I’ve been editing with 2012 MacBook Pro I7-16gb ram, using ssd external as scratch disk thru usb3 port. I was looking to speed up my work. Would a portable SSD raid be a solution ? Like this?https://www.amazon.com/dp/B071HQXGWH/ref=cm_sw_r_cp_api_zxIuAb9NXRWFF
Any cheap but work recommend would be appreciated.
Since that box seems to implement RAID in hardware, it's even possible that it will be a little bit slower than a single SSD (though RAID 0 is simple enough that it probably won't be). Otherwise, a device like that would be more useful for a portable RAID 1 to keep multiple copies of files that you care about.
No.
If you want, you can get larger SSD. But it won't speed up anything also, just will be more space.
@ Vitaliy_Kiselev 2 ssd in that enclosure raid 0 is my plan would help to speed it up?
No, it is waste of money.
Any normal single SSD disc speed is more than speed of USB 3 port.
