GoPro Hero3 , 4K is here in Baby Steps for $399.99!
  • 642 Replies sorted by
  • Are we set for a GoPro 4 announcement next week. They tend to announce around the same time as apple which will be 9/10/2013.
    Could we see 4K @ 30 FPS and 2K @ 120 FPS? Will you upgrade if that is the case?
    http://wideopencamera.com/cameras/gopro-hero-4-what-we-might-expect-4k-30-fps-2k-120-fps/
  • @subco As far as I can see, the 3.00 firmware doesn't do a speed test. It just checks for the manufacturer. When I tested the three 64GB SanDisk cards which I have previously selected (out of 10) as working well at 45Mbps, they were downgraded in speed the same as the worst of the bunch of 10. People have been complaining that the newer SanDisk cards (Extreme Pro) are downgraded the same as the older UHS-1. I have seen no evidence of any actual speed test in any of my testing :)
    The reason I suggested SLOW was there are only 4 characters on the front LCD display, I think. But your 35Mb would be a much better indication, I agree. Easier to figure out what was happening :)
  • @mpgsxvcd "I think GoPro should be commended here"
    I do not. They do not deserve commendation, based on what I have seen. I have programmed embedded systems, and led programming teams, so I am comparing what they have done with what they could have done. My conclusion is that they have done a sloppy job, for the following reasons.
    1. They only check the Manufacturer of the card, and make no attempt to see if it is fast enough or not. My fastest Sandisk, which are perfectly reliable at 45Mbps, are forced to record at 35Mbps.
    2. The countdown clock showing how much time is left is not adjusted when you put in a slow card. It counts down to 00:00 and then stays showing that for the last hour of filming at 35Mbps. In addition, they have not fixed the minutes and seconds juxtaposition countdown error, which has been around since version 1.0
    3. No attempt is made to indicate to the user what has happened (see countdown above, for example)
    4. There are more elegant ways of handling the issue, such as giving the user an option to drop to 35Mbps even with the faster manufacturers, for example.
    Yes, I am a hard taskmaster, but when commendations are handed out for "fixes" (remember GoPro recommended Sandisk cards right up until a few days ago) those fixes need to be creative and well-executed, IMO.
    As an example, they could have provided a menu item for Protune 35Mbps and another for Protune 45Mbps (rather than the current single Protune selector). If 45Mbps is selected, and a slow card is installed, the display could show "SLOW" and refuse to allow that mode to be selected.
  • Seems like there is a bug involving the "extended life" batteries and the camera itself, it's a bug I thought would surely be fixed about 2 firmwares ago lol. @rambo if you can pass this on, or know something I should try with my cameras (maybe power cycle the batteries somehow??) to get the battery add on to work properly I would greatly appreciate it. This battery issue alone scares me too much to take these cameras serious enough for any kind of paid project in fear they will stop working in the middle of whatever is going on.
  • @mpgxsvcd
    It is good thing as allows to understand how crappy are controllers and overall design. It also applies to many SSDs.
  • @trevmar
    That makes sense. I didn't realize that was the case. Oh well Sandisk doesn't have many happy customers now. That is the bottom line. I just hope those customers don't blame GoPro entirely for this.
  • The problem with the Sandisk cards is that occasionally, not very often, it takes the card a long time to find a new sector for writing into. So the time between when a new sector is sent to the card, and the operation is completed, extends to 750msec on my worst cards. This is quite easy to measure with IOmeter. So it is not really a problem with average write speed, but with occasional very slow response. I think a legal case would be hard to construct, as no card manufacturer guarantees its garbage-clean-up performance. The average write-speed is usually not affected so much.
    All SDXC cards have the same behavior, regardless of manufacturer, it is just that most manufacturers keep the maximum latency under about 250msec. Which is still pretty slow, IMO. I suspect all card latencies rise as time goes by...
  • I think GoPro should be commended here. They came up with a fix here for Sandisk's defective memory cards that actually has some benefits(Longer Recording time).
    This just screams class action lawsuit against Sandisk. They should simply recall all of these memory cards before some lawyer decides to force them to do it.
  • @mpgxsvcd Yes, that is my initial experience too. I tested my worst Sandisk 64G card (out of 10), yet it now recorded 2K7 CIN 24T Protune continuously until the display showed "FULL" at 4hrs 2 minutes, datarate 35MBps, without any problem. Although, through the first three hours of the recording, the display was counting down to the 3hr card capacity which I would have gotten at the 45Mbps datarate.
    Strangely, I have seen no folder or file containing any numbers on my cards yet. I will try the Samsung Pro out now, and report back after I get more. This behavior actually could be a useful way to get a longer recording session out of each card - 4hrs is longer than 3hrs - and if it is only B-roll - (insert Devilish thoughts here)...
    The firmware version I downloaded last night is 3.00, and says it was a 29th July release. I wonder how much longer the battery lasts at the lower data rate. I usually get about 1hr30 at the non-protune 35Mbps and 1hr15 at the 45Mbps Protune settings - (Wifi off, no LCD) - I need to test that as well...
  • I tried the new firmware and everything went great. My 64 Gb Sandisk card now records at 38 mb/sec and my transcend 64 GB card records at the full 49 mb/sec. The good thing is that now my Sandisk card can actually record without failing.
  • On my first recording with the new firmware, the card (Sandisk 64GB) stopped recording after a few min. Tried recording again, and on lower settings but nothing helped. Then I got the SD ERR after I restarted the camera. Haven't had time to look into it further, since I'm on vacation.
    On the bright side, Adobe released a lens correction profile for all GoPros to fully correct distortion in photos and video. Available on Adobe Photoshop CC, ACR 8.2, and Lightroom 5.2. Can't wait to try it out, and compare with AE's Optics Compensation filter.
  • one isn't required to install the firmware update
    Yes, that is true. I will update one of my H3B, and leave the other where it is. Will post any differences, as I note them...
  • And one isn't required to install the firmware update, after all. If the file transfer functions in the app are not needed I don't see other reasons to install the new firmware.
    Fran
  • @Rambo: "you still have Protune mode, just that the data rate is now 35mbps instead of 45mbps with Sandisk cards"
    Oh - that's not so bad then. Again, thanks for the detailed info.
  • Seems like they also removed the Exposure Lock for Timelapse in the latest Firmware. :( Some Bugs don't need fixing.
  • @trevmar It's worth a look at the link Rambo posted...suryaprihadi has done exhaustive work on cards for the GP's. Very informative and he's a heck of a nice fellow too.
  • No probs, only to happy t help.
    Just to clarify for others who might be reading, you still have Protune mode, just that the data rate is now 35mbps instead of 45mbps with Sandisc cards, all other cards the camera still records 45mbps in Protune mode.
  • Well, I use Protune for EVERYTHING. It is the main advantage the GoPro gives over my other cameras. Stuff the 95% of users who haven't figured out dynamic range yet, GoPro has just my MY life more difficult... . I appreciate your info, in any case, Rambo :) Thanks for all you do re GoPro...
  • Yep, exhaustive test on many cards where done here (27 pages of tests) http://goprouser.freeforums.org/this-is-why-ur-black-freezes-t12096.html
    It's possible the Sandisc range will be included again in a future update as now Sandisc have released new Extreme and Extreme Pro MicroSD cards, but GoPro are very pissed with Sandisc as it affected their business big time with hundreds of thousands of support calls of cameras freezing with Sandisc Ultra cards which as we know were the very cards GoPro initially listed as recommend on their website based on Sandiscs class10 specs.
    Difference between 35mbps and 45mbps recorded video ?.?. .. I can't see the difference visually, but possibly high motion footage could suffer, but 95% of users don't have a need for Protune or even understand what it is so it was the right thing for GoPro to do.
  • So all that work I did to figure out the 40% of my Sandisk cards which actually do work OK is now wasted. Nice one, GoPro. I have $600 of useless SDXC now. And no longer such a warm feeling about this company... . BTW, I figured out that the problem was that occasionally the allocation algorithms in the SanDisk cards take a long time - as long as 750msec in faulty cards - to allocate a new sector to be written...
  • As reported one page back, GoPro have implemented a card check in their latest HD3 firmware update. Due to Sandisc manufacturing UNDER spec class 10 MicroSD cards in the ULTRA range ( GoPro, many experienced users and even Sandisc themselves have confirmed this) "ALL" Sandisc branded cards (even the Extreme Pro) are detected by the camera FW and the Protune recording data rate is reduced from 45mbps to 35mbps. All other brands, no changes, however GoPro now have a new list of recommended cards on their website.
  • That's true Douglas but still very useful especially if you also have 1+, 2+, 5 + to get the range you want. Check this for example.
    @Gravitatemediagroup, for slip on adapters for the GoPro here http://www.snakeriverprototyping.com/hero3-filter-adapters
  • The lens just puts everything out of focus except for what's in the macro range. It doesn't seem very useful in most contexts.
  • I would REALLY like to see some 1080 or 2k 24p stuff with this lens : ) if possible
    I must have been snoozing on gopro info, how long have these "slip on adapters" been out, because being able to add basically any type of 55mm filter or small lens is really nice addition.
  • Rambo, thanks for another brilliant tip - I just ordered a "BlurFix Micro52 slip on adapter" as I didn't realize any such thing existed :) :)
