GINI cage for GH1, GH2
  • 95 Replies sorted by
  • Well, I hope that Camera777 website is legit... because I just ordered a cage. The Service Terms that you have to check off are blank (just say 'insert rule content here'), but it accepts Paypal for payment at least. Fingers crossed.
  • @rockroadpix & @feha - Do you find there to be a fair amount of wiggle or "twist" because the camera is not secured at the top of the cage from the hot-shoe?
  • Yeah, I got mine off ebay, too.
  • @IvanUskokovic , I did not order from that website yet. I bought on eBay but I got that link on paper from the same guy I got the cage.
  • Sorry if I missed it, but - can one or more people confirm whether or not this website is legitimate in where to purchase the Gini cages: http://camera777.com/ ?
    I contacted the seller through the website 24-48 hours ago and have not received a response.
    I also found it weird that the same GH2 cage is listed three+ times on the website priced a little...funny.
    Your help is appreciated.
  • @Gabel , the top plate have about 20 of 1/4" holes, the rest of holes is M5. New cage have more space for mic jack. I got my new cage (rig combination) and need a bit of time to make a video review ...
  • Does the new GINI cage (GH2 version) have the special sized holes, or regular 1/4"?
  • Here is a new website of Gini and their GH2 cages: http://camera777.com/
    I think they have good prices
  • @fosterchen , looks great, very compact for the GH2 size :-) I'm waiting for the same one, should be here in few days.
  • Got my Gini Cage Rig...It really is solid. Pictured with the modified Rainbow H6x8-II C-mount lens and the Fifty Dollar Follow Focus.
    4608 x 2592 - 2M
    4608 x 2592 - 2M
  • I just received my gini cage and I have to say that for the price, I am impressed. I still wish that it had a contact point on the shoe, but it seems really rock solid once the cam is in there.
  • @feha Thanks, just started a new topic, i will see what i can do. Anyone near Richmond UK that have a Varavon loupe that i can measure? (How busy are you Mr. Philip Bloom.. ha ha)
    You are right I don't think anything or venture is guaranteed and without any risks but i'm trying hard to take most of the risks. I am currently financing the development and initial production of the first 25 or so.
    Just in case anyone is wondering about quality; the factory i'm using also makes parts for Formula 1 racing and the Military Aerospace.
  • @jakef , i just wanted to show that luope won't fit to this cage ... the uni loupe might work ... If you think to build new cage for GH2 you can start a new topic ... there have been many topics about building a new GH2 cage but not many resulted to final product.
  • I see does it hit at the top and bottom of the cage? 1. where should the top end: distance from base of camera to top csage opening 2bottom clearance frombase of camera to base of opening of cage?
    Where do you want to mount the the 2 screws, do you mean a new bracket (or modify) and screw holes to clamp the slider part to the cage.
    I'm sure you've noticed that the original bottom blate of the loupe cant fit with the camera also you'll loose the camera cage clamp.
    Should we start a new thread? i think we are mixing topics.
    Regards
    Jake
  • @jakef , the Varavon GH2 loupe, does not slide in completely, as there is not much space between folded out lcd and cage. If there would be a place to slide in completely than the gap between mounting bracket of luope and cage would be less, also the loupe screws could be mounted into new drilled holes ... Check images below.
    1500 x 1125 - 197K
    1500 x 1125 - 192K
    1500 x 1125 - 148K
    1500 x 1125 - 131K
    1500 x 1125 - 148K
  • How would you attach the varavon loupe to the cage? Just asking as im currently finalising cad drawings being done for me of a new cage for the GH2, i should have the prototype machined by next week hopefully, it not that simple to machine a cage from a solid block of aluminium.
  • @jshzr , great. I wish there was a place to mount my Varavon loupe for GH2, but in any case is a good investment.
  • @feha - yup got the cage and used it on a wedding. As you described on the video, its a bit tight for the MIC adapter. I had to remove the camera from the cage to remove/add the L shaped mic adapter. Overall, It does what I want it to do. Was able to attach LED panel and Mic to it. Also, the added weight helps w/ flying the Glidecam HD2000.
  • Ditto. Should have it by end of month.
  • Just ordered one. I'll post my thoughts next month when it arrives.
  • @jshzr
    Did you got the cage ? Your impressions ?
  • I hesitated to place an auction on this one too but I chose the "regular" version (no cage,with a baseplate and I Focus), looking forward to your review.
  • I won on auction a new GH2 cage that works as a rig configuration. Waiting for it, will make a new video review about this one too.
    463 x 463 - 26K
    500 x 393 - 22K
  • @jshzr , they did rework on the cage, hope you get the right one ... Here is part 2, talking about mounting options ...
  • @feha looks like they changed the right hand grip portion of the cage for easier access to the knobs. Thanks for the vid review
