This should work.. http://www.amazon.com/Fotodiox-Adapter-Olympus-Thirds-Panasonic/dp/B002TSWTAA/ref=sr_1_1?ie=UTF8&qid=1337910017&sr=8-1
Back to Sanity
Thanks
Just posted a video review for the EM320E shotgun mic, using the Sanity 5 and Pasedena Pulse audio patch:
Shot on the 20mm pancake with autofocus enabled. Dynamic picture style -2, -2, -2, -1 ISO 400, F2.8 Whatever the white balance is that looks like a circle with little lines emanating outwards all around. Incandescent? don't know....
Straight out of the camera, no mucking about it post.
How do I use Sanity 5 with Pasedena Pulse at the same time?
@yoclay It's really impossible to compare the two (Really with Driftwood's it's 3 latest) because they are targeted at different uses. Driftwood's settings are amazing and I do use his night settings for certain night shots. I do almost 100% run and gun and for that, Sanity 5 is far better. I'm still not completely convinced Sanity 5's lower bitrate is better than some of the older Sanity versions...but I'm not convinced it isn't either.
If I only did planned cinema shots, I may be temped to use one of the High BR settings from Driftwood but for a single very high quality and versatile patch, Sanity is hard to beat. Then you have to look at Flow Motion also (Which is geared more to MPEG).
What I'm saying is that there are a lot of very good settings to choose from. Try them all and see what fits.
@subco uploaded a merged patch here near the bottom of the page. Use the second one (setb.ini)
Tony
@tcarretti I dont see anything?
Sorry! Thought I posted a link...
Just go to page 8 of this thread and you'll see a post by subco (second from the bottom, I think...) Use the second file (or setb.ini) as he suggests.
@tcarretti Alright thanks!
@tcarretti Oh and I know you were talking about trying different export settings for your videos sometime ago but I would say export you video out as a Cineform.avi format with filmscan 1 and with yuv 4:2:2 selected then after that take it into virtualdub and export out as a xvid video file for the web
+1 on Cineform - it has been my "digital intermediate" codec and workflow for years now. However, for online videos, I recommend the export settings described here: http://walkingad.com#SDXC
@mo7ies Well yeah if I had of gone in depth on the xvid part the settings would have been pretty similar to the ones on that link
getting write errors with sanity 5 on sh and h modes with a sandisk extreme class 10
@RandyCatanach - errors on which card?
I'm using a sandisk extreme 16gb 30mb/s which has worked fine with QuantumX and other super high bitrate patches so I thought this would work fine too.
IMHO, Sanity v5 is such low bitrate, you can actually use its 24H video mode for timelapse. Simply shoot video and in post, speed it up however you like. Added bonus: gives you variable time control in post, up to real-time 24p - try that with photo timelapse ;)
http://www.personal-view.com/talks/discussion/3305/timelapse-with-sanity-v5
I'd like to try out Sanity 5 mixed with the Palais Audio (for my news work - shot 1080i50 for broadcast). There's a combined patch on page 8 but I'm not sure how to access the .ini file (I thuoght I could right-click to save/download, but no luck). Any suggestions?
Apologies for the dumb question.
Yes. Firstly I have this patch http://www.personal-view.com/talks/discussion/comment/24194 but the AVCD in it is to hard for me but in sanity 5 I cannot make MJPG 2 fps manualy or another way I'm trying to combine this 2 patches but it is not good idea . I can not find the simple only for mjpg timelapse patch wich not making influence to the sanity 5
Vitaliy_Kiselev
13904
stonebat
3613
driftwood
3036
