How does RawDigger deal with jpg in camera conversion?
Stop posting all this emotions, get proper tool
And let us know that you see.
Here is the jpeg ( compressed to upload ) but this is what it looks like ON the camera itself. So I am now leaning towards this being an issue with the camera itself!
Thanks @stucameraman1
I just went up to Algonquin Provincial Park (Canada) to shoot the canopy of all the leaves changing and accidentally had left my camera on JPEG mode instead of RAW so I just got home to check out the photos, and oddly enough ISO 100 is fine on the highlights no sign of pink anywhere, and on random pictures there are pink highlights right away without any sort of adjustments made. So I have now confirmed this is NOT just a raw problem!!
WHAT IS GOING ON!?!
Hi, after fiddling with Canon Magic Lantern RAW video for a while, DNG sequence, i was trying different programs to go from RAW data to CDNG, i remember i tried one of the few free ware software and it gave me like a pink tint ect, i remember changing the COLOR SPACE inside the software and the pink vanished! and displayed the image as i exposed it, Im not sure what color space GH4 raw stills belong to but try different color spaces within your software, so the software is applying the correct changes to the correct color space map.....something like that. Color spaces im aware of are RGB, sRGB, AdobeRGB, wide gammut RGB, CMYK (not sure if that applies to RAW), or even a 14bit image fitting into 12bit software settings??? Hope this helps, or maybe not but its worth a thought info - http://en.wikipedia.org/wiki/Raw_image_format stu.
The extended ISO helps when wanting to open the aperture for shallow depth of field. If the GH4 had ND filters built in, it would be unnecessary.
Panasonic doesn't provide 3rd-party software makers with information about how to decode the GH4's raw files. The raw format is proprietary. 3rd parties had to reverse engineer it. At least that's how it usually goes with raw formats. It's unfortunate and it's a good argument for the DNG standard format.
Thanks for that info that's great t know!
As for the software issues, it is definitely a software/profile issue that needs to be resolved. It happens on everything but silkypix so it must be an issue with how the gh4 profile was given to the different softwares to work?
I don't have a GH4 and I'm kind of guessing here, but if it's anything like the cameras I know, there is no point in using an extended ISO setting when shooting raw. An extended ISO setting of 100 will have the same highlight range as a native ISO 200, but less shadow range. The camera's display (and JPEG images) may show extra highlight range at ISO 100, but whatever extra range it shows would also be recoverable from a raw image at ISO 200. There's up to 1 stop of additional highlight range at all native ISO settings relative to the JPEG, depending on the white balance setting. Shooting raw at the extended ISO 100 can lead you to believe there is more hightlight range available than there really is, since the amount of extra highlight range depends on the white balance. Shooting at ISO 200 guarantees your hightlights are covered if the image is exposed correctly, regardless of the white balance setting.
If Silkypix decodes the ISO 100 raw images correctly and other software does not, it just means the other software is wrong. This isn't Panasonic's problem.
The situation is flipped when using extended high ISOs: the extended high ISOs have less highlight range and the same shadow range as the top native ISO, so again, there is no point in using them for raw shooting.
The bottom line is that the extended ISO settings are just for JPEG shooting. They give you nothing that you couldn't get with raw shooting at a native ISO setting, and the camera won't perform as well as in its native ISO range.
Thank you! This is exactly what I needed to hear. And thank you to @jjj_ri_usa for suggesting that iso 100 was the problem.
I never used Silky Pix so I will have to try using it for the ones I took already and go from there. I won't be using iso100 though and this definitely needs to be brought up to Panasonic.
I used Silkypix from Panasonic and the problem does not happen. I can only deduce that 3rd party RAW support does not take into account the extended ISO100 setting. I think I'll use Silkypix for ISO100 RAW shots and Aperture or Adobe RAW for everything else. It does make me worry that other issues may arise with RAW files at other settings in future.
I just did a proper test in Apple Aperture; RAW at ISO 100 and ISO 200 in manual mode with slightly clipped highlights and can confirm the pink highlights at ISO 100. This is an issue that should be brought to Panasonic's attention. My next test is to try different converter software.
I had the same pink highlights when loading your shots into Apple Aperture with the new GH4 RAW support. I have not had this effect with any of my GH4 photo's. Maybe you have a camera fault? Have you tried checking ALL camera settings to be certain there is nothing odd set in the camera?
For some reason, DxO couldn't load your shot of the stream (P1200485.RW2). Now it has and the pink highlight is very prominent. No clue as to cause save for ISO or camera problem.
I took a quick look at the headshot using DxO Pro (which I find superior to LR CC for raw file processing). The shadow from the pendant is pink, but not the pendant. I couldn't make the highlights go pink. DxO didn't recognize the lens, so couldn't do auto processing of the image. Agree using color card might help. I haven't seen this behavior at ISO 200 even with very high contrast subjects in bright daylight.
I'm no photographer, but had a quick flick back and found an iso100 pic with plenty of highlights pushed and pulled it to extreme and I couldn't get it to go pink. Just using Silkypix 6 that came with the camera to process it. Here's an example I also noticed that the examples you posted were all around the 16meg mark, mine all come out around 19meg raw for the GH4 don't know if that is something. https://dl.dropboxusercontent.com/u/99048946/pv/P1000753.RW2
Exactly! @joethepro
If I'm shooting in bright light, the lower the iso the better for me at least, but this sounds like a bug to me! I would love it if some other members could test this out for themselves to shoot at iso 100 and post the raw files to test!
@tylerknight The expanded ISOs on the lower side can reduce dynamic range slightly. Other than that, there arent really any drawbacks to using them, unless you get purple photos, then there is a huge drawback!
If it is an interpolated ISO, I would not use it unless I was stuck with too much light and no ND filter.
@MRfanny I was always under the impression that the lower the ISO the lower the noise? I know the 100 is expanded but I didn't think that would mean any less quality?
Either way, I won't be shooting at 100 until this is fixed. I would like to see if anyone else has the same problem shooting at 100 though. There still shouldn't be these issues I don't think
I've always stuck at iso 200. if your shooting at iso 100 your hitting the "low iso" settings right and thats not recommended.
https://www.dropbox.com/sh/vi9cfyajjsnfyvy/AADzvbTIF1QLug0VfDAMQP0ea?dl=0
Some more photos to try out at iso 100
The headshot is very subtle, but if you bring down exposure and look at her necklace pendant it is pink.
The over exposed one is just an example of it looking perfectly white, and then with any adjustments at all it will turn pink as well.
I think there is something seriously weird going on!
So you are definitely on to something @jjj_ri_usa !!!
The magenta highlights only occur on the expanded ISO shots. Anything that is 200 and up doesn't exhibit those issues!
My only question with that, is that I can take that same file shot at iso 100, edit it using the raw conversion in the camera, bring down the exposure and the highlights stay white, so it's something to do with the profile for adobe I assume?
Let me check my library to find one at a different iso! ( great thought though I will get back to you)
As far as the long exposure, I shot headshots for a political campaign and had the same issue. iso 100 again, canon fd50mm f1.4 with speedbooster. Same pink highlights.
As far as the ND filter, it is a low quality variable ND but the fact that it happens with or without it kills that theory.
Very strange. Your green channel seems to be clipped at a value less than 255? I notice that the ISO is 100. I don't have a GH4 (just a GH3). Does this happen for the native ISO (200) as well? I know that Panny does some tricks to get the non-native ISOs. It might be worth trying to duplicate this at ISO 200? Just a wild guess. Maybe there is some strange mis-match in their circuitry for obtaining the expanded ISOs? I also notice that it is a 20 second exposure. Are you using some ND filter that cuts out the Green?
