@Estie P=progressive and i stays for Interlaced. To be precise the 25p mode on the GH2 is in fact a 50i internal rewrapped to 25p, but it´s only for this case. It´s better to shoot 24p or in the 720 modes this looks almost the same of the 1080 modes. Try to compare the same shoot on 1080 and 720 in two different layers on Photoshop or Gimp you can´t see differences in resolution..
@rajamalik Playback is fine i only see the heavy interlacing on the computer. i did try 24p and it was better does this mean 24p is progressive ?
sorry just trying to catch up with all the info
@blackspot after sedna was rep leased gh2 separates color better than 5d. infact 5d mark 3 footage is not comparable to sedna A footage,.. gh2 killed 5d mark 3 in every aspect grading color specification ad details. as sir @driftwood now gonna release a green screen version it would be 10 times better than 5d mark 3 green screen shots,.. 100% you can be very sure that it would do well in keying and graphic composing
IN regards to greenscreen, GH2 keys MUCH better than 5D in my experience. You simply have to either balance the green cast out in camera or in post before you key and you have to get the subject further away from the green in general.
The 5D makes it easier out of the box, you can separate the subject and background by shooting a wider aperture, but if you can adjust for these things then yeah, the GH2 is much better for keying/compositing.
@driftwood...I would love to see an optimized green screen patch too...you could call it "the Green Lantern"...:)
@driftwood I am very interested into a setting optimized for greenscreen!
@Estie There is a huge difference between 1080i 50/60 modes and 1080p24. You can record 24p and later speed up to 25 FPS if you want to create DVD or Bluray from it. Your interlaced footage can be deinterlaced to play back on a computer.
I hope my small donation helps :) Thanks @driftwood, Vitaliy_Kiselev and all the others helping out
ps: i dont want this to sound like a stupid question but i Just tried using the VY Canis Majoris 'Night' patch with the Voigtlander 25mm but my videos never look as sharp as the others users. Checked the focus, F-stops and everything else and results are still the same.
thanks and i hope im not bothering anyone
Both videos were no longer than 1 minute
@xavieramelio @gokuan003 @Kihlian I bought it. Its made in Japan. Its perfect.
Love your work @drift!...
@ChainsawFilms @Driftwood Actually that would AWESOME IDEA!! to have CM GreenScreen- version, since the GH2 greenscreen capability is not too good at the moment. 5D still kicks GH2 ass when it comes to GS shooting. GH2 low level noise and pretty dominant GREEN CHANNEL/GREENISH TINT overall causes some problems with greenscreen.
Driftwood, what do you think?
@fohdeesha I think some of the energy got re-directed by the discussion of different chroma/interpolation approaches. No need to get frustrated that people may not have felt sure about what to post after the reaction the first response. I say this not as a criticism, but as an explanation for the lack of response.
You mentioned that you had not had to set the key this wide. Perhaps if you could document setting the key under similar conditions for different cameras/settings it would be easier for those who modify the settings to try to ascertain a solution. As it is, it may be difficult intuit what combination of factors is causing the issue.
So if you shoot the exact same controlled light scene with different settings (but the same light) and possibly a camera that handles it in a away you like better (preferrably with the same lens or at least the same framing, shutter speed and ISO) it should be a lot easier to diagnose. Best of luck getting assistance to figure out the problem.
I'm hoping to do some greenscreen with Night this weekend, have just put it on the camera.
I don't suppose we're going to be seeing a specific CM Green Screen version are we? :)
@xavieramelio It also comes from Hong Kong for about the same price. I think it´s not a fake, are all taked from a boundle. The problem are the costumer fees..
About Lumix 14 mm,I know it is off topic, but do guys think this deal is a fake:
@gokuan003 Lumix 14mm pancake is the best
@thepalalias Canon EF-S 10-22mm, it's not bad! ;) For cons I fear that there is deformation in the movement
