Beginners: Basic hacks questions
  • 1012 Replies sorted by
  • @bobsomebody
    This is why I asked to READ SOMETHING.
    Like instructions in PTool topic.
  • Vitaliy, with all due respect that is what I am doing. When I click the 'load firmware' button in PTools my file browser doesn't show the downloaded file. I am having problems with it, and it is obviously a simple question that I can't seem to get to work-the reason I am posting in the Basic and beginners questions thread.
  • How about try to read something?
    Just click on round button, select settings you downloaded, and it'll import settings.
  • Just load that directly downloaded file into Ptools?.....Trying now...
  • @bobsomebody
    You don't need to unzip them :-)
  • Just to elaborate on this, once I unzipped the files from the patch vault all I'm getting is serb.ini file-any help much appreciated.
  • Hi folks, one question: Up until now my friend had been sending the patched zip files that I would just drop onto my SD card and hack away with. Now Im wondering-I have the direct files from the latest hacks from the patch thread but how do I then get that file onto my SD card to update camera? I have the new Ptools open but where can I load the patches in? Im on a mac using wine bottler. Thanks
  • Lowrider, I'm too new to have a clue.... sorry
  • scaper . Its brand new and I did hacked it (1 month ago) with the 3.62 V and blackpowell patch works great (now It has the Version 0.0 installed) Im trying to install the patch Timelapser ans Driftwood patch but after all the required steps, when I turned the camera on, the camera does read the new firmware version, stays the same,
    I did try the new 3.63 V as well but it does not read it anyway, any thoughts on this?
  • Lowrider, if your camera is brand new, set the increment number to 2 at the top of the ptool window.
  • @aljimenez, this is something youu can test for yourself easily. Auto ISO with the ISO limit removed appears to go up to 6400 or so.
  • hi
    I did the whole step by step update firmware, battery charged, hacked firmware on card. but when i power the camera y press the playback button, nothing happens, anybody knows? I tried the whole process 3 times, nothing happens when i press green button.
  • I can't get ptool to run. I'm running on an Intel Mac with wine bottler. When I launch ptool3.exe, wine seems to run fine, there's no error message but nothing happens at all. I've downloaded ptool several times and unzipped it using different utilities with always the exact same result. Any ideas??
  • The max ISO in AutoISO is 3200, and was wondering if VK, now that the ISO has been released for video, can do this for AutoISO? Probably not since this is probably a table in the AutoISO that cant be made larger? Al
  • I love Japan. Been there twice; Kyoto, Kobe, Shinzuka, and of course Tokyo. Keep trying out the patches, it could be your sd card and you may want to test another card.
  • I may have jumped the gun on my last post. Though I can get it to record continuously at 80%, I have to make it pretty dark. First test was on a bright moving object though, so not sure why that one worked. Otherwise it is working well on the other settings though with the exception of one right error, forgot if it was 24p or Manual.
  • @Driftwood, well this is interesting. After shooting with the SpanMyBitchUp patch all day and with zero problems and using 80% slowdown often, insomnia got me curious and I patched my GH2 with Seaquake just cause this is your one high end patch I had not yet tried. For some reason, very very curious as to why, Seaquake works with the 80% slowdown, when Terraquake and AQ2 did not. I have yet to test the whole board, but this is encouraging and curious... encourious... sorry, insomnia. Off too the bunny cafe tomorrow to test it. Yes Japan has a bunny cafe. Real bunnies, not sexy girls.. but they have those too ;)
  • I have to do more work on Seaquake... but I am very impressed to say the least!
    The idea just dawned on me that even high end encoders will NOT retain as much data as some of your settings are... so where is it all going? I have been thinking of conducting controlled tests between different settings and subtracting the images to see where the differences lie. The theory is (and as @Ralph_B tests seam to prove) that pushing quality insanely high has a 'domino' effect for chroma encoding as well... (Possibly we could even get what turns out to be medium quality chroma 422 and super quality 420? Poor mans 422 perhaps?)
  • @alcomposer that's a very good question. If I remember @Ralph_B conducted chroma /colour tests on the original 220m intra patches and found it much better in the colour channel and easier to grade. I dont think youre going to c much difference in the latest intra patches like seaquake. Its time for more tests on this. How have you found it?
  • im looking for applicable night time (latest) hacked settings for GF1. kindly point me to the link.
  • go easy though man- let me enjoy the spanning on your settings for at least one day.
    ;-D
    One question @driftwood, (directed at you because you have so much knowledge of PTool and Intra):
    With bit rate exceeding already that of AVCINTRA 100, does the added quality of 4:2:0 allow higher quality in the 0 colour channel when converted? (this is to say that 4:2:0 at 200mb/s can look as good as 4:2:2 at 100mb/s) Kind of like saying super high quality luminosity 'punches through' the chroma channels...
  • @alcomposer Hi mate, yep, and pushing the frame limits further :-)
  • @driftwood,
    Looking forward to corroborating spanning on 95MB/s 64gig Sandisk!
    (And checking out your new super settings!)
    :-D
  • @evanflys Im having no problems with TerraQuake and 720p, also you could try AQuamotion v2.
  • @el3nd1l 80% slowdown is pure INTRA at 30fps roughly. However, that mode does not record audio. People use it for effects.
