OM-5
Dynamic Range comparative E-M5 vs GH2: http://peterfraileyphoto.blogspot.com.es/2012/07/olympus-e-m5-post-11-dynamic-range-part.html
One thing that I don't quite get: the manual claims that, when shooting movies mode from A or S mode, the movie recording uses the same settings as for stills. However, even if fixing ISO at 200, and setting the shutter speed to 1/4000th in S mode (which, in a dim environment will produce pitch black stills of course), I still get properly exposed videos.
New firmware available
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1583&os=w
OM-D E-M5 Version 1.2 Updates
Added function to automatically move focus to the following zoom positions when underwater macro mode or underwater wide mode is selected. (Only when M. ZUIKO DIGITAL ED 12-50 mm F3.5-6.3 EZ is attached)
Took my OM-D for a locations / inspiration scout to the central highlands. Nothing too elaborate. I'm no pixel peeper, but low bitrate makes this camera unusable for serious work: High detail + fast movement totally trashes the footage. But the image stabilization is very interesting. Shooting handheld footage with only this small camera gives you such flexibility and ease that I feel it can really add another dimension to shooting video and you end up doing more shots and finding more creative angles because of it. Don't take this compilation of shots as any indications of the IS - it was just a locations scout :)
Oh, and let's admit it: It's a fashion accessory as well as a camera :)
Some really nice pics with Leica 25/1.4
http://www.flickr.com/photos/cempayzin/sets/72157630429515370/
One of the things I like about Dpreview is the frame where you can compare 100 percent crops of different cameras. If you Navigate to here http://www.dpreview.com/reviews/fujifilm-x-pro1/23 And plug in, say the E-PL1 and the new Olympus E-M5, what I see is that the new camera does slightly out resolve the E-PL1. But it isn't a huge difference. Both the E-PL1 and the E-M5 see noticeably better than the Fuji. Still, cameras are getting better. I won't buy a new one till I see the GH3.
sorry about that.
Please, do not post unreadable things next time.
it seems to according to media inspector:
Audio Stream #1
    Codec.............................................PCM
    Codec (FourCC)....................................sowt
    Audio Stream Length...............................15s 40ms
    Audio Stream BitRate..............................1 536 Kbps
    Audio Stream BitRate Mode.........................CBR
    Number of Audio Channels..........................2
    Sampling Rate.....................................48.0 KHz
    Bit Depth.........................................16 bits
    Audio Stream Size.................................2.75 MiB (9%)
