Xiaomi Xiaoyi YI-M1 m43 camera, 4K video, $213 only now for kit
  • 303 Replies sorted by
  • I bought it. I saw the reconring time limitation. I brought back to the seller. What a pity. They lost another customer. In fact Panasonic GX80/85 is FAR better.
  • YI M1 4K 20 MP Mirrorless Digital Camera with Interchangeable Lens 12-40mm F3.5-5.6 Lens / 42.5mm F1.8 dropped to $322
    https://www.amazon.com/YI-Mirrorless-Digital-Interchangeable-F3-5-5-6/dp/B01CW4CKHW/
  • @RockHunter
    The way camera companies make firmware I never advice you to do such updates. Use old proven method.
  • Alternate way to install firmware instead of using the SD card. If your cell phone is a Apple or an Android phone you can install the YI app. With that app you connect to the camera with Bluetooth. Then you can install firmware updates to the camera or the lens using your cell phone.
  • Still crossing my fingers for clean HDMI out~
  • Wow! Some progress finally.
  • More detailed version of changes
    Functionality:
    • Added exposure control in the mode P/A/S/M for video capture
    • Added AF/MF control for video capture
    • Added RAW+JPG format for still capture
    • Added a quick control panel on main shooting screen, which greatly improves access to frequently used settings:
      • Focus Mode (S-AF, C-AF, MF, MF+Peak Focus)
      • ISO (Auto, 100-25600)
      • White Balance
      • Metering Mode
      • File Format (JPEG, RAW, RAW+JPEG)
      • Drive Mode (Single, Continuous, 2s and 10s Self-Timer)
    • Added a histogram in live view mode for both still and video capture
    • Added the option to shoot 1-3 images when using the self-timer function with an initial 2 second or 10 second timer setting
    • Supports remote shooting using the YI M1 App
    • Added still image option to Time Lapse
    • Raised Auto ISO maximum limit from 3200 to 25600
    Focus stuff:
    • Improved AF speed by approximately 300%
    • Improved AF speed and accuracy in low light
    • Added new focus viewing modes with improved image quality including: 6x, 8x and 10x magnification in MF mode
    • Supports AF upon selecting a focal point manually
    Image Quality:
    • Greatly improved 4K video quality.
    • Greatly improved still image quality, especially in high ISO and low light environment in JPEG and RAW
    • AE algorithm optimization greatly improved
    • UI/ Display:
    Improved Touch Screen Control experience.
    • Added 2 ways to show the Metering mode in the UI
    • Added the user guide (Restoring factory settings to view)
    • Added 2 new options for the display grid
    • Master Guide template display logic optimized
    • Change the thumbnails in each screen from 9 to 12 images.
    • Improved the display for f-stop (F), shutter speed (S) and exposure compensation (EV) on the Live view interface, especially if that function cannot be selected
    • Added a prompt message when switching Macro and Normal modes for the f/1.8 42.5mm prime lens
    Other:
    • Added multiple selection of images for deletion.
    • Improved the overall stability of the system
    • Added sleep mode
    • Supports ISO AUTO in M mode
    • Added French, Italian and Spanish languages
    • Greatly improved the compatibility with M 4/3 lenses
    • Improved SD card compatibility
    • Improved Auto power off function
    • Improved the audio quality when recording video
  • Official v3.0 press release
    New
    • Added AF/MF control for video capture.
    • Added still image option in Time Lapse
    • Added the option to shoot 1-3 images when using the self-timer function with an initial 2 second or 10 second timer settings
    • Improved AF speed
    Fixed
    Fixed some known bugs, and improved the overall stability of the system.
    Changed
    http://www.personal-view.com/downloads/firmware.zip
  • The app for the phone got updated.
    1. Added menu settings of continuous shooting and focus mode.
    2. Supported remote shooting for non-contact lens.
    3. Supported downloading RAW files.
    4. Supported downloading videos.
    5. Adapted to the firmware version 3.0
    6. Fixed minor known bugs.
  • Video I shot of a pet parade and competition using this camera and the included zoom lens.
  • One of the issues with the camera is that you cannot see your adjustments live (View how the video will truly look) in full manual mode unless you hit the record button. You could see your adjustments if you choose other modes such as Aperture or Shutter priority for example. The good news is that you can still adjust the aperture, shutter and ISO after you hit record in full manual mode. Would be way better if you were able to see your settings live before you hit record like you could on a Panasonic M43 camera when you set the dial to movie mode. I'm hoping in a future firmware update, you'd be able to do that on the M1.
    Except for the latest firmware, if you were to set up a shot in manual focus mode, about several seconds later, it would automatically switch to auto focusing mode. As if the manual adjustment issue wasn't bad enough as is. As mentioned, it seams like the latest firmware have fixed this problem because I'm not noticing it now. I really wish it was fixed earlier because it was truly a pain having to deal with this issue. It's still not perfect. If you shut the camera off and put it back on, it'll go back to auto focus. I'll need to test this more.
    In 4K mode, it'll only shoot until it reaches to around 7 and a half minutes. Basically stopping at around 4GB. If you want to shoot longer without the camera stopping, you'll need to shoot in 1080p. Another negative about the 4K mode is that it's not as wide as HD. Basically you'll have more in the shot shooting in HD than you would with 4K at the same focal length. This is actually how it is with the Panasonic UX90. You get a wider image with HD unlike the UX180 in which HD and 4K is about the same. While I'm at it, the Panasonic GH4 also gives you a wider image in HD.
    The GH5 is definitely leagues better than the Yi M1 in many, many areas but it's definitely a very big price difference. The Yi M1 is still a good value for just $300 and that includes the 12-40mm lens. For a package that includes the 12-40mm and the 42.5mm f /1.8, it's only $380.
    The competition for the Yi M1 would be the Panasonic GX850. for $548. It has a movable screen unlike the M1 which is fixed. It does not have a movie mode on the dial unlike some of the more expensive M43 cameras from Panasonic so I'm I don't know how the manual controls are on that for video.
  • @pureaxis
    Need to first test last firmware.
    Previous versions liked to randomly switch from manual mode to AF and such.
  • @Vitaliy_Kiselev what are those bugs, thinking of getting this as a cheap walkaround
  • @DrDave
    For now it has some quite severe bugs they can't fix.
    24p and more is far away, I think.
  • Do they have any interest in 24p? I'm looking for a set of road cameras that are not going to break the bank if they are lost or damages.
  • New firmware 3.0 final (internal is 1.39 now, from 1.37)
    • Various fixed of bugs
    Get at http://www.personal-view.com/downloads/firmware.zip
  • Thanks, guys! It worked! I'm already testing the new firmware.
  • If you did the previous firmware, this new one should be just as easy.
    Make sure to extract the firmware. The file you put in the memory card should say firmware.bin.
    Then when you put it in the memory card, it should be in the root. Basically it should not be in any folders. Just copy it into the memory card.
    Make sure battery have enough charge.
    Swipe from left to right to get into the menu. Scroll all the way to the bottom and hit "Firmware" Then press the 2 external buttons on the right side of the screen at the same time. Circle and Triangle button. Choose "Upgrade Camera Firmware".
  • @samuelcabral
    We updated our both M1s, so all good for certain.
  • Weird... I can't update with this file. I've already tried with 2 sdcards but the camera couldn't go thru
  • New firmware 3.0 beta 3 (internal is 1.37 now, from 1.35atm)
    • Histogram must now work in manual video work properly
    • Other manual modes fixes
    Plus lot of small fixes.
    get at http://www.personal-view.com/downloads/firmware.zip
  • @samuelcabral
    Check now, just two letters messed up.
  • @Vitaliy_Kiselev firmware link is broken. Could you make it available, please?
  • @Vitaliy_Kiselev @Ryvaeus Weird, isn't?
    891 x 524 - 382K
    953 x 527 - 367K
    957 x 532 - 298K
