In general, I'd agree that the D750 is currently the most refined 1080p hybrid DSLR Nikon offers. Like all Nikons, however, the D750 has a few crucial limitations that impair its usability as a video camera:
For my purposes, a Nikon full-frame DSLR fills a video niche that would otherwise require a Sony A7s: high-ISO low-light shooting. Neither the Panasonic GH4 nor the JVC LS300 produce acceptable noise levels above ISO 1600 (and even that requires Neat Video in post). Both of those cameras are otherwise excellent choices, with none of the above limitations of Nikon DSLRs. But for ISO 1600+ Nikon is a better choice, with a full-frame sensor and image stabilized lenses far superior to Panasonic OIS zooms. On the MFT side, the SpeedBooster option is indeed useful, but IME shooting video at effective apertures wider than f2.8 often produces a painfully narrow depth of field. I much prefer to shoot in low-light at f2.8 at a higher ISO.
With that context in mind, there's a video alternative I still prefer to the D750: a Nikon D800 with a Mosaic Engineering anti-aliasing filter, hacked to use a 64 Mbps bitrate. This combination of third-party enhancements eliminates video moire and captures the highest quality low-light shadow details of any DSLR short of the Sony A7s. (While the A7s is superb in low-light, its proprietary lens selection makes it impractical for my purposes.) Here are links to the third-party D800 developer sites:
Mosaic Engineering: http://www.mosaicengineering.com/products/vaf/d800.html
Nikon Hacker: https://nikonhacker.com/index.php?sid=1257e1f5cafd972a325cb7d868b55048
Of course, the D800 solution requires additional camera preparation and enthusiasm for custom firmware hacking. As one of the more prominent hackers of the GH2, that's not an issue for me, and I've tested Nikon Hacker's firmware upgrades to my complete satisfaction. IMO, 50Mbps is the minimum bitrate needed for fast-motion and low-light video shooting at 1080p. Unfortunately, the D750 doesn't meet that spec, and Nikon Hacker has been unable to increase the bitrates of Nikon models beyond the D800. For that reason alone, I must regretfully pass on Nikon's current generation of hybrid DSLR's, in spite their improvements in overall usability.
The following video samples show the difference 64Mbps can make in fast-motion videography on the D800. To clearly see the increase in video detail, I'd recommend examing the frames at 200% resolution in a video editor. The original footage can be downloaded from my Vimeo site.
Or You can wait for the D760 and D820 They will both have higher ISO and 4k Video
Nikon D750 DSLR Camera, $1299
@RRRoger Everyone here knows how I feel about bitrate!
Is now back up to $2K, seems it was a very short price drop.
Nikon D750 firmware version 1.11
http://downloadcenter.nikonimglib.com/en/download/fw/217.html
Is there a 30 minutes recording limit in EU version or is there more limited in all version like in d7100 for example to 20minutes?
...So it is 10 minutes
Thanks @ironfilm Ive got the camera already amd it is actually 10 minutes in 1080 50p
I did test other sigma lenses 135 f1.8 and 24-105 f4 both works well in live view AF. Older 50 f1.4 and 18-35 f1.8 does not work. Can anyone confirmed Id like to know if it is samething wrong with mine or user error. Thanks
NOTICE TO USERS OF THE NIKON D750 DIGITAL SLR CAMERA OF NEWLY ADDED AFFECTED PRODUCT SERIAL NUMBERS (UPDATED)
In July 2015 and with an additional notice in February 2016, we announced that the shutter in some Nikon D750 digital SLR cameras manufactured between October 2014 and June 2015 does not function normally, sometimes resulting in shading of a portion of images. Since that time, further examination of the issue has found that the same issue may also occur with D750 cameras manufactured from July to September 2014 and from July 2015 to September 2016.
Therefore, any D750 manufactured from July 2014 to September 2016 is eligible for inspection and repair of its shutter. Please follow the instructions in the “Identifying affected products” section below to check if your camera is affected.
We sincerely apologize for any inconvenience this issue may have caused.
Please direct inquiries regarding this issue to your nearest Nikon service center.
New firmware version 1.12
- Added support for the following features of AF-P lenses:
- If the standby timer expires after the camera has focused, the focus position will not change when the timer is reactivated. *In manual focus mode, the focus indicator in the viewfinder (or in live view, the focus point selected in the monitor) will flash to show that infinity or the minimum focus distance has been reached by rotating the focus ring.
 - Fixed the following issues:
- When pictures were viewed after shooting with Overflow selected for Role played by card in Slot 2 in the PHOTO SHOOTING MENU, the camera would sometimes display the second-last picture taken.
 - Microphone sensitivity would sometimes not be correctly adjusted when movies were recorded with Auto sensitivity > Microphone sensitivity.
http://downloadcenter.nikonimglib.com/en/download/fw/245.html
Dont fix if is not broken :) Is there any known way of downgrade Nikon firmware? I did the one above and my Sigma 135 AF is gone now. Calibrating does not help. I was on secend last one before this one and could not complain at all!
I also think that it is always worth having a good camera at hand for such moments. However, most often I take photos on my iPhone. There are so many useful tips that I also want to buy a new camera. Thank you!
Nikon D750 DSLR Camera + stuff for $1296
https://www.bhphotovideo.com/c/product/1082599-REG/nikon_d750_dslr_camera_body.html
Nikon D750 Firmware Version 1.15
- Fixed an issue that resulted in over-application of distortion control in pictures taken with an AF-P DX NIKKOR 10-20mm f/4.5-5.6G VR lens at a focal length of 10 mm and with FX (36x24) 1.0x selected for Image area > Choose image area, Off selected for Image area > Auto DX crop, and On selected for Auto distortion control in the PHOTO SHOOTING MENU.
 - Fixed an issue that resulted in photos shot with non-CPU lenses being overexposed when taken by pressing the shutter-release button all the way down in a single motion under the following conditions: the standby timer off, On selected for Custom Setting c1 (Shutter-release button AE-L) in the CUSTOM SETTING MENU, and lens information specified using the Non-CPU lens data option in the SETUP MENU.
https://downloadcenter.nikonimglib.com/en/download/fw/318.html
Nikon D750 refurbished for $1049
Nikon D750 FX-Format Digital SLR Body Only Camera - Refurbished, $899
