Driftwood Quantum X Settings, Series 3: VY Canis Majoris, Mysteron, Sedna, Orion, Cluster...
  • 1046 Replies sorted by
  • Sorry if it's boring or well known to anybody except me. I was looking for a topic but I couldn't find any. Is there a well-defined recommended patch for 25p/HBR with best image quality? If I understand right most of these settings focus on 24L but I sometimes I need the GH2 as a second simultaneous unit with an other 25p PAL camera. Thanks!
  • Think of how sharp pin hole cameras are, and not just due to movement, and there you have a perfect example of diffraction.
  • +1 on the f8 thing. I think diffraction looks horrible on images but an ND stops you having to increase shutter speed, which is the only other alternative, and that also has its own weird effect on video. I guess with most lenses there's a happy middle range of apertures which work well but the Panasonic ones seem particularly bad.
    I have a video camera lens which I adapted from an old tube camera, and that has a continuous aperture which can close completely (most video lenses do this on older cameras). At the point just before it closes it creates some VERY strange effects.
    EDIT: While not strictly relevant to these settings, actually in low light, you also have to stop down a bit on some lenses (to sharpen them up a bit) and now I'm finding that with the better settings you can do this in low light with very little noise penalty - and what noise there is can often be pretty much eliminated with Neat NR.
  • @Tifose It doesn't matter. You can use the cheaper old fashioned non-variable, or you can use the relatively new variable. Both have strengths.
    @conscius Yes, in a big way. I only own two Panasonic lenses -- but that was absolutely the worst softness from lens diffraction I've ever encountered.
    @duartix Definitely not a "non issue" with that Panasonic lens.
  • @onionbrain : It should! http://www.slrgear.com/reviews/zproducts/panasonic14-45f35-56g/tloader.htm However with all the binning and reduced resolution in video, I though this might be almost a non issue.
  • I've just ordered a 6-stops ND filter. Really needed for outside when the sun shines! :)
  • @onionbrain do you mean Variable Range Neutral Density ND filter ?
  • @onionbrain I tend to stay around f8 on wide shots from my photography days i have always liked to keep my aperture around there its just translated into my video work. good shout though, my footage has been sharp enough so i was wondering why people where commenting on soft footage.
  • A quick note about diffraction...
    This may be of some use to some of you, especially those newer to DSLR (or EVIL) video.
    Lens diffraction translates into meaning that when you stop your lens down past a certain point -- the image gets soft. In very general terms this usually means your lens is sharpest between f/8 and f/11.
    So -- I was just outside playing with stuff and I had the Panasonic 14-42 "kit lens" stopped down to f/22. When I came back in the footage looked soft -- as if the people complaining about sharpness with Sedna were right. Then I placed an ND filter on the lens and went back outside and filmed the exact same stuff at f/8. The difference was HUGE -- beyond anything I've ever encountered on a Nikkor or Canon lens. Really -- HUGE -- like two different cameras. This was the worst lens diffraction I've ever encountered.
    So, if you're using these Panasonic lenses (especially this "kit lens"), be aware that diffraction appears to be a MAJOR issue (far worse than Nikkor or Canon). You not only need an ND filter for wider apertures -- but you REALLY need an ND filter to keep your lens at or below f/11.
  • Sedna is working well for my workflow so far, need to make some field tests this week. but its looking promising. still torn between the looks of Orion 4b though. first thing is to get a new ND filter mines starting to reflect sun light big time.
  • Latest project I did using Driftwoods Orion Patch
  • @Kihlian Yes. It handles red noise better and does slightly better with green noise in gray areas.
  • For Q20 B..
    60fps FB2 = 472000 60fps Frame Limit = 1600000
    Isn't FL = FB2 x 8 ??? 472000 x 8 = 3776000 (not 1600000) or 1600000 / 8 = 200000 (not 472000)
    So shouldn't FB2 be changed to 200000 for Sedna?
    Or does this formula for Frame limit and FB2 not applied in Sedna?
  • @LumixUser looking forward to your test, I have the same feelings about sedna. I wouldn't say it doesn't hold up, just that you can't push it as much as say orion 4b. But I've only had experience (and brief too) with the Q20 versions. It could just be I've not stared at nor pushed enough sedna footage though.
  • @act : Great editing on what seems to be an amazing party.
  • @onionbrain I'm not playing wery long with the GH2 and the hack settings. Have a beginner question, is Sedna also better in low light than 'dark matter'? i mean less noisy? Thanks in advance.
  • Hi guys, I still didn't understand why some people prefer Sedna q20 to Aq1... Why someone would prefer to have less infos in the file?
  • @LumixUser Remember that conditions need to be identical for any "testing." I've thrown out over 90% of the comparisons I've done because of a change in some condition. One of the most frustrating issues I encountered is that the camera makes certain changes when you update the firmware -- including screwing with custom white balance settings on some occasions (so dial in a number or use one of the fixed settings).
    In an ideal world you can stare at the same subject under identical conditions -- and use a split screen for comparison. It's a challenge and problematic to accomplish this -- but when it's done right -- those are the results you can trust.
    Simply filming stuff at different times of the day and "eyeballing it" and calling that a "test" is essentially useless in terms of a comparison.
    And, it's precisely because of a properly done test as described above that I'll tell any of you with confidence that Sedna beats 9b on a range of levels. 9b was superior to the original Orion, and 9b was essentially indistinguishable from "dark matter."
  • @LumixUser can't wait for the Test. :)
    Anyway shooting a movie with Sedna!
  • Remember to buy some milk for those words, they're quite dry without
  • I think Sedna is way better filmic-wise The others are closer to a sharp digital look
  • if Driftwood say Sedna is better then it's better!
  • @LumixUser 244 was a Wow for me, Sedna is great but i wish someone would do side by side with the two
