		Olympus LS-100  is coming this February.
http://cinescopophilia.com/399-olympus-ls-100-24-bit-multi-track-recorder-with-xlr-inputs/
I have a new DR-40and tested the battery life. i was set at Dual, MP-3 128, Phantom off, and turned on Record on a trip. The battery died at 8.5 hours. Tascam told me that if I had it at basic settings the batteries would have lasted longer. The manual says they should last 18 hours. Everything else works great so I am reluctant to return it. Will good rechargeable's do better? Anyone have any thoughts?
I use nothing but lithium ultimate in all devices. They seem to last forever unless I forget to turn something off at the end of the job.
I've used a DR-100 for more than a year now. With DPA-4060 lavs it works pretty well. They are sensitive mics so the gain doesn't need to be turned up so high. The preamps are OK, but nothing great. I've also used it with a Rode NTG2 which is a quiet mic but when I turn up the gain some slight noise is introduced.
Battery life is OK. It does seem picky with rechargeable batteries so I mainly use the Li-ion battery. Other than that I've had no other problems.
