Neway CT700HO, 1280x800 IPS compact monitor with good features
  • 71 Replies sorted by
  • I didn't realize it was due to the specific new panel. I'll edit my post as I don't want to mis represent.
    thanks for the quick response.
  • I have been holding off on this monitor to see if they had solved the light leaks that plagued the CL76HO model.
    Plagued is strong word. 95% of light leaks reports are from small period. 100% of them are for their 600nit new panels. This panels are made for shooting outside.
    As far as I checked other monitors none of them have anything like it.
  • @wolfshooter
    Can you post a picture of the light leaks? I have been holding off on this monitor to see if they had solved the light leaks that occured in the CL76HO model (with new 600nit panel). I know IPS panels often have minor light leaks but I want to see if its in an acceptable range for me.
  • I purchased one of these through a deal (thanks Vitaliy) and got it shipped express for a job. It's very very light, just a fraction heavier than the Seetec 5.6" but the image is miles ahead of that monitor. I also have the metal cased 5.6" and it's about half the weight! It's also amzingly compact for a 7". Mine does have a few light leaks at the bottom edge - Neway tell me all of their CT700 monitors have this problem. It's an issue but something I can live with I guess. The false colour and pixel to pixel features are great and the image is just brilliant.
    Does anyone else have light leak issues with this model?
  • Does anyone know how the pixel to pixel feature works on this monitor? How do you move the zoomed in area? Unlike the CL76HO, this one doesn't appear to have 4 movement buttons - so is it time consuming to select the area you're trying to focus on (and is this possible)? Also do either monitors have peaking with colour image in the background (not B&W)? Thanks!
  • @MRfanny
    By idea they must work. At least never got any report that they do not work with something. I do not know that can be wrong with BMPCC.
  • thanks.
    can anyone confirm if this or these work with the BMPCC?
  • how does this compare to the 1280x800 IPS 7" NEWAY CL76HO-X.
    It is very similar, software is the same. It is smaller and simpler in design.
    CL76HO has brighter panel (600 nits), but have small light leaks (mostly fixed now).
  • how does this compare to the 1280x800 IPS 7" NEWAY CL76HO-X. which one is better and do any of these two work with the BMPCC?
  • @Sogdiec I'm not sure I understand your question, but this is not a 16x9 monitor. So you either have a black bar (which can show info) or you stretch the picture. Or is this a different issue?
  • @Sogdiec
    It distorts the picture in all modes. It is breakage? - this strip changes color and the accurate line passes on the screen? Or she is moved away somehow?
    Can you make better description and photos?
  • If this strip is technical malfunction - what to do? It is advisable to change the monitor. :(
  • I am sorry. I found as to increase the picture - the INFO button on 6D. Other question - I can't understand - for what a vertical strip at the left in 1/4 screens. It distorts the picture in all modes. It is breakage? - this strip changes color and the accurate line passes on the screen? Or she is moved away somehow?
    1024 x 768 - 62K
    1024 x 768 - 86K
    1024 x 768 - 91K
  • Anybody tried it with a BMPCC ? The Seetec and the Ikans don't work with it, while Marshal and SmallHD do.
  • @Sogdiec
    Make photo or short video, also tell your camera and HDMI mode.
  • I received the HDMI cable, I connected the monitor and. What it is necessary to make that the picture was on all screen? All buttons I tried, but the picture occupies the screen with a difference on 2 cm from edge. What to do? Here - in a subject - the picture is specified all screen, and I also hoped. Can settings in the camera it is necessary change?
  • Thanks for the feedback
  • @RatLabProductions see below extract from manual:
    474 x 653 - 159K
  • I can tell you that if you are using it for actual monitoring you really want the 7". I have it packed away in one of 25 bags of gear but I'll try to fish it out. It is very thin and lightweight, but once you put the battery on that is where the weight is. You won't regret going for the larger size.
  • I've been trying to convince myself to get the smaller metal cased 5.6" on deals to save some $$ and size but this compact Neway 7" monitor looks like its very much a superior on camera monitor in colour and quality and worth the extra $$. Time to make some adjustments to the budget. lol
    @DrDave - do you have dimension measurements for this monitor? I haven't seen measurements anywhere and the compact design looks nice.
  • Update: I used this on a big project over the weekend and it was very handy. I had ten cams and before the start I just walked around and plugged in the monitor to each cam in turn to check the exposure. Since I was looking at the same monitor for each cam, I was able to get a faster idea of the exposure and white balance issues, and the dual clip feature where both the whites and the blacks blink was better than just zebras for the white clipping to try and center the exposure on all the cams.
  • Одно уточнение - здесь общение ведется строго и только на английском?
    YEp :-)
    Power adapter и аккумулятора нет в комплекте. Все правильно?
    Right.
    По картинке в инструкции ко мне пришел переходник под NWNP-F960. Этот переходник не по размеру немного - не вставляется в монитор - рычаг Lock упирается в сам переходник
    And this is strange, send me picture in PM.
    В накладной указана сумма - восемьдесят баксов. Мне все равно, для меня нет разницы - что в накладной. И все же - любопытно - почему так? :)
    Just precaution (for customs).
    Кабель HDMI длиной 0,5м должно хватить при размещении камеры Canon 6D в клетке и монитора над ней? Или взять с запасом?
    Just get coiled cable - http://www.personal-view.com/talks/discussion/comment/68013
  • Здравствуйте! Одно уточнение - здесь общение ведется строго и только на английском? Хочу поблагодарить за доставку монитора - очень рад, впечатлен - внешне выглядит просто замечательно. Вопросы: 1. Power adapter и аккумулятора нет в комплекте. Все правильно? 2. По картинке в инструкции ко мне пришел переходник под NWNP-F960. Этот переходник не по размеру немного - не вставляется в монитор - рычаг Lock упирается в сам переходник. Придется подрезать/подпиливать его. Жаль, что такие мелочи не могут предусмотреть. А какие родные аккумуляторы идут на монитор? - чтобы без переходников. Или таких нет? 3. В накладной указана сумма - восемьдесят баксов. Мне все равно, для меня нет разницы - что в накладной. И все же - любопытно - почему так? :) 4. Кабель HDMI длиной 0,5м должно хватить при размещении камеры Canon 6D в клетке и монитора над ней? Или взять с запасом?
  • Does this have the same 600nit panel in the CL76HO-X?
    Nope. It has panel that CL76HO-X had before 600nit update.
