Specs:
Video modes
G9 Firmware Ver. 2.5
Added functions
[Focus Ring Control] function has been added.
Compatible lenses: H-XA025, H-ES200, H-E08018, H-X1025, H-HSA12035, H-ES12060, H-FS12060, H-X2550, H-HSA35100, H-FSA45200, H-ES50200, H-FSA100300 and H-RS100400
Do you use G9 with Vlog and Vlog assist? Im using one the same Lut and getting different results (brightnes)
In camera .tln image is much brighter then In Ninja and in NLE (looks correct)
Interestingly when I set Vlog assist to HDME out in G9 and disable LUT in Ninja. In G9 is still brighter (about 1/2 2/3 stop Very visible in shadows wit low key)
I cant see any setting to fix this. Is this regular issue or only in mine any one notis this?
A question about this last video, showing Eye Af in video: looks like the camera is in AFS mode, how could it track the face dynamically while recording? It should not be in AFC?
Panasonic Lumix G9 Mirrorless Camera Body+Battery grip for $997
