Thank god, thx balazer..........
The Extreme HD Video cards are the recommended cards, and they are very common.
Indeed but those cards are hard to find. even if you find one, they send you something else.
I did have orderd a two weeks back a 32 GB SD Card Extreme SDHC Class 10 SanDisk with 30mb/s But it was off stock, today i did get a mail that i will have in two weeks from today. But they have updated my order, and it displays now the Sandisk Extreme HD Video 32 GB And if i read this topic good, then that cart is not good enough.
by the way, thx for your response balazer
Just like it says at sdcard.org, SDXC is differentiated from SDHC only by card size (and filesystem). SDHC and SDXC cards both come in different bus interface speeds and speed classes. Different cards with the same speed class often have very different performance.
The 45 MB/s cards are fine for an unhacked GH2, but not recommended for higher bit rate patch settings. Stick with one of the recommended cards, as described in the personal-view FAQ.
I have the Sandisk extreme pro SDHC UHS-I 8gb 45mb/s card.
Its performance is disappointing.
Now i am reading in this topic that the gh2 doesn't take advance from the uhs card.
Still, on there website its announced as supported?
Even the manual says SDXC!
http://panasonic.net/avc/sdcard/product_lineup/index.html
http://panasonic.net/avc/lumix/systemcamera/gms/pdf/g_series_system_chart.pdf
https://www.sdcard.org/consumers/speed/uhs/uhs_compatibility.png
a lot off useful info about SD cards
So. there is no different in speed, but only in size.?
SDHC supports 4GB to 32GB
SDXC supports 32GB up to 2TB
The SDHC and SDXC with a UHS-I Bus Interface (Busmark I, SDHCI, SDXCI) Bus speed 50MB/s (SDR50, DDR50)
104MB/s (SDR104)
The SDHC and SDXC with a  UHS-II SDHC and SDXC  (Busmark TBD) Bus speed 156MB/s
312MB/s
I am really confused, and my mind is screwed ad the moment :-(
