Z-CAM E1 Camera 100 Mbps hack for 4K DCI (fw v0.31)
  • 366 Replies sorted by
  • @markr041 ...changing the subject , mark if you've got or will get the mod screen for the hero 9, could you evaluate whether it might be appropriate mod for this cam. thanks
  • @kurth Good question. I am awaiting the screen, and I will try it out on a number of cameras, including this one! Should be here at the end of next week. In principle, if this cam has a 1080 standard stream via HDMI it should work.
  • @markr041 ...well I've been reading the hero 9 thread and had the notion about e1. Interesting cam, the gopro. ok thanks
  • Guys, does anybody have iZugar E1 or iZugar's firmware? Are Z-CAM and iZugar E1 different?
  • Sorry Long Time AVK
    when planning and testing the conversion of the e1 to active cooling, i came across a few interesting details
    1.) sensor cooling of up to 50C to between 10 and 15C is most effective
    2.) The cooling is almost invisible with video ( 3D noise reductin ) , with photo especially with ISO values ​​of more than 400 massively less noise
    3.) After an update from Izuga E1 to the current Fw, the 1x1 resolution of 2500x2500 disappears this can be fixed / undone with a small hardware hack
    My conversion of the E1 to active cooling has meanwhile become:
    1.) E1 has become E2 housing hack with active cooling without a ventilator in which the chips and memory are also better cooled
    2.) the Accu has grown to 1sLipo 1000mAh
    3.) The New E1 box that looks like an RED e2 style eloxal Aluminium Housing 100x100x100mm
  • @Bob_Hawk can you send a photo? :)
  • I first recreated the housing parts with 3D printing until they fit.
    now a friend is milling the 20mm thick aluminum on a CNC machine As a finish, the aluminum fire red is anodized ...... the MN34230 sensor and Ambarella A9S75 are each cooled via a small peltier element with 15x15mm to the housing
    I cool down to + 10C to avoid condensation.
  • Oh yes, I'll be selling the next few days on Ebay or direkt to here
    The newer remote module set from IZUGA for 4 Zcam E1s
    1x master 3x slave incl. 4 cabel 1 short for Stereo config 3x 100mm long for 4cam setup
    function can be shown via a current video
    that is recognized with firmware 0.31 even without config on the SD
    who of you hardcore zcam gamers was interested in advance PM with a serious offer to me
    I also ship worldwide
  • @bob_hawk no improvement n video?
  • After about 10 minutes, the E1 normally has a sensor temperature of over 40C at 4K30
    in the E1 you can only switch the "3D noise reduction" to weak / medium or strong
    at weak something can be seen that the image noises less when the sensor is cold.
    In the photo mode, the difference between 48C and 10C sensor temperature is clearly visible
    the photo mode has never interested in the E1 except maybe for time-lapse
  • Noise that does not arise does not need to be removed.
    The new panasonic / blackmagic red everywhere great importance is attached to good sensor cooling.
    and the sensors were not operated up to the limmit.
    Only Zcam claims that the noise is not a problem for you .....
    Zcam has its external noise removal software to iron out noisy images again
    Look the open BMPCC Pic
    The huge success of BMPCC was partly due to the image quality .... the BMMCC had already cooled the sensor with a peltier element
    740 x 530 - 131K
  • I don't know what horror awaits us when "Storryboard" manages to deactivate the noise suppression with a pach
    I suspect a lot of reading errors that the 3D noise reduction had eliminated so far
    The E1 is what it is .....: a compact cam with 4/3 interchangeable lenses---> i have 4 X E1 :-)
    The E1 will never be a cinema camera like the blackmagic pocket 4K or the E2, --> it lacks the technical requirements
  • I am selling mine iZugar Z4XL Remote Kabel Set on EBAY
    Shipping woldwide with Tracking 10€
    if you are interested , To special people i also make special prices
    please contact here in the forum via private mail ... so that I can distinguish you from ebay customers
    https://www.ebay.de/itm/133600176874
    1378 x 840 - 113K
  • If 1080p 4:2:2 HDMI is interpolated properly, the noise will be substantially reduced and bad pixels will be mitigated. A good 1080p will be the best option from this cam, if noise reduction can be canceled.
  • My setup for live music events and weddings:
    3 x Zcam E1 started simultaneously as multicam recordings via remote.
    In 3x 4k 30 Fps 3x the 100mbit hack --- 3x 128 Gb sandisk extreme pro
    if there is little light, use lenses with at least F1.8 or F2 and switch off the automatics
    The noise reduction set to low and a flat profile (less contrast, less color)
    So I have achieved the best results with my 3 Zcam E3 even in low light
    Good lenses !!! and time for color grading with Davinci Resolve are the most important things
    meanwhile I use 2 x LM12XC KOWA manual lenses for the left and right stage cam
    Set it once and let it run .. the hyperfocal distance at 12mm F2 makes it possibleI....I love this Lenses
    700 x 480 - 106K
