@onionbrain thanks for the insight. I'm finding everything you're saying to be true, regarding Vibrant. I've been doing high ISO, high dynamic range scenes, heavy grading, etc. and Vibrant just holds up the best to everything. I compared the 5D (Neutral profile -2, -2, 0, 0 and Technicolor -2, -2, 0, 0) to the GH2 and thought it looked overly washed out and maybe favored green a bit too much. The GH2 color is a way more accurate, actually. It's kind of reminds me of Kodak film vs Fuji.
I've only had my GH2 for a month, but I can't believe this camera isn't getting more attention. It's really amazing. This camera is 700 dollars!
EDIT: Here is a good starting point for discussing Color Profiles and Film Modes, all in one place.
http://www.personal-view.com/talks/discussion/461/gh2-film-modes#Item_84
@proaudio4 Glad those tests are of some use.
@dbp > "I'd follow the whole "shoot flat, grade to whatever" workflow if I was shooting Red Raw files, or even AVC-Intra 100 10 bit 4:2:2, which grades far better than any GH2 hack."
That certainly is a valid point.
@rajamalik I just forwarded you what he said about it and asked not to pressure him about the settings. But it's all good. :)
I quoted what he said for you - he's so busy he didn't even have time to post and asked me to do it for him.
Hopefully, I can get back to more testing this weekend. But the test I performed last weekend (posted here), shows that Mysteron is VERY close to Sendna A AQ1. @thepalalias tests above also show the same thing.
I use -2,-2,-1,-2. Saturation at -1 seems to be the "sweet spot." -2 on saturation and it looks exactly like an HVX200 (a camera that records 4:2:2 color). 0 on saturation is a bit heavy handed.
whats the recommended setting for vibrant? 4 X -2 ?
@Zaven13 cool! thanks! will try it next.
@onionbrain okidokie will be testing vibrant then! ;) for Mysteron 4x-2?
@luxis. I am attaching the zip file for the settings. Try it. I think you will be pleasantly surprised with the results. Thanks again to @driftwood, @Ralph_B and @Vitaliy for their great work.
                  @peternap All my thanks!
@adamquesada My thanks! Sedna or Mysteron (that I assume was an experimental version of "Canus") are both great and I've already used both in footage for productions.
@modernhuman I agree on Vibrant and use the settings you noted. The "dynamic range" complaint is a myth from people who refuse to understand levels/curves adjustments. Vibrant is very mildly blurring the chroma channels -- meaning it's creating the closest thing to 4:2:2 footage you can possibly get off this camera (and the colors handle better than "Standard" in post). And, that's why it's the cleanest (relative to noise) profile on the camera. And, because it's cleaner you can raise mid tones and shadows to higher levels -- resulting in more usable detail (broader dynamic range) than other picture profiles.
Regarding Smooth -- it's exactly Standard with mid tones raised slightly.
@shian See above response. And, relying on any single "plug-in" doesn't replace actually learning the fundamentals of color correction and enhancement.
@Zaven13 how can i try these settings? do you have a link for it?
@Zeven13, I've used your hybrid for several projects and it works great. No problems at all. Zip. Filled two 32GB cards on one shoot without any errors. I think I have the Sedna Q20 and Sanity 3.
This is one I did with 24p. I also used Shian's ColorGhear.
BTW the lighting was difficult because they were switching between floresent lights and warm lighting and my white balance was off. Still looks pretty good though.
STRESS TEST MYSTERON + SANDISK 30MB/S 32GB
@jfro , this is continuing what we talked a few days ago.
-This is only a stress test. Don't look at the composition, focus or motion blur... it's only about bitrate & writing speed errors on the mentioned card-.
Everything was shoot on 14-42 kit lens at 14mm & f8. shutter around 100, iso 320.
-1st shot (clip 41), 24H, smooth -2-2 0-2 / walking--> Got a stopped with a speed error at 1'30" aprox.
-2nd shot (clip 43), 24L, smooth -2-2 0-2 / only moving the camera around--> Stopped MAnually at 4'30" aprox.
-3rd shot (clip 44), 24H, standard 0 0 0-2/walking --> Got a stopped with a speed error at 2' aprox.
-4th shot (clip 45), SH 60p, smooth -2-2 0-2 /walking--> Got a stopped with a speed error at 3'30" aprox.
-5th shot (clip 46), 24H 300%, smooth -2-2 0-2 /walking--> Stopped MAnually at 10'30" aprox clip length 3'20".
-6th shot (clip 47), 24H, smooth -2-2 0-2 /moving the camera/ the subject was less busy that shot 1. Did that in order to try improving recording time--> Got a stopped with a speed error at 3' aprox.
-7th shot (clip 48), 24H, smooth -2-2 0-2 /walking / Another variation, walking. This time got stopped with a speed error at 4'10" aprox. File size 3,99GB. Span error (the only one I had in this test) All other files were smaller.
CONCLUSSIONS:
Mysteron is great, at least for my needs.
You can get wide shots (usually for establishing purposes) 1'30" should be enough.
If you want to shoot a time-lapse using video, go for the 24H 300% or the 24L settings. Or better, get an intervalo-meter (20 USD on ebay) and do it properly with manual lenses & stills (JPEG/RAW).
720 60p works great! 3' should be enough for any slow motion!
If you are following an action, it should be a similar situation from my test "7th". I got about
4 minutes 3.99GB. The limit is the span.
Thanks VK & Nick Driftwood for making this cheap plastic box a real video camera! -with intra-frame Super Hi bit-rates!!!!!
-It's much more than I expected for the price!
note: with the same card, I couldn't get 60p with sedna.
-Hope it's clear and will help.
what so wrong with standard then? 4x-2
I'll be covering the different modes and their effect on dynamic range in the CGT Film School series (I've already covered "smooth").
And those shooting Vibrant clearly aren't using ColorGHear, or otherwise they'd know better to squeeze as much detail as you can get into the image at the extreme ends of the dynamic range first, and then let more powerful processors and algorithms handle contrast and saturation in post.
@yeehaanow. If you are interested in a good 60p to combine with Driftwood's 24p settings, I am using a hybrid setting that uses Sedna A Q20 for 24H, L and Sanity 4 for FSH, 720p60 and HBR. However, I am using Sedna matrix for Sanity instead of the stock matrix. I am very happy with this combination setting. I am getting anywhere from 35 - 50 mb for 60p, FSH and HBR with great quality. BTW, Sedna A Q20 in 24L with averaging 75mb produces great image quality and it spans. All of these modes work with Sandisk Extreme HD 32GB 30mb/s card including EXTC mode.
@conscius nice waiting for the shortfilm with Sedna q20 ver.A settings
@rajamalik (@adamquesada) see, link below, there is no banding problems with it, it's "Sedna Q20 ver.A", but there are videos with for example Sedna's incl. AQ1 ver.A, raja I know you are still fan of it, ver.B C etc. and even Q20 ver.A with (incl. blue sky) banding problems. But no problems with this one Q20 ver.A, see also comments there, vimeo.com/39188868
@all Isn't it strange? (some with problems and some not, they are all shooting respectively with same settings/mayne even setup)
Thank you @dbp, seems that we have come to a similar conclusion. Although, with numerous tests, I don't think smooth has, in the real world, anymore useable dynamic range. But it does have less contrast, in the low mids. So that could equate to less noise, if you're not having to push that range up in the grade. Either way I think I'm liking vibrant more and more.
@RRRR I definitely agree that neither profile, nor camera, have perfect colors, but Vibrant has far more color information, and the greens and reds have a more natural appearance. As for underexposing or shifting the histogram left, instead of right, I will have to do more tests. Ideally, the lighting is controlled and the exposure is correct, but when shooting in a forest or some difficult location, underexposure seems a bit more favorable. Definitely, overexposure (and pull back in the grade) is a terrible idea. I guess I'm just saying err on the side of underexposure, when in doubt.
regarding grading e.t.c. Gh2 footage holds up well enough to be pushed pretty far. The only difference when grading and choosing color profiles is if you want to push or pull color. Vibrant is no more natural looking than the others, but you might think so if you have shot a lot with Canon. Unfortunately there is no truely flat profile - such flatness has to be achieved by other means: lighting, filters e.t.c.
IMO the old underexpose trick does not work well with the gh2. Instead I prefer to expose as far to the right as possible on the histogram, meaning that I do not have to lift areas that are likely to have noise in them.
But if you have a gameplan for a certain look and know you can achieve it with good results, then that is a good gameplan and one you shouldn't doubt too much.
My humble opinion about ISO, fundamented on a few tests I've done while trying to access the relation ISO/bitrate spending: avoiding the ISO bug, ISO160 is definitely the cleanest and ISO320 is cleaner than ISO640 so I believe base is ISO160 because noise & bitrate rise normally and linearly.
@Mr_Moore said:
"We don’t know for sure, but I believe the reasoning is as follows. The base ISO for the GH2 in stills mode is 160. Assuming that one video pixel is interpolated by using four stills pixels, 160 × 4 = 640."
@duartix thinks:
I've seen that logic repeated, but not knowing whether the sum of the pixels is averaged in the end, can defeat it instantly.
@modernhuman I've been sold on Vibrant as my goto setting for a while. It seems to be the cleanest, and to my eyes, it does offer the best color. The biggest difference is in the greens...Standard and Smooth, even with additional saturation to match Vibrant, have weird looking greens to my eyes. Especially smooth.
I'm with you, too. I'd much rather take away saturation then add it back in on an 8 bit 4:2:0 codec, regardless of the bit rate.
The only time I'd ever shoot smooth is if I was 95% sure that I wanted a flatter, desaturated look as my final look. Whenever I'm not sure, and I want room to mess around, I'll go with Vibrant. It may not have the highest dynamic range, and you may be stuck with the contrast, but you have to make compromises somewhere. I'd follow the whole "shoot flat, grade to whatever" workflow if I was shooting Red Raw files, or even AVC-Intra 100 10 bit 4:2:2, which grades far better than any GH2 hack.
new shortfilm I filmed for a friend. Sedna A Q20 (L settings)
Later this week I'm going to shoot my own shortfilm. I'm going to use Sedna A Q20 24p H.
