Duration = 0:00:44,43
Average Total Bitrate = 59.368.189
Average Video Bitrate = 57.509.756
Average Audio Bitrate = 235.155
Average Other Bitrate = 1.623.277
Max GOP Size = 1.124.352 Bytes (8.994.816 bits)
Video Frame Size (Min/Ave/Max)= 169.728 / 305.899 / 408.960
No speed issues on Samsung Class 10 Pro 16GB.
you are right, i wanted to upload the good png screens, but then the post gets such a chaos, thats why only updated that 1 image.
I will upload a 720p 50fps, a 10801 and 1080 24p clip, strate out off the gh2.
I really like this patch, just that it doesn't record in 720 tele is for me a slight hold back, because i use it 25% off the time.
quick question, can i use driftwoods Quantum v9 720 settings in this patch? mmm well i go try it ;-)
@mozes: When uploading JPG please make sure you have saved them at maximum quality. All your samples are suffering from heavy compression, there's blocking, ringing, the whole enchilada. I'd almost go as far as suggesting to post PNG only.
There is no conclusion to draw from these samples until you update with proper captures.
@Vitaliy_Kiselev : Is there a reason why we can't delete attached files? Every time I try to delete one of my attachments, I get a confirmation overlay and when I press "Okay" I always get this: {"Code":401,"Exception":"You don't have permission to do that."}
Tried your patch:
The only mode I use is 1080i50 (de-interlaced in post-production), I'm a slow-motion addict :-)
No idea about 1080p/720p.
Thanks a lot for "Cake",
Riccardo
@Balazer, just tryid your patch.
Sadly enough in 720 SH and H mode in tele there is a speed limit on the sandisk extreem hd video 32gb 30mb/s. when go higher then iso160
BUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This is the first patch that dose save the recorded file, in other patches a get a 0mb clip
In 24p and 50i mode it runs great. even with tele-converter
*File size                        : 43.8 MiB
Duration                         : 17s 833ms
Overall bit rate mode            : Variable
Overall bit rate                 : 20.6 Mbps
Maximum Overall bit rate         : 184 Mbps
*File size                        : 211 MiB
Duration                         : 46s 972ms
Overall bit rate                 : 37.7 Mbps
- I love the image it gives
In 720p 50 fps with tele2 and the error speed limit give me this file
File size                        : 125 MiB
Duration                         : 13s 721ms
Overall bit rate                 : 76.2 Mbps
Maximum Overall bit rate         : 100 Mbps
1e screenshot from vlc player (raw mts file 720p, 50fps, iso, 160 color neutral, white ballans-daylight)
2e screenshot from vlc player (raw mts file 720p, 50fps, iso, 320 color neutral, white ballans-daylight) done with tele2 ad max = 300mm
4e screenshot from vlc player (raw mts file 1080, 50fps, 24p iso, 160 color neutra, white ballans-daylightl)
Screenshot 3 is a bad jpg compression i uploaded the 4e in a png screengrap from vlc-player
I did not have permision to delete the 3e image.
Quantum X - damn that even sounds good...
@balazer: You forgot to set "All Languages". Encoder setting 1 720p is checked but has default value. I'll give it a try tomorrow.
Haven't tried "Cake", but seems like a great patch...well done balazer.
@driftwood, could you be dropping a bomb soon sir? Your reticence has got me excited. Love this bloody place...
Its a nice patch @balazer.
I had a chance to test my constant quality VBR "Cake" settings against some other settings on some different scenes at different ISOs. In my humble opinion, Cake easily beats SpanMyBitchUp (66 Mbps intra) and Quantum 50 (Intra), and equals Aquamotion (88 Mbps intra), while averaging less than half the bit rate. Flow Motion L50 beats Cake for a static highly detailed scene at ISO 200, but Cake wins at ISO 400 and higher or when there is motion. At ISO 400 and up or when there is motion, Flow Motion L50 doesn't manage to keep the frames as close in quality to each other as Cake does.
Personally, I'm not interested in any settings that don't span, so I didn't test Flow Motion H100. I suppose if you don't care about spanning and you don't mind such high bit rates, you're probably better off with 146-Mbps intra.
I'm really excited about the quality I'm seeing from Cake. I wish some people would try it out!
