Specifications:
The slow drumbeat for the X-H2 begins. Feels like full circle from the GH2 patch projects is upon us.
Fuji X-H1 Mirrorless Digital Camera w/ Battery Grip + 16-55mm f/2.8 R LM WR Lens, $1198
Fujifilm X-H1 + vertical power grip + $400 gift card for $1949
V2.0 firmware available now
- In-body image stabilization and optical image stabilization now work together to improve overall stability With an XF or XC optical image stabilized lens, in-body image stabilization worked with 3 axis (up and down / optical axis rotation). The remaining 2 axis (right and left pitch, yaw angle) was controlled by optical image stabilization in the lens. This firmware has a new image stabilization algorithm to allow the in-body image stabilization to work in all 5 axis and to achieve more than five-stops (up to the equivalent of 5.5 stops (*1)) image stabilization by cooperative control according to the types of frequency and blur amount. To activate this function, lenses are necessary to be updated to latest firmware version.
- Improved in-body image stabilization performance
Eliminate image shake when panning slowly when movie recording or on the live view image.- Recording over 4GB movie file as one file
Movie files are no longer split when the file reaches 4GB file size. The file is recorded as one file providing an SD memory card greater than 32GB is used (excludes 32GB) .
By using SD memory cards less than or equal to 32GB, movie recording will continue without interruption when the file size reaches 4GB, however subsequent footage will be recorded to a separate file.
Note:Format SD memory cards before first use, and be sure to reformat all memory cards after using them in a computer or other device.- Display color temperature (Kelvin) on EVF/LCD
Color temperature (Kelvin) can be displayed on EVF/LCD.- Display power supply icon
Power supply icon is displayed on EVF/LCD while using AC adapter (AC-9VS), or Anker PowerCore+ 26800 PD- Fix of slight defects.
http://www.fujifilm.com/support/digital_cameras/software/firmware/x/xh1/index.html
FUJIFILM X-H1 Ver. 2.00 : December 2018
With an XF or XC optical image stabilized lens, in-body image stabilization worked with 3 axis (up and down optical axis rotation). The remaining 2 axis (right and left pitch, yaw angle) was controlled by optical image stabilization in the lens. This firmware has a new image stabilization algorithm to allow the in-body image stabilization to work in all 5 axis and to achieve more than five-stops (up to the equivalent of 5.5 stops ) image stabilization by cooperative control according to the types of frequency and blur amount.
To activate this function, lenses are necessary to be updated to latest firmware version. Please check the latest firmware version from http://www.fujifilm.com/support/digital_cameras/software/fw_table.html#interchangeable_lens- Improved in-body image stabilization performance
Movie files are no longer split when the file reaches 4GB file size. The file is recorded as one file providing an SD memory card greater than 32GB is used (excludes 32GB) . By using SD memory cards less than or equal to 32GB, movie recording will continue without interruption when the file size reaches 4GB, however subsequent footage will be recorded to a separate file.- Display color temperature (Kelvin) on EVF/LCD
Color temperature (Kelvin) can be displayed on EVF/LCD.- Display power supply icon Power supply icon is displayed on EVF/LCD while using AC adapter (AC-9VS), or Anker PowerCore+ 26800 PD *10 and Anker PowerCore Speed 20000 PD. Anker and PowerCore are trademark or registered trademark of Anker Innovations Limited or associated companies. Product may not be available on your country.
New v1.12 firmware
Stability improvement for connection with some wireless routers.
Fujifilm X-H1 24.3MP Mirrorless Digital Camera Black With Free Accessory Bundle, $1649 Deal
Thermal shots had been made with continuous recording with one second pauses for restart, total time was 45 minutes, ambient temperature was 25 degrees Celsius.
In other words - things are bad.
@Vitaliy_Kiselev I found the article and read the translation kind of surprised. Not that I'm going to buy a X-H1 my X-T20 is working great and I've only seen a heat indicator once and it was recording with battery in camera and installed in an underwater case constantly running on and off for an hour. So I'm surprised by this. I guess getting the battery out of the camera is significant from my experience.
Camera heats >50 degrees shooting 4K, very uncomfortable to hold
Bare Samples
Firmware v1.10 released
- The functions of "Select Folder" and "Create Folder", which was planned to be included in Ver.1.10 will be incorporated in Ver.1.20 to be released in July 2018.
- Upgrading firmware from Ver.1.00 to Ver.1.10 will remove the functions of "Select Folder" and "Create Folder".
It sound strange.
As flange distance for Fujifilm is much less than Canon FE and M42.
https://en.wikipedia.org/wiki/Flange_focal_distance
Active adapter is https://www.fringeradapter.com/#for-x-mount
Need some advice. A friend of mine is thinking of buying this camera. She works with both photos and videos. She was working with Canon 5D until now. She has several M42 Takumar lenses and one Canon electronic lens left. Will she be able to use these lenses on the Fuji Camera without quality loss? The analogic adaptor comes with an optical lens (normally these kind of adapters have quality loss) and obviously some of the features will not work, such as stabilizer etc. What do you think?
