Apefos Scoperama Anamorphic Adapter Development Topic
  • 470 Replies sorted by
  • @apefos; how about including metal parts in the plastic construction? Like two metal shells with threads? Should be possible to create a relatively simple "mixed" solution.
  • I don't know to answer this right now, it needs research.
    But if I start to pursue the helicoid focus now, the project will fail. I would need to find another machining service or offer more money for my current partner. I would need to buy many pieces of metal, and metal is much more expensive than plastic, I would need to build some different systems to compare. Also metal would need another service after machining to turn it into black color and I do not know if this would change the behavior of the helicoid. So it would be "start from zero" again.
    I think it is much more important now I try to deal with the optical lab to improve the lens grinding to get the best approach in same thickness. Also do my best to get the plastic body working the best as I can do. And also find the best coating.
    If I can get a little more accurate thickness in lenses and the plastic body with a good alignment, this adapter will be a winner. It will work good at a good price range. This is what people call "best price/performance".
    Between the "impossible perfect expensive product" and the "possible good enough affordable product" It will be better the possible.
  • (sorry for going on, but I´m getting ideas as I think about it – I understand your reasoning)
    How about making bigger threads? Like, 2-3mm thick, relatively deep ones. Something like that should be possible to machine in plastic.
    Even lomo oct-18 helicoids are rather big:
    4976 x 2800 - 1M
    4976 x 2800 - 1M
  • The reason the helicoids have different threads is:
    smaller threads you need to do more rotations to move it some distance
    bigger threads you need to do less rotations to move it same distance.
    The camera lenses needs to be very fine precise focus, so they use small threads
    As the anamorphic adapters needs to move font and back much more than camera lens to do the focus, the best option would be the 3mm
    The problem for me is not to design it, the problem is to make it happen, to find some service that is willing to build it and do it in high quality. Also at this moment money is a big problem.
    But I will consider it for sometime in future. Maybe one year from now, or less if I can raise enough funds.
    Now it is impossible for me.
  • Donation sent! Keep up Your great work!
  • Thank you very much, I got the 25 usd. If I could get just more 9 donations like yours all the money problem would be solved to finish the project.
  • @apefos
    Man, don't worry too much about pricing now, that's, if i can give you an advice, the last problem you should put in the equation. I think you have to go for the best quality you can get, since there are tons of anamorphic projectors lenses that do their dirty job for around 100-150$. And when i say dirty, i say not like the iscorama, or the other winners. Here i think you are making a better product, and i agree with @RRRR for metal and bigger thread, and for his previous post too about website etcetera. Also, when it will come the asking money time, i think you will need to put your face on it (in a video where you present the item). This is the business as it must be if you do something new and if you came out of nowhere. Also, accepting all donations as part of payment for the finish project, will give you credibility. Wish you best luck. :-)
  • OK guys, about the helicoid:
    I decided to talk to my plastic machining partner one more time. I will beg them all the way I can. First thing I will say is:
    "I do not want you to say things are difficult to do, I just want you to say how much you want to do it. I will allow you to destroy some pieces of plastic on your attempts. If you don't want, or if you can't, just point me to someone else."
    Lets see what happens.
  • I think @apefos did a great job so far.
    @RRRR We work with metal only as that is what we are good with but for the anamorphic we did at one point consider using plastic housing instead. The Anamorphic attachment is usually heavy. The Isco has a metal housing and are very heavy. The LA-7200 has a plastic housing and it is much more comfortable to hold in the hand as well as attach on the taking lens. I don't think plastic is not necessary a bad idea.
    I think @apefos did not stress hard enough on the part where he said he need to figure out the right coating. It is much more difficult financially than it sounds. Maybe if you share your cost you have to spend every time you try the coating once/each time so that others on the forum would understand your concerns better.
  • It is good to see another manufacturer recognizes my efforts and my accomplishments. Thanks.
    About the coating, 250 usd will be enough to try the options.
  • About the criticisms, I like them, it helps me to improve the project. I just do not like when people say things like "completely unusable" because I believe this is not true. I like criticisms when it points the problem and try to help. This is good.
  • I found the problem in the night shoots.
    I used two prototypes, one for day and one for night. I did this to try a slightly difference in the lenses power, using the lenses I have from the first experiments.
    The problem was not the difference in the power, I confirmed the problem was the difference in thickness as I said before. Comparing the lenses used in day and night I found the day prototype lenses was good with almost same thickness in both sides of the lenses, but one lens in the night prototype was with a 2,3mm difference in thickness from one side to other, I measured with a caliper rule. This increased the CA and softness in one side. As I said before, when I lifted this lens one side using some shim adhesive tape I got a better balance in sharpness between sides, but the CA could not be corrected.
    So I confirmed the need for talk with the optical lab to ask them more precision when grinding the lenses. As I said before, probably I will need to deal with an error margin, but I will request them to do the best they can.
  • @apefos
    They can make some simple automated test for single lens (like making projected chart photo with automatic distortions detection)
  • @apefos: Good thinking on the helicoids..!
  • So this conclusion was important for me to discover the problem is not in the plastic parts, so the first final body will work. I will get the first body within this week and when I go get it I will avail the meeting in the plastic service to talk about the helicoid.
  • They have optical/electronic equipment to do measure lenses. I think what they need to do is a better alignment in the tools that hold and friction the lens in the machine which do the grinding. I will talk to them.
  • Very interesting to read every day your project ! Something goes here...
  • Thanks, stay tuned.
  • I think I have bad news. Kickstarter project seems to be denied. I read this in the project preview page:
    "This project does not meet the Kickstarter Project Guidelines. Adriano Apefos may disable this link at any time."
  • I need to say an important thing about the CA:
    After the optical lab improve the grinding to get the best balance thickness between the sides of lenses the CA correction will be very better as shown in the day shots (day shoot lenses was good in thickness).
    when I said in previous post that the CA could not be corrected when I lifted one side of that lens used in night shoots which shows difference in thickness, it is because it is caused by the angle formed by the inclination generated by the thickness difference. So lifting one side of the lens can help balance the corner sharpness because this aligns the curves between lenses, but it does not change the curves inside the same lens.
    As I said I will try to get the best possible grinding from the optical lab to avoid the CA.
  • I recommend you write to the kickstarter staff to find out what the problem is, if they refuse to help, there are alternative sites to kickstarter.
  • I already told that you do not need any of this sites until you want some publicity that they offer (usually only first day and last one).
    Just make simple one page site with big paypal button.
  • As I promised, here it is: the first Apefoscope assembled unit. The black plastic body with focus mechanism.
    I followed @Vitaliy_Kiselev advice and I created the donate button in my website. You type the amount after click. I need a total amount of 250 usd to finish the coating tests. So @others can donate.
    My website is: http://www.apefos.com
    It was just five days delay from plastic service to get it ready.
    The body alignment is ok.
    There are small scuffs in the edge of lens and this normal from grinding and do not hurt image quality.
    I removed the front clamp from the body to allow it goes a little more wide.
    The front lens now is fixed with dark grey cement.
    The big screws can be black painted if you prefer.
    The two small screws in the front part is for allow hold the part to move it.
    The three screws in the back part is to fix it after doing focus.
    The rear thread is 52mm, step up or step down rings can be used.
    Focus is from 51cm (1,7 feet) to infinite (measured from the front of adapter using Nikon 35mm AIS lens)
    It works in GH2 with 35mm and 50mm full frame lenses. With the kit lens you must set it to 42mm.
    I will do tests to find the focal length to use it with APS-C and Full Frame cameras.
    ND filter can be used between the adapter and the taking lens.
    The weight is 125 grams (4,41 ounces)
    I will wait until I do the review before start selling. So buyers will know exactly what they will pay for.
    1920 x 1080 - 118K
    1920 x 1080 - 122K
    1920 x 1080 - 116K
    1920 x 1080 - 123K
    1920 x 1080 - 129K
  • About the helicoid:
    The plastic service will give it a try, but not in the body, it will be a test in two pieces of plastic, an attempt to make it works, I will use the first donation to pay this test. Price increased a little in the two helicoid parts, the male and the female, other parts keep same service price.
    The body will need to be completely redesign because two ring movements need to work together, one for distance focus and one for cylindrical focus. I did some draws yesterday night and found the solutions.
    I decided to release the product with the first body because it works pretty good. The helicoid, if it happens, will be a future product, more expensive due to a more complex body with more parts, more plastic and more service. And at this moment I will do just the first test to know if the helicoid works. The body development will be delayed until I make money to work on it, so it is a idea for months in the future from now.
    the coating tests and the replication of the finished unit is the main goal now.
  • Two donations until now: 35usd.
