Watched College Football all day, and then decided I'd actually put something together - Quick and dirty tests.
Process: add "S-log to linear" LUT, or "Cineon Log to linear" LUT in Resolve, and then grade as normal. None of these grades took longer than a minute using ColorGhear Pro.
2k ProRes 444 download available here: https://www.dropbox.com/s/etar2oo17ueds0k/2k.mov?dl=0
I'll get around to playing with an ACES workflow maybe later.
@rwriter nope - no need.
@shian, I presume you denoised those clips significantly? The originals are so noisy that I’m thinking of investing in the full version of Resolve or in Neat Video. I know they’re underexposed to begin with, but with 400 as the base ISO I’m not expecting cleaner shadows than what we currently get.
Multitasking is easy these days :)
you guys waste a lot of time on something that is going to be released soon. Go play outside or something. A couple more weeks and you can test vlog like crazy.
seriously?
@LPowell, @matthere: I don't know why the most of the GH4 users make such a grading (even on v-log) which still remains kind of flat. Maybe the reason is to keep that dynamic range too much obvious. Therefore almost every graded footage looks like a reportage video material, not cinematic, like a movie production. The most of the motion pictures have highly contrasted look that gives the cinema look and doesn't destroy the dynamic range.
For me, this grading looks much more cinematic (sorry for the boast):
@LPowell just a sample of internal footage I came across, there doesn't seem to be much internal footage around.. especially for download, like you say.
I hope that's not it.. as far as log development.
@matthere Sorry, but to my eyes that Evening Walk video doesn't look very good at all. The shadows certainly do not show much dynamic range and the color grading often shows traces of the telltale gray cast of unprocessed log footage. Without access to an original file download from Vimeo, it's hard to evaluate the quality of the original footage.
@Mckinise some internal low light footage.
@mckinse Well, I've already pre-ordered my update, so as soon as it gets here and I get a chance to shoot some stuff I guess we'll know.
@Shian As good as the Shogun footage is, I am still wondering what you can do with the GH4 recorded internal 8-bit.
On Illya Friedman's pre-production v-log-l the histogram in camera showed clipping to occur when starting to climb the right hand side, so maybe it won't be too difficult to expose without a monitor which accepts LUTs.
As Panasonic are now adding a log profile, what would be needed to add variations of that profile?
If Panasonic are listening to their users... what would be needed to create a v-log that uses the full range of the camera, what could we ask for, from them, to help them?
It's obvious that they want a log that will match the Varicam and it looks like the v-log-l does that, unfortunatly at the expense of 8 bit, could another version maximise gains from internally shot log?
Maybe Panasonic don't want users to get their fingers inside their cameras? But as noted elsewhere the v2.3 software shows potentially a location where other activated items might go..
Please, use Flickr
I'm about to fall asleep at my computer. I'm going to have to say goodnight and god bless.
That math looks pretty darn good.
Here's an ACES treatment. No "grading". Just math. V-Log/V-Gamut to linear, scaling, and linear to Rec.709.
(Delete the attachments, if you want, Vitaliy. I moved the photos to Flickr)
@ Shian....might have to rethink the external recorder thing on this one ( ordered the Shogun 3 days ago)...I believe, from what Iv'e seen you do, this is the combo we've been waiting for and I'm curious as to where you take the image!!...Impatient for this update now!!
Time to go to sleep, till tomorrow.
I'd be curious to see how much noise in the shadows on the under exposed shots you get doing it that way. I'm exporting video clips to see, but so far this stuff is just way too easy to grade.
This shot is indicative of what I expect many users to deliver. https://farm1.staticflickr.com/626/20969187248_766d1fbe0b_o.jpg
All those shadow areas can't be recovered. It'll look like it's exposed fine, but if you try to lift those shadows and put them in the same exposure field as the rest you'll get some nasty noise. You pretty much need to let those fall into blackness.
The advantage of the extended DR in V-log isn't so much in terms of exposure, but in falloff.
