"That is achieved by electronic, rather than optical, means."
Optics or electronics make no difference. Can not make more brightness from less original brightness all else being equal.
Obviously if the Black Magic camera can produce more dynamic range from a less light sensitive area means the sensor has to be of higher quality or the magnification circuits and algorithms need to be of higher quality. There is no disagreement there and I am aware of different sensor characteristics. So all is not equal inside the cameras.
It is safe to say the exposure is the same when switching the lens between the cameras, there is no disagreement either.
But somebody would have to explain where the increased image brightness with focal reducer comes when the lens is the same, the f-stop is the same and even the sensor is the same.
Actually I have studied optical physics, and you're dead wrong about this.
Cameras with smaller sensors do not have built-in focal reducers. There is no process inside the camera that is analogous to using a focal reducer. Focal reducers have specific optical properties that are not replicated in any way, to "match" the "final image sizes viewed on a monitor". That is achieved by electronic, rather than optical, means.
You're treating image sensors as single, discrete entities. To understand the physics at work, you need to stop thinking of them that way and start thinking of them as matrices of pixels. In this view, and notwithstanding more sophisticated algorithms like pixel-binning, if anything it is the pixel size that determines the relative brightness (which is normalized by ISO, and thus actually determines only the ISO performance). Again, pixel-binning algorithms make pixel size less important, as they effectively merge pixels with their otherwise-inactive neighbors during video recording.
Any optical laboratory will confirm this. No film school will, however. This is why I suggest youth to take physics and chemistry in the university and not videography ;-)
@aki_hartikainen I've lost patience with your inability to comprehend optical physics. I'm out.
@Sangye "The brightness does change if you either move the projector closer to create a projected image that is 3' x 5', or if you use a lens / adjust the focal length to focus it onto a smaller area. This is analogous to using a focal reducer."
But that is what one has to do inside a camera aswell, if there is change in the sensor size. The final image sizes viewed on a monitor will need to match.
One could use a focal reducer. Or grow the sensor area. Same result. Where does the increase in brightness come when using a focal reducer, if not seeing more light? Larger sensor would see more light just the same.
@aki_hartikainen To clarify, does the wider FOV picture on the right use a focal reducer? The brightening effects of focal reducers are well known. They're also completely irrelevant to this debate. Focal reducers are rarely if ever used on video cameras, due to inherent issues with coma.
To further negate the legitimacy of that example, compare the brightness of a given lens at a given f-stop mounted to a GH2 with a focal reducer, with that of the same lens at the same f-stop mounted to a larger sensor that gives the same FOV as the GH2 + focal reducer. The GH2 will be brighter, because the focal reducer focuses the projected image into a smaller projection. In other words, using a focal reducer is NOT the "exact same" as what "would happen if the sensor by some miracle grew in size."
As another example, take a projector. The brightness of the projected image doesn't magically change if you're projecting the full image onto a 6' x 10' wall, or a crop of it on a 3' x 5' screen mounted to that wall. This is analogous to the [non-existant] difference in brightness between sensor sizes.
I took the liberty to take the samples from the other thread that I linked on the previous page and originally provided by Brian202020, who is working on a focal reducer. Histogram proves increased image brightness for larger image. Same lens, same f-stop. Only difference is angle or "crop" causing change in image brightness (all else being equal). This exact same would happen if the sensor by some miracle grew in size.
According to some in this thread, this should not happen but the histogram proves it.
Brightness is wattage. It would be worth a lot of money if 1/4 sized panel could produce the same wattage/brightness as four times larger. Unfortunately this would be against the laws of physics. That it seems to happen in a camera where there is plenty of things to adjust for the brightness and quality (including sensor and pixel density), something clever has been achieved to be able to magnify more without apparent brightness/quality penalty.
The penalty could still be there in the final analysis, just small enough to be insignificant now.
+1. BMCC has larger pixel pitch than 5DmkIII.
See http://www.personal-view.com/talks/discussion/4403/pixel-pitch-size-sensor-refresh-rate/p1
@aki_hartikainen No, you can't say that "the lens will be brighter on the larger sensor", and moreover, dynamic range does not correlate with sensor size. Basing your argument on a hypothetical larger sensor with more dynamic range is both a strawman fallacy, and a false dichotomy. How about a smaller sensor with more dynamic range (e.g. the BMCC)?
Also, your concept of "magnification" as you use it here is very abstract. Please explain, because I'm not following.
You are right that engineers have adjusted different cameras to have equivalent brightnesses at given ISO levels, but the variable is not sensor size. The variable is pixel size. Importantly, pixel size does not necessarily correlate with sensor size. And as I explained above, the given downscaling algorithm used by a camera can to some extent overcome differences in pixel size.
The larger sensor captured more light, but not necessarily more light per pixel -- only if the pixels are larger! Moreover, the additional light attributable directly to sensor size, is only manifest in the greater field of view.
This is fantastic! Arguing that all the light-meters must be wrong. Creating a flame instead of spending 10 minutes with a camera to test.
Not only proof that the F-stop we've all known, loved and trusted can be found somehow faulty using words alone. But even more fantastic, we now have proof of the inexorable laziness of humans to postulate from their armchairs, even against all odds.
We could argue the hind-leg off a donkey!
Are you from the planet Earth? You sound like out of this planet.
"but you can't say that it's because the lens is "brighter" on the larger sensor. It's the same god-damn lens, or else, it's the same god-damn f-stop. Stop confusing people, please."
The lens and exposure will be the same, no disagreement there.
But if the larger sensor has better dynamic range, then yes, one could say the lens will be brighter on the larger sensor.
This is because there is magnification taking place inside the camera and magnification has the penalty of reducing brightness. The smaller the original, the more magnification required for the final size and thus bigger penalty for brightness. Both cameras need to produce the same image size of 1920 x 1080, but the full frame camera saw four times the light for that final size compared to cropped 1/4 area sensor. It has already been mentioned that it does not seem to have impact on the final image brightness or quality, but the basic principle of magnification is still there.
It is also true this does not seem to require any user intervention between different sized cameras, but that is because the camera engineers adjusted the output to be the same very carefully. The larger sensor that indeed captured more light could still have advantage for dynamic range, for example.
It's a bit disheartening to see just how much misinformation is out there about the interrelationship of optical parameters (e.g. sensor size, focal length, f-stop) and optical effects (e.g. subjective brightness, field of view, and depth of field).
In short, the lens doesn't "care" how large the sensor behind it is. It projects the exact same image, and it's up the the sensor to capture some or all of it.
A 50mm f/1.4 will project the same image, at the same brightness, irrespective of whether it's mounted to a Canon 5D or a Panasonic GH2. The only difference is that the 5D's sensor will capture most of the projected image, whereas the GH2 will capture a smaller "cropped" section.
The "brightness" of the projected image won't change.
As for the depth of field, to dispel another myth, same thing.
It really doesn't matter how large your sensor is, all other things (e.g. pixel density, downscaling algorithm) being equal.
All that will change is your field of view.
Now, if you take a 35mm sensor with 21 megapixels, it will probably have better ISO performance than a MFT sensor with 21 megapixels, simply because the pixels are larger, and thus receive more light each. But with both set to, say, 1600ISO, the "brightness" will be virtually identical (slight variations are possible due to inexact ISO standards, but not necessarily to the advantage of the larger sensor). The sensor with larger pixels will likely have less ISO noise, all other things equal, but you can't say that it's because the lens is "brighter" on the larger sensor.
It does get a little more complicated when sensors use pixel-binning algorithms for video. Such algorithms can effectively make a sensor with a high pixel density (which is to say, small pixels), perform significantly better, due to more light registering. That's why, besides also giving it very little aliasing and moire, the GH2 has impressive low-light performance. In my experience it's better than most of Canon's lineup, due to their shitty line-skipping algorithm. The idea that smaller sensor necessarily means worse low-light performance, so frequently espoused by the legions of misinformed die-hard Canon fanboys, is misleading at best.
Part of the problem is that we have not defined brightness accurately. Intuitively, the brightness of an image is the luminous flux per unit area, which is either illuminance or luminous emittance, depending on whether we are talking about light falling on a surface or being emitted by it.
When you take the same lens with the same lens field of view and a smaller sensor, the illuminance of the image falling on the sensor does not change. The luminous flux of the light falling on the sensor may be lower, depending on the distribution of luminous flux in the area of the image plane. If the parts of the image that fall outside of the crop border were all black, then there is no difference in the luminous flux of the light falling on the sensor.
If you hold up a photographic print in front of your face, cut it in half and let half fall to the floor, and then hold up the remaining half, did it get any darker? No, not in the intuitive sense of the word brightness. Less total light might reflected from the print onto your face. Someone looking at your face might say that your face is not as bright. But the part of the image that remains is just as bright as before. Cropping changes the area of an image, not its brightness.
Now if we compare an m43 and a full-frame camera where the full-frame camera has a lens with double the focal length so as to give the same field of view, if the two lenses have the same f-number and ignoring differences in light transmittance between the two lenses, the larger lens collects four times as much light from each object in the field of view because it has an aperture four times as large. This gives a two-stop advantage for noise performance. The advantage in noise performance comes from the lens having a larger aperture, not from the sensor being bigger. These cameras are not equivalent, and their fields of view are technically not the same because one has an aperture covering a larger area. The depths of field will be different, assuming the same output resolution. Here's a good read on camera equivalence: http://www.falklumo.com/lumolabs/articles/equivalence/index.html
Alfi, depth of field depends on the output resolution, magnification, and focus distance, not just the lens's aperture. The circle of confusion size of out-of-focus objects relative to the size of in-focus objects in the image depends only on the aperture diameter, focus distance, and object distance. But depth of field depends also on lens magnification and on your circle of confusion criterion. Generally we take the output pixel pitch scaled to the image plane to be the circle of confusion criterion. If you take the same lens with the same field of view and put it on a smaller format camera with the same output resolution, the depth of field becomes shallower, because the resolution in the image plane goes up. If the image plane resolution is the same, then the depth of field is the same. This sums it up pretty well: http://en.wikipedia.org/wiki/Depth_of_field#DOF_vs._format_size
Until yo go back to reading that other people posted and check all definitions you are prohibited to post in this topic.
Right now you are talking with yourself and going in circles.  Not hearing that people telly you.
I do not like such level of discussion.
I am not mixing anything. Changing the ocular of the telescope does not change the f-stop of the lens. The brightness falls by cropping of the ocular with more magnification. Yes, we could get the image back to the same brightness, but we would have to do something about it.
The camera engineers already made the cameras appear similar in brightness, but they did something to achieve that.
I already told you that you mixed different things in your head. Check definition of F stop. and other definitions first. As for brightness talks, see my posts above.
Then take a telescope and change the ocular magnification (=crop the field of view). The lens diameter and f-stop remains the same, the ocular would be the film/sensor size. If the brightness remained the same regardless of the ocular, one would just have won a Nobel prize for physics...
Many things mixed in your head :-)
As I said, spend some time and read definitions.
This is not difficult concept at all. Just put a macro tube on the camera. Now you have cropped the image and the brightness falls. That is all there is to it. If the lens would focus as usual, it would be identical situation to cropping the film/sensor size.
I understand it would be simple for many people to say that there is no difference between cameras of different imager sizes, because that would be true also.
But when somebody clearly understands the basic principle of relationship between magnification and brightness, then there is really no need to insist that this does not exist at all, which is what several people in this thread try to maintain.
All this flame arise because people are mixing lenses, sensor as whole, and small photo sensitive sites. Add here that most never account for viewing size and you'll have perfect mix.
Just fix your head on individual photo site covered with micro lens. If they are the same size on FF and m43, and same lens is mounted, they recieve same amount of light. Period. This means that FF will have more resolution (and this is usually the case).
If you are viewing m43 and FF image on same monitor and same size than SNR will be better for FF image (up to 4 times).
So many wrong assumptions here... You won't believe, but an M4/3 F2.8 lens will be as much bright as Canon EF 2.8 lens - just the second one is made for bigger sensor - therefore there has to be more glass.
So if you take a fullframe Canon EF 2.8 lens and put it on M4/3 camera, it WILL HAVE SAME BRIGHTNESS - just different "zoom factor". And now comes the big surprise - THE DOF will be the same as well!! (meaning same on FF and M4/3)
Only thing that will change is the ZOOM - FIELD OF VIEW.
It is common believe, that DOF is half as small on 2x crop than on fullframe - THAT'S NOT TRUE. DOF is same - it is just that you have more "zoomed" image than on fullframe - so you have to step back from the subject, and therefore, REFOCUS the lens - which obviously changes the BOKEH. You can try for yourself - try it on 5Dm2, then put the lens on GH2 BUT don't change the focus... the background blur will be the same - just the image will be cropped.
So to achieve the same field of view (zoom) on cropped camera - you have to use wider lens - which has longer DOF for obvious reasons - that's why the common belief of "longer DOF" on crop.
DOF depends on LENS.. nothing else... if you PUT smaller sensor behind the lens, you won't see any other image - its just that you will see only part of the image that the lens can produce.
Obviously the sensor may be more sensitive to light and the density of light sensitive elements may be different, but that is one form of amplification and does not refute what I wrote.
Here you could see from sample images provided by Brian202020 what happens to the brightness when cropping/magnification is changed: http://personal-view.com/talks/discussion/577/using-focal-reducers-with-gh12-and-old-lenses#Item_38 (in the middle of the page)
From the histogram you could see increase in brightness when field of view gets wider. The opposite would have to happen when reducing the field of view. It is time to admit that by creating a tele lens or "tele sensor" by cropping the field of view can not maintain image brightness without doing something.
