Hi all,
I'm going to shoot a documentary with a GH1 in a wild animal care park (wild animals that are wounded, abandoned or from smuggling). Most animals are in cage and there are lots of trees covering the sun rays so it can be dark. I did some tests already to see what kind of problems may occur (dark areas, animals running around or hiding, etc). I'll shoot whenever there's sun so there'll be some very contrasting lighting (between sun rays and shadows), I need some details on fur and feathers (there are birds as well).
So what would be the best suited hack for the GH1 to get the most details? I am a motion designer and occasionally shoot stuff for my own projects so I'm no camera specialist (but i love it!). I'm looking for a "film" look (hopefully i'm not bad in postproduction) and fullHD in 24p.
Thank you for your help!
Cheers. I use the sandisk 32gig 45mbs which never gave me any problem so far. last intra setting i tried was AN BOOM! a great setting but said to have stability issues and it demands 140mbs (i write mbs in small letters in both cases, know the diff between bites and bytes though :-) )
I just wonder anyway if the step from flow motion to intra is that big. I really dig the new valkyrie settings but they demand as much space as an intra setting.
sedna seems to be a good point to start with. cheers
@Mirrorkisser :o) There are quite a few things to consider.. the memory card is probably the first consideration, as long as you have the 64/95mbs card then you are right smack bang in the candy shop.. you can expect all settings to be as stable as can be... Then comes lens choice, panasonic/ olympus auto lenses affect stability more than manual lenses... next comes the frame rate that you prefer to shoot at.. 24H seems to be the optimum frame rate for both performance and stability... Then things start getting tricky, when you add in the personal preferences of iDynamic et al..
Really recommend reading for a few months and testing out what sounds and looks good for you.. :) although I understand why a lot of people might want a faster route ;)
Do try the 24L option though.. I really like the Sedna settings but recently away for three weeks in California didn't want to fill too many hard drives, the 24L setting was great and I didn't find any noticable drop in IQ. Good luck finding your favourite!
@matthere: lol i knew this was coming when i wrote "best". I know there is no best. I meant a good allround and stable setting. something like flowmotion, where i think everybody would agree its good and stable ^^.
@Mirrorkisser best is a subjective term, you are the right person to judge the different settings for yourself, harsh I know, but true. If you are looking for an intra setting at lower bit rates, I would suggest trying the 24L settings rather than 24H, to find one that fits with your workflow, good luck :)
just wondering, the gh3 will have a sub 80mbs intra codec...
so what is the best and less space consuming intra codec then?
They are space consuming because they need to be. Recording with all I-frames but not enough bit rate is much worse than recording with B-frames and more than enough bit rate.
I am looking for a very good and stable intra setting with max 120mbs. Any ideas? All the other intra settings are really space consuming. Cheers
I sent you a message with the information you need.
Edit: mpgxsvcd has helped me sort his setting out on my camera so I will use his for now - thanks!
Copy and pasted from my thread because it got closed :( :
Hi there I have been trying to find a 100 percent stable settings file to download for my GH2 I tried one already from mpgxsvcd and strangely it does not record more than 2 seconds at HBR I have a verbatim class 10 SD card as well which should be more than good enough - this is with the latest ptools (3.66d) and panasonic firmware (1.1) and his 725B settings.
So basically I am wondering if anyone else has come across this and also if there are any other stable settings I can use? As of this date (I found some old ones which I was not sure of) Thanks!
Hello people with knowledge, I just got the panasonic GH2 with a Sandisk 64GB 95MB/s SDXC. I don't know much about the technical part of this camera's. I am a documentary filmmaker. I was thinking about hacking the camera, but i don't know if i should do it after reading about errors and short recording times.. I also can't see the difference any more between all those vimeo/youtube film tests with hacks. Does the hack really make the image look that much better?? I thought the flow motion did some great work with the movement.. did i see that correct? I just don't know which hack to download anymore......
What i want from the hack: - that it is save and stable - long recording time. - pretty image / good flowing movement - good image in the dark (higher iso maybe?) - i have an adaptor for photo lenses on the gh2, the hack needs to work with that. - Nice footage for editing (not TO big sized maybe...)
Who knows the right hack for me? Hope some one can help me out in making the right decision for the hack. So i can start making films with the camera!
Thanks already.
Greets, Daan The Netherlands (PAL, if thats importent to mention)
Do any of the currently available Cluster or Crossfire settings outperform Sedna A, for all-around best quality in 24H?
Need a hack patch that works well in high contrast. I'm shooting something lit in an area n almost black in another. Is the night patch you guys mention good for this?
Hi I'm new to this, and I want to put the driftwood hack on my GH2, I know how to use ptool, but if someone would take their time to explain which driftwood path to download to get the quality as good/better then a Red Epic camera and give the link and the settings to use on the camera that would be great! Thanks!!!
Hi everyone, So, I come from a film background and am now shooting a film on the gh2. I'm looking for a patch that gets close to 35mil; things like latitude, ratio, etc.. Can anyone recommend a patch that gets as close to 35mil a patch can get while still maintaining some good reliability? Ambiguous question maybe. Thanks!
Airgam, Cake would probably meet your requirements, except possibly for in-camera playback. I never tested that. Other hack settings may not span in ETC mode.
cogumelo, PTool can only change the frame rate for MJPEG.
anthonyw, all of the hack settings have some adverse effects, not the least of which is going to be card compatibility when the bit rate is raised. At the low end there are several choices including Sanity and Cbrandin 44M. You just need to go looking and see which ones meet your requirements. You don't need to change the version compare checkbox in PTool. You can name the firmware file GH2__V12.bin every time.
Try Cluster v6 Drewnet.
Hmmm... really having a tough time deciding which patch I want to use. Orion V4b is really good, but the file sizes are just too big. Aquamotion v2... Flow Motion v2... can't decide which one I like better. Flow Motion does not allow for in camera playback of MJPEG though. Then there's Sanity v5... why are there so many hacks? Wow, this is really frustrating! I want to pick just one to use, but can't decide. Thoughts anyone?
Hi everyone. I've had a GH1 and just got a GH2. I have some questions as far as all of these settings go.
I'm really liking what I've seen from people using the Orion v4b patch. I think that a lot of it looks like big screen / feature film quality with is amazing!
Does anyone know if this patch retains all normal camera functionality.. e.g. playback in all modes, spanning, ect...? If not, does anyone know what is the highest quality patch that does? What patch would also give you the best quality at reasonable bit rates, would it be Sanity 5?
Basically, I would like to know what patch is going to retain all normal camera features while enhancing them as much as possible. If the Orion patch does this, that's perfect. What is the difference between the Orion v4b and v4d patches?
I'm currently running a SanDisk 16gb 95 MB/s card which I just purchased with the GH2. I have the 14-140 and 20mm lenses. I will mainly be doing music videos, with some possible low light shots for nightclubs.
Also, when hacking my GH1 I would just make sure "prevent version compare" was checked when loading a new patch, and I wouldn't rename the firmware filename, I would just save it as the original firmware filename. When loading a new patch / firmware in the GH2 do we still need to rename the file each time as a higher number for it to take effect, or can we just overwrite the original?
Any help is greatly appreciated. Thanks!
I am looking for a stable patch that provides a high bit rate and the ability to directly playback in cam without the need to switch it off first. I am also wanting to implement the Pasadena sound settings.
I am more interested in stability and direct playback than push the camera to its limits. As far as the sound hack goes I am just trying to limit or eliminate the Automatic Gain Control (AGC).
Just decided to hack the GH2. I've been reading the humongous amount of information and wisdom you have here but I'm completely lost. I'd like to find a patch that suits what I do but dont know where to begin. What I'm interested in is:
Shooting PAL, 25fps 1080P.
Using ETC mode primarily.
Lots of pans and movement.
10-15 min of continuous recording.
Looking for a good balance of quality and reliability, with the focus on reliability.
Would use 95mb Sandisk card.
If someone has a recommendation on what to try, I would greatly apreciate it.
Thanks!
