Panasonic GH5S GH5 S, 4K Video Edition
  • 512 Replies sorted by
  • FW Update is coming for GH5 & GH5s. Seems to incorporate C-AF fixes for video mode as well as some additional enhancements for video. Also some updates for photo features. But still unclear if GH5 will get higher frame rates and high res mode.
  • For acceptance in the EBU Tiering system, the camera should be used with the optional sound module to allow for XLR audio connections. Monitoring connections are only just adequate, only HDMI is provided, but this connection can carry all the resolutions so this ought not to be a problem.
    Colour performance is good and there was no evidence of any Infra-Red response.
    Resolution at HD is very good, with very little spatial aliasing. At UHD (and therefore at 4K as well) resolution is good but not as good as at HD, and there is inevitable coloured aliasing horizontally and vertically, and diagonal luminance aliasing, but neither is at a high level. This confirms that there is a good optical low-pass filter in the camera, and that the down-scaling to 1920x1080 HD is done with a good algorithm.
    The dynamic range is about 14.6 stops in HLG, a creditable performance. CineLike-D is about 13.9 stops and Like709 about 10.3 stops with the Knee switched off. However, all of this is using the 4:2:2 10-bit recording modes. Using any of the 8-bit recording modes will automatically reduce the dynamic range by at least a stop.
    However, the dynamic range of Like709 can be extended by using the Knee function. Previous tests, not published, showed that the knee can capture about 2.5 times normal exposure (+1.3 stops), so the dynamic range for Like709 can be extended to about 11.6 stops – even with 8-bit recording.
    https://tech.ebu.ch/docs/tech/tech3335_s29.pdf
    800 x 347 - 43K
    622 x 449 - 39K
  • @thetrickster: where did you find that trade-in offer?
  • @suresure123
    Rolling shutter, but the readout is extremely fast on it compared to any other mirrorless out there. The effect is very very well handled
  • @suresure123 rolling shutter
  • Is this global shutter?
  • Wonder how many GH5S owners will be selling their camera in September ;)
  • Just got around to putting together some of the videos I shot when testing out the GH5s pre-production several months ago!
    Here's a music video we shot using only a single 60watt bulb camera right and a variety of lumix lenses (42.5 f1.2, 15mm f1.7, 25mm f1.4)
    This was shot using the first pre-production firmware so didn't have the full range of dual ISO, but most shots here were between 1600 and 6400 with no noise reduction!
  • Panasonic doing £200 / 250€ trade in on old cameras against the GH5s in EU Land.
  • Found some pretty impressive 240fps slow-mo eagle footage. Some of it is a little out of focus but I'm sure this was very challenging shooting.
  • Tyger Tyger (The Tiger by William Blake) in HDR Hybrid Log Gamma GH5S shot in Rajistan India Ranthambore Bagh. filmed over 5 days and 10 safaris we managed three of them to find tigers to build this story.
  • The Artist Inspired by HDR filmed by Driftwood. Really loving the wider curve in the highlights of Hybrid Log Gamma.
  • unfortunately it's a bad sample as the de-squeeze in post isn't strong enough.
  • Gh5s with anamorphic adapter 50mm:
  • @IronFilm
    Several YouTube videos posit that a Synchro Scan setting at 179 degrees (rather than the normal 180) greatly assist with autofocus. It appears to work for both the GH5 and GH5s. This video is one I've found quite interesting.
  • That is the proverbial $64,000 question many of us are asking ourselves. If you need stills as well as video and value IBIS over low light functionality, the GH5 is likely the camera for you. If you are looking for a video-centric model with far better low light performance and no IBIS, then you'd probably be most happy with the GH5s.
    Some people might be able to live with the 10.2 megapixels of the GH5S :-) It is still heaps more than the Nikon D50 I started out on! (and massively better low light than the CCD sensor of the D50! :-o )
    I'm personally leaning now in favor of the GH5s, notwithstanding both Panasonic cameras' reported poor auto-focus performance. (Yes, I'm aware of the 179-degree shutter angle workaround that could ameliorate this issue a bit.)
    What is the 179 degree work around?
    TBH, I think the GH5S is the new GH2. I'm loving it. I will post some vid, when I have compiled enough.
    Nice way to put it, this generation's GH2
  • A nice old violin, with fake pegs, bridge and tailpiece.
