The new model will be the world's first medium format mirrorless digital camera to feature an image sensor that has phase detection pixels across the entire sensor, outperforming contrast detection autofocus in tracking a moving subject and delivering greater accuracy in continuous autofocus. This model will also become the first medium format digital camera to feature in-body image stabilization mechanism, to significantly broaden the scope of achieving ultra-high resolution handheld images. The camera boasts substantially improved video recording capability compared to that of the GFX 50S and GFX 50R. It will be the first mirrorless digital camera equipped with an image sensor with the size of 43.8mmx32.9mm to support 4K video recording (4K/30P).
This model will be Fujifilm's highest performance camera that offers unrivalled innovation and versatility, as seen in the three "world's first" features, satisfying all the needs of photographers at a higher level.
GFX 100 megapixel camera main features:
FUJIFILM G Format image sensor with over 100MP resolution
The camera is equipped with a 102MP "FUJIFILM G Format ("G Format") image sensor, specifically developed for this model. It delivers the highest image quality in the history of Fujifilm when combined with the fourth-generation "X-Processor 4" image processing engine that delivers superb color reproduction Fujifilm is famous for, and FUJINON GF lenses that offers ultra-high resolving power. Phase detection AF coverage on the entire sensor (approx. 100% coverage) enables fast and highly accurate autofocus regardless of your subject's position within the frame, providing a level of performance that defies the current standards of medium format digital cameras.
World's first medium format digital camera to feature in-body image stabilization
In general, the higher the number of pixels that an image sensor has, the greater the likelihood of producing images out of focus from camera shakes. This is why Fujifilm has developed a new in-body image stabilization system for the G Format. This is also a world's first for medium-format digital cameras. This has dramatically expanded the scope of achieving ultra-high resolution images (100MP+) hand-held, allowing users to explore new photographic opportunities.
World's first medium format mirrorless digital camera capable of recording 4K video
The combination of X-Processor 4's advanced processing capability and the new image sensor with fast read speed has enabled 4K video recording (4K/30P, 10bit), the world's first for a medium format mirrorless digital camera. The use of the larger image sensor facilitates a shallower depth of field, broader tone reproduction and advanced sensitivity characteristics. This, in turn, makes it possible to record a subject's texture, three-dimensional feel and even the atmosphere of the scene with an unprecedented level of ease.
Lightweight and robust magnesium alloy body with integrated vertical grip
The new camera has the size and weight equivalent to a high-end DSLR despite featuring an image sensor which is about 1.7 times the size of a 35mm sensor. This will be the first GFX camera to feature an integrated vertical grip, making it more robust and comfortable to hold, especially when large telephoto lenses are used.
New firmware coming
The 4.0 firmware will be available in June and will include a boosted AF speed, improved face/eye-detection performance, and enhanced AF tracking and accuracy for all modes including the capture of movement. The IBIS and OIS will now work together to enable the optimum correction based on the amount of camera shake and frequency of the gyro sensors. Below are additional updates and improvements:
- The level of "clarity" can be set in the range from -5 to +5.
- The "tone curve" can be adjusted in the increment of 0.5 stop for both highlights and shadows.
- The "focus limiter" function is added to specify any focusing range. Choose the default focusing distance or select it from the specified range.
- Pictures can be enlarged in the magnification of 1x, 2x, 4x or 8x in playback. There is also an option to select the magnification used in the previous playback (from center).
- Function button can be assigned to switch "shooting mode" between P, S, A and M modes.
- The front and rear command dials can be set to rotate in a reverse direction.
- The number of items in the Q menu can be selected from 4, 8, 12 or 16 for both stills and video. The items to display in the Q menu are customizable.
- The Q button can be assigned as a function button.
- The camera stays ON even when an SD card is removed.
- Electronic image stabilization is available while shooting video.
- It corrects camera shake that occurs when shooting video handheld. (1.1x crop when this mode is turned on)
- Live View can be enlarged even while shooting video.
- The Focus Check Lock can now also be set to ON/OFF to maintain focus check or not when starting to shoot video.
- Video recorded in the SD card can be backed up to the SD card in another card slot.
- The elapsed video recording time can be displayed on the LCD for checking.
- The AF area size can be changed while shooting video.
- Video files recorded with F-log can be played back in conversion equivalent to BT.709.
- Added White Balance / ISO metadata to RAW footage, output to Atomos Ninja V HDR Monitor Recorder via HDMI. The footage is recorded as Apple ProRes RAW files and White Balance / ISO can be adjusted in Final Cut Pro.
New pixelshift mode via new firmware
25th November FUJIFILM Corporation (President: Kenji Sukeno) is pleased to announce firmware version 3.00 for the FUJIFILM GFX100, which adds the Pixel Shift Multi-Shot function to the GFX System’s flagship mirrorless camera. This update allows photographers to create images with 400MP of resolution.
Joining the firmware is a new software application, the FUJIFILM Pixel Shift Combiner, which combines the 16 RAW images created by the new Pixel Shift Multi-Shot function into a single 400MP image. It also facilitates tethered capture capability when used with the Pixel Shift Multi-Shot function. This simple capture-to-edit workflow is a great solution for fine art and still life photographers; the additional resolution creates images with incredibly accurate colour reproduction that are high in detail and rich in tonality.
Photographers can use the Pixel Shift Multi-Shot function to faithfully reproduce every detail and achieve superior image quality with 400 megapixels of resolution.
Using state of the art technology to create an image
Utilising the GFX100’s 102MP large-format sensor*, high-precision in-body image stabilisation mechanism (IBIS) and its powerful X Processor 4 image processor, the Pixel Shift Multi-Shot function slightly moves the image sensor by 0.5 pixels to incrementally record high-resolution RGB pixel information over the course of creating 16 RAW images. Those images can then be imported into Pixel Shift Combiner, to create a single 400MP image, and outputted as a DNG RAW file for further processing in Capture One*2 or any other compatible editing software.
Preserving detail, one pixel at a time
The Pixel Shift Multi-Shot function reproduces fine detail and colour accuracy by shifting the image sensor so that each pixel records image data in red, green and blue. This allows for unparalleled colour reproduction, with next to no false colours occurring, even in the finest of details. This benefit makes it the perfect choice for digital archiving and preserving works of art, cultural assets, and any other applications that require immense colour fidelity and the reproduction of fine details.
A simple workflow for tethered or untethered applications
In addition to combining and outputting DNG RAW Files from images created through the Pixel Shift Multi-Shot function, Pixel Shift Combiner also provides photographers with tethered capture functionality to allow for seamless transition from making images to combining, and, subsequently, editing them in Capture One*2 or any other compatible editing software.
For those working in the archival or cultural preservation fields, these new functions are especially valuable to photographers documenting historical artefacts or large works of art, because they can be preserved digitally, at 400MP, with colour reproduction that only Fujifilm can provide. With Pixel Shift Multi-Shot, GFX100 can now be used to precisely record these artefacts so that they may be shared with future generations before they are lost forever.
https://fujifilm-x.com/global/support/download/firmware/cameras/gfx100/
FUJIFILM GFX100 IR
FUJIFILM North America Corporation is pleased to announce the launch of FUJIFILM GFX100 IR digital camera (GFX100 IR), a uniquely specialized version of its GFX100 large format mirrorless digital camera, now with infrared image-making capabilities, which can be produced upon order for professionals in forensic, scientific, and cultural preservation fields. Infrared images can now be made at 100MP - and even at 400MP through GFX100 IR's new Pixel Shift Multi-Shot function - to reveal intricate details within a subject or scene that can only normally be seen through the infrared spectrum.
GFX100 IR also includes the ability to:
Make images in the infrared spectrum at an incredible 100MP or 400MP of resolution
Images made of a subject within the infrared spectrum can reveal details that a regular (non-IR) digital camera or the naked eye cannot see. For example, in the field of forensics, this can be an important tool in helping to identify counterfeit documents. For individuals working in cultural preservation, GFX100 IR can be used to analyze pigments in works of art and historical artifacts, even if they have degraded over time. Using the Pixel Shift Multi-Shot feature on GFX100 IR can create 400MP images with incredible detail and little-to-no color fringing.
"Using GFX100 IR with the Pixel Shift Multi-Shot feature is invaluable for cultural research because reviewing images in infrared could lead to unlocking the secrets of some of history's most treasured artifacts," said Victor Ha, senior director of marketing and product development for FUJIFILM North America Corporation. "It can also be an incredibly powerful tool for researchers using the images to evaluate works of art or pieces of evidence."
Use special filters to make images within specific wavelengths
Different IR filters in front of the camera lens can be used to make images at various wavelengths, which can reveal different details within a subject. However, using the appropriate IR cut filter will allow GFX100 IR to be used normally (i.e. in the same manner as the standard FUJIFILM GFX100 digital camera) to make regular, color images within the visible spectrum.
Additionally, when the camera is set in a fixed position and paired with Capture One or a similarly compatible software application to engage tethered capture functionality, users can create images with the same angle of view. This enables them to maintain a simple capture to output workflow for maximum efficiency.
Availability
GFX100 IR is designed for forensic, scientific, and cultural preservation applications, and the product will not be made available to general photographers or customers for personal use. GFX100 IR will only be offered by specific, Fujifilm authorized retailers, and sales of GFX100 IR will be subject to a GFX100 IR User Agreement, which sets out the specific terms of use for the camera. GFX100 IR is currently expected to be available in the first quarter of 2021.
The GFX100 Pixel Shift Firmware coming in Late November. It will allow you to take 400MP shots.
Sensor assembly
FUJIFILM started providing the latest firmware for the mirrorless camera "FUJIFILM GFX 100" on July 27th.
There are two updates. Improvement of "the problem that the image may be displayed slowly during playback" and bugs when shooting movies. The updated version is Ver.2.01.
GFX 100 will Get Free ProRes RAW via Firmware Update.
A GFX System firmware update will bring new technology to the In-Body Image Stabilization (IBIS) feature found on the GFX100 so it will be able to capture 400MP images.
Part 2
Samples
https://www.dpreview.com/sample-galleries/7927473748/fujifilm-gfx-100-sample-gallery-dpreview-tv/
