I’ve been editing with 2012 MacBook Pro I7-16gb ram, using ssd external as scratch disk thru usb3 port. I was looking to speed up my work. Would a portable SSD raid be a solution ? Like this?https://www.amazon.com/dp/B071HQXGWH/ref=cm_sw_r_cp_api_zxIuAb9NXRWFF
Any cheap but work recommend would be appreciated.
No, it is waste of money.
Any normal single SSD disc speed is more than speed of USB 3 port.
@ Vitaliy_Kiselev 2 ssd in that enclosure raid 0 is my plan would help to speed it up?
No.
If you want, you can get larger SSD. But it won't speed up anything also, just will be more space.
Since that box seems to implement RAID in hardware, it's even possible that it will be a little bit slower than a single SSD (though RAID 0 is simple enough that it probably won't be). Otherwise, a device like that would be more useful for a portable RAID 1 to keep multiple copies of files that you care about.
