http://skiboblog.skibovision.com/?p=1
quick little thing I put up with links to a great program that unlocks GPU for mercury playback. This is only reccomended for GPU's with minimum of 1GB RAM.
If the "tool" is some sort of registry editor, you don't want it. Just follow the simple steps: Enable premiere in the Nvidia control panel, and add your card to the text file for supported cards. DOH!
Using a tool did not work for me a while back either (if this is the same one). I wish it did because I did not know about the other method and returned the card (and my Premiere Pro trial expired before I heard about the other method).
Hi Vitaliy, I just wanted to wrtite what worked for me.. I had that tool (from studio1production.com I think) and my PPro cs5.5 didn´t recognized my GTS450 after using it (I have a PC).. maybe it was only in my case.. but only after adding manualy my card to the cuda list worked fine.. I´m not an expert.. but I think it´s fine when users know about other alternatives ..
http://www.personal-view.com/talks/discussion/2752/about-forums#Item_18
Here we have good example of one of common things to forums.
Someone is making tool/description making it simple for more people to do something.
Instantly many "experts" arise with references that it is already good and simple.
May be, but in most cases it is not.
all you need to do is search for a cuda_supported_cards.txt file ..open it and write your card name in the supported cards list..
You just edit a text file, the info is all over the web.
You don't need a program, it is a simple unlock.
It's great. As I said in my post I picked up an Acer Aspire 4830TG with the Nvidia GT 540m. It was a $650 dollar laptop.
According to this link you would normally be required to spend a great deal more money to get something thats approved
I am sure that we had something like it few months ago. But without program as I remember.
