AVCHD maximum image quality settings and testing
  • 1002 Replies sorted by
  • @Chris
    the 44mbs is good..
  • @cbrandin
    the 66m set doesn't work neither in 720p50 (SH),
    thanx
  • @Chris
    Thank you for information.
    When I first used 66m setting, 24L was not able to be played in the camera.
    Then, I combined with 32m though I understood the difference from what you intended because it was inconvenient.
    Is it still useless?
  • @bkmcwd
    Mixing up these settings won't work. The 44M settings do have 32M at the 24L position. Also, 32M works fine with just the user settings bitrate and AQ.
    Chris
  • Though I do not firmly understand the theory, I changed a little and tested Chris's 66Mbps setting.
    It was possible to record continuously during 30 minutes in 32Mbps(24L) though it was possible to take only up to 4GB with this setting in 66Mbps(24h).
    Both, there was occasionally what was not able to be played in the camera.
    However, it could play after turning off and on camera's power.
    Im not sure this is correct setting...
    1297 x 633 - 147K
    1297 x 633 - 144K
    setd.zip
    493B
  • @cbrandin
    "Here are some updated standard GOP settings. One is at 2x(44M), and the other is 3x(66M)"
    The 66M set doesn't work with FSH/50i (card speed error with my SanDisk cl.10).
    The 44M set is great!
  • @cbrandin I could not produce an uneven cadence with your settings, both 44Mb version looks great in stream parser and on screen, lucky we have you, thanks ;)
    1289 x 673 - 68K
    1289 x 673 - 68K
  • @cbrandin do these settings apply to all modes?
    I used your last set on some test shots for an upcoming project and noticed some pulsing at regular intervals on 720p60, otherwise they looked great
  • @cbrandin re your last settings here, why did you go for those values in High Top Setting (x2.40) etc?
  • @cbrandin Cheers Chris, fantastic work
  • Yeah, there are some technical refinements. It shouldn't look any different, however.
    Chris
  • @cbrandin Top stuff. Is the 44m much different to the last one you updated?
  • Here are some updated standard GOP settings. One is at 2x(44M), and the other is 3x(66M). As I expected, 4x (88M) does not improve on 66M significantly, so I am not bothering with those. As before, there is still the spanning issue sometimes.
    Chris
    seti_66M_setj_44M_Settings.zip
    1007B
  • I wanted to share these settings. GOP is unchecked 24H -88 24L -66. AQ4
    The 66 setting seemed to use more of it's bit rate but have to shoot more at 88 to really make that call.
    I've posted a earlier 24H@66 but these settings use more of the bit rate. I've been using the 66 at 24H and just changed to the higher bit rate. The footage looks great. I've shot bushes trees bees dog and cats and a number of humans. Load to FCP no problems.
    I'm wanting to try the new low GOP for the motion and to see the difference if any.
    thanks to everyone
    Luke
    1161 x 608 - 127K
    setf.zip
    438B
  • Thanks for the Help Mihuel.
    much appreciated.
    Luke
  • @LukeV
    1) push the button "print screan"
    2)open "paint" program"
    3) control V ( paste to program)
    4) make selection from picture and save JPG
  • I'm a Mac user and just got a PC for SP app. Can someone point me to how to post the Stream Parser graph.
    I'm a bit lost.
    Thanks
  • @cbrandin I am using your setj.zip setting posted from 27 August. On 24H mode, I have no issues with file spanning past the first 4Gig size. I am using PQI class10 16GB SDHC card.
  • @cbrandin Here's my 2 cents.
    I guess a simple tactic would be keeping I-frame high enough and QP low enough. Once we reach I-frame large enough, we wouldn't gain much. Then shortening GOP makes sense for higher bitrate settings as lower GOP demands more redundancies which may not be a bad thing. The more I-frames per second, the less motion aliasing... although not proven yet.
    44Mbps GOP12
    66Mbps GOP12 or GOP6
    88Mbps GOP6 or GOP3
    110Mbps GOP3
    All those settings might have almost same image quality on I-frames, but the higher bitrate gets more I-frames. So the diminishing gain in image quality might become non-issue for those who prefer shorter GOP. I think each setting would be perfectly fine, and we have more choice.
    BTW it would be nice if 24L and 24H can have different GOP value so that I can have 44Mbps GOP12 and 110Mbps GOP3.
  • Ah, I should point out Film Mode: Smooth, -2 Contrast, -2 Sharpness, 0 Colour, -2 ND.
  • Contrast -2 might help, too.
  • For me, the occasions of gradient banding in areas of subtle tonal and chroma shifts over large areas like blue sky and blank walls are the Achilles' heel of the GH2 video image. I am finding @cbrandin's 44M settings are producing less banding. The banding has not been eliminated entirely but it appears to be noticeably reduced.
    I attach two PNG images of typical images that would produce a more pronounced banding effect with the default firmware as well as some of the high Mbps/low GOP settings being tested, at least so far as I can tell. I have an allergy to that banding, so I am very aware when and to what degree I see it!
    Great work, Chris!
    1920 x 1080 - 3M
    1920 x 1080 - 3M
  • @vladnik
    I want to max out quality and stability at 44M first. At some point lowering QP won't do anything any more. Eventually I plan to start increasing bitrate in order to determine when there is a diminishing return. My guess is that will happen by the time 66M is reached and going higher will not produce better results.
    Chris
  • @cbrandin
    how about 88Mb 12 gop super quality patch.
  • for 100 mbit AQ4 is 7 qp and AQ3 is 10.
    12 qp is probably minimum .
